Fender Cyber Twin Head Analog Problem
Hi, My Cyber Twin head died on startup yesterday. The Power amp works fine, digital (Solid State) amp models work fine, but all analog models will not produce sound. I have replaced the T1A and F2A fuses and both 12AX7's, but sitll no life.
Any ideas?
Thanks,
Dave.
    Sergeant:
    Champion:
  • 319 Answers
Analog and digital are not compatible. You cannot plug in analog equipment to digital inputs. The signals are completely different
Posted on Apr 17, 2008
Amp loosing power
The Eden has a thermostatically controlled fan, my first thought is to clean the fan and airways and make sure it is working properly. This relates to some heat problems on solid state stuff. If they get too hot, some shut off for protection, the fan should automatically speed up on this model to compensate. When volume is low watch the fan. Also, make sure the impedance switch is set properly. I've very rarely seen any reason to use 2ohms settings. The only way to run that is with 2 4ohm cabinets in parallel. If they are in series it would become 8ohm. Any other way will make the amp get too hot on 2 ohm setting. Most cabs are 4, 8, and 16.
Mar 05, 2013 | Eden WT550 World Tour Bass Amplifier Head
Flexwave 120H Speaker wire shorted amp won't work
Solid state amps are very subject to blowing out the output transistors if speaker leads get shorted. Take it in for repair.
Aug 31, 2011 | Crate FlexWave FW120H Guitar Amp Head with...
I have 2 amps instalkled in my car one is sony 1200w 2 channel amp for speakers and one is solid audio f2500d for 3 subs my sound and every thing was good but suddenly from yesterday im having trouble when...
First disconnect the CD head unit from the sub amp and see if the other amp works. If yes, the problem is the wires to the amp, the amp itself, or the subs/sub wiring. If no, the problem is the head unit--probably an internal short.
If the other amp works with the sub amp disconnected, reconnect the sub amp to the head unit, but disconnect the sub wires from the amp. Try the CD player. If the amp goes to protect with no speaker wires attached, the amp is bad. If the amp is OK, the problem is the subs or sub wires. Hook the wires up to the amp again, but disconnect them from the speakers. Try the player again. If the amp goes to protect, the problem is the amp wiring. If not, the problem is the subs. Check the impedance of each sub using an ohmmeter to determine which amp is out of spec.
Please let me know if you have questions, and thanks for using Fixya.
Jun 11, 2011 | Solid Audio F2500D 1-Channel Amplifier Car...
The reverb channel on my fender twin feeds back
Not sure of how it is feeding back. Two possibilities... the reverb tank in the cabinet is no longer shock mounted. The other is your guitar can "hear" the speaker... make sure you are away from the amp. With the reverb on, the feedback stability is less than with it off so make sure your guitar is away from the amp. Acoustic guitars are more sensitive to this than solid body ones.
May 10, 2011 | Fender 65 Twin Reverb 85W 2x12 Tube Guitar...
I have the fender accessories footswitch and the cyber twin. The pedal has stopped working and I have replaced the cable but still does not work. Is it the pedal or the amp? The amp buttons still work...
Verify the footswitch with an ohmmeter. You should find that each of four pins should have continuity to pin 2 of the connector when the switch associated with the pin is pressed.
Note the pin numbers on the connector seem to have a weird layout. Here is a link to your amp schematic. The Footswitch interface is shown on page 3 of 12.
http://elektrotanya.com/fender_cyber-twin_sch.pdf/download.html
Use the ohmmeter to check each wire in the cable is good. SOme cables, unless the official one for the unit, may lack some wires.
The amp "reads" the footswitch state into a register which is then read serially. The inouts are pretty well protected from user mistakes. With the schematic you should be able to analyze the failure.
Feb 27, 2011 | Fender Accessories Footswitch for Cyber...
Samsung twincooling icemaker leaking water & overfreezing
probably the water valve is not shutting of completly . this will flood the tray and then run over into the bucket. try // i would replace water valve . if this does not correct prob. replace the ice mker head as it time's the fill..
Dec 11, 2009 | Washing Machines
03 Pontiac Vibe after rear ended several electronics died
10 amp fuse under steering column that says it is for 'Gauge' fixed this problem. That fuse had blown.
Oct 23, 2009 | 2003 Pontiac Vibe
FENDER CYBER TWIN AMP SOUNDS GREAT WORKS GREAT BUT WHEN YOU CRANK THE VOLUME A LITTLE LOUDER THAN NORMAL THE AMP GET STATIC OR DISTORTS OR POPS AND CRACKS. COULD THE TUBES DO THIS?
First make sure you have the TRIM knob positioned correctly. When playing loud the Red Led should just blink a bit so you know you're not overloading the preamp and Digital sections. The Twin Reverb Patch is a clean place to start so select that first. On this amp it's a good idea to set the MASTER to 5 and use the VOLUME control at as low a setting as you can. The GAIN control should be set under 4. You better sound crystal clear on this setting. Try turning up the volume to see how loud you can get without breaking up. It's a guitar amp so there will be some grainy distortion but it should be very light. I bet you get through this test without much trouble. After that you need to be very careful about what settings you're using since many of the presets may not mesh with your guitar pickups. You should concentrate on tweaking one highgain setting and learn about how the controls interact. The amp is so much more complicated than a 10 knob standard guitar amp. Most people need to put in some time to get a handle on it.
As far as the tubes go, typically they can get microphonic which was a problem with versions 1.1 and 1.0 of this amp so check that. Fender had a Cyber twin upgrade kit way back to fix this but if you have version 1.2 or 1.3 that's not it. Problems with this amp are typically caused by control setting more often than an electronic problem but this reponse should get you started figuring it out.
MYREL
Jul 13, 2009 | Music
Fender Stage 100 dsp, solid state amp volume (or power) problem
The Deluxe may have more efficient speakers....which would cause it to sound louder. Also, the EQ settings could play a part in this. If the EQ's aren't set the same there could be a noticeable difference in sound.....usually the mids can have quite an effect on overall amp volume....
May 31, 2009 | HHB Radius 50 Tube Amplifier
177 people viewed this question
 Grubhead
Grubhead
