Question about Dell 924 All-in-One InkJet Printer
Dell photo 924 - scanner does not work
My problem is very simple, when i press "SCAN" on my multifunctional, it doesn't do anything. it simply wont work. i tried to reinstall the software, change USB ports, disconnect printer power supply for 30 secs. none of them worked for me.
do you have a solution?
  • Huntress1 Apr 26, 2009
    My Dell printer works just fine with my Dell Desktop but not with my Dell Inspiron 1525. It will print from my computer but will not Scan....Does anyone know why?? Same problem as prior post.
  • Dell Master
  • 1,183 Answers
select the scan problems in the below mentioned guide , it would take you to the solution, if its a software fault.There is nothing much we can do if the scanner bed is faulty except for getting the printer replaced if under warranty
http://tinyurl.com/5nua8k
Posted on Apr 13, 2008
My Dell Photo A10 Printer is stuck on 'PAUSE' and I can"t get it off . Please help.
There is no A10 printer , the AIO stands for All-In-One. So i'll assume you have the 924 model.
First make sure the printer itself is functional: shut it down, disconnect it from the pc, start it and use it to scan and copy a file - just press the Start button.
If it doesn't work then the printer is effectively dead - the damage is in the procesor and to replace iot would cost more than a new printer.
If it works then there is something wrong in the setting from the pc. In that case the first thing you should check in Start ? Control Panel ? Printers and Other Hardware ? Printers and Faxes ? Double-click Dell Photo AIO Printer 924, and then click Printer ; in there make sure a check mark is not next to Pause Printing. If a check mark is next to Pause Printing, click Pause Printing to clear it. If it's not then the driver and the associated utility have been corrupted: uninstall it from Add/Remove Programs, reboot , manually wipe all the remaining Dell folders reboot one more time and reinstall them.
Aug 08, 2011 | Dell 924 All-in-One InkJet Printer
How to scan picture into computer
Follow these steps :
1.1
Open the software program that came from your scanner.
2.2
Lift the lid of your scanner, place photo on scanner bed and close the lid.
3.3
Press the "Scan" button on the scanner or in your scanner software program.
4.4
Preview the scanned photo on your computer screen and check that the borders are straight and even. Rescan the photo if you make changes.
5.5
Load photo paper into your photo printer.
6.6
Press "Print" on your computer screen where your scanned picture is showing. If "Print" is not an option, save your photo to a specific folder and open it. When it's open you should have the option to "Print.
Oct 29, 2010 | Dell 924 All-in-One InkJet Printer
How to scan on the dell photo 926
Download the latest printer software/driver for your operating system at the site below.
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=PRN_ALL_A926&os=WLH&osl=en&catid=&impid=
click start, click printers and faxes, click scanners and cameras, double click on scanner image device (scanner and camera wizard pops up) follow instructions from there.
Jul 28, 2010 | Dell 924 All-in-One InkJet Printer
I need instructions for 934 photo printer
Hello
Just click on the link, it will direct you to the page where you can download the manual.
http://www.retrevo.com/support/Dell-924-Multifunction-Printers-manual/id/261dj588/t/2/
Kind regards
Andrea
Nov 13, 2009 | Dell Office Equipment & Supplies
I have a Dell All-In-One PictBridge Photo 924. I
Open Dell All-in-one center, keep the picture on the Scanner bed and click on scan and choose a location to save the picture once the scan is completed and the preview is visible. Alternatively, a simpler way to do this is to Open MSPaint, click on File and click on Import from Camera or Scanner. Choose the kind of picture you want to scan and confirm scan. Try experimenting with options to experience scanning effects and image quality.
Good Luck!
-Abhishek
Nov 03, 2009 | Dell 924 All-in-One InkJet Printer
Dell All-in-One 924 Scaaning problem
Reinstall the printer using the instructions located at....
924 Photo All-In-One Printer owners thread (W7)
The Dell All-In-One Center and the OCR Program are needed to scan. If you lost your printer disk, Simple OCRshould work nicely with this printer.
Rick
Oct 06, 2009 | Dell 924 All-in-One InkJet Printer
Dell 924 scanner won't work
Downloaded the driver from the dell web site.
Version: G11a, A02
File Size: 36 MB
Dell Photo All-in-One Printer 924
Or
http://support.dell.com/support/downloads/download.aspx?c=us&cs=19&l=en&s=dhs&releaseid=R109906&SystemID=DIM_CEL_3000&servicetag=&os=WW1&osl=en&deviceid=8733&devlib=0&typecnt=0&vercnt=1&catid=&impid=&formatcnt=1&libid=0&fileid=143054
Aug 09, 2009 | Dell 924 All-in-One InkJet Printer
My printer/scanner will not scan my photos but will copy them.
The problem is the driver/twain driver/the software. reinstal it.
May 29, 2009 | Dell 924 All-in-One InkJet Printer
Scanner problem
I have a Dell Photo A10 924 Printer. If you click on the Printer Icon and select Microsoft Sanner and Camera Wizard it should scan in OK>
Dec 18, 2008 | Dell 924 All-in-One InkJet Printer
Dell AIO 924 Printer/Scanner Wont work with Vista
try to download the compatible driver for Vista!!
using the page of ur product starting with dell.com
Dec 12, 2008 | Dell 924 All-in-One InkJet Printer
Dell 924 All-in-One InkJet Printer Logo
905 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
