Question about GE 24 in. Profile PDW7800 Built-in Dishwasher
Water inlet blocked , cleaned filter, still no water entering machine, if I remove machine from the fitted area, can I look into the inlet hose at the back of the machine
Paul Cleary
  • 132 Answers
Posted on Jul 12, 2009
  • MOHAMMED Jul 15, 2009
    also there is "water proof system "connected to inlet water source and this system has electricity inside so take care when you decide to un-tighten this "wps" there is a solenoid valve inside this box May it has a signal to close water because there is another problem>
    i hob it now clear
Miele Novotronic 500, 10 years old, noisy filling, no error light, inlet filters clean. Any suggestions please?
Hi dear,
As I know it's a indication on inlet valves going to fail. I hope that helps. Thanks.
Jan 21, 2016 | Miele Washing Machines
The "Check Inlet" is indicating on the wash cycle. The hose to the machine is fine, and the flow in the pre-wash is normal. The problem is that the water dribbles out of the inlet holes into the soap...
Check if there is a filter on the water inlet hose which could be dirty..Remove fill hose hold over sink/bucket check water flowing fleely if so then fit new solenoid Water valve...Good luck
Oct 13, 2013 | Miele Novotronic Premier 500 Front Load...
My miele washing machine says water inlet problem
Have you tryed to reset all the dials to zero disconnect power for a couple of minutes and check hose pipe not bend anyware then riconnect power set a wash and start.hope this helps also check pressure of water at inlet.
Feb 01, 2018 | Miele Washing Machines
Meile Novotronic W 828 Washing machine half way through the cycle it stopped and the screen shows a message saying "check the inlet"
It means what it says! i.e. water is not getting into the machine, the inlet hose or path is blocked or the inlet valve has failed. You need to turn off power and water and check it is getting water through inlet hose and that the inlet filter is clear, the filter can be seen on the valve when you remove the hose. You will need to open the machine to check the inlet valve and tubing. Hope that helps please vote
Feb 04, 2011 | Miele Washing Machines
I haven't used the miele novotronic washing machine in our other house for a year and noticed when i tried today the water was only dribbling into soap tray-thereis enough pressure in water feed so feel...
More than likely the problem is actually the inlet valve which only partly allows water to flow into the unit. you would need to remove the lid and replace the inlet valve which is on the left hand back corner of the unit. Valves are available from Miele
Jun 07, 2010 | Miele Novotronic Premier 500 Front Load...
Water leaking
deafenatly sounds like a blockage or remove soap dispensor and check that there is no damage below it
ie a crack in the plastic allowing water to escape
Jan 16, 2010 | Miele Novotronic W1918A Front Load Washer
Miele Novotronic W 844 Washing Machine
When I had this problem I went along the entire water inlet route and verified flow. Water flow entering the soap dispenser tray should be very robust & audible; if not, you have a flow restriction or low pressure, flashing red light or not.
I'm stating the obvious because I actually missed some filter elements the first time I tried. Disconnect inlet hose at plastic fitting on chassis and verify your flow there. Then look inside the inlet barb and use a small pair of channel lock or lineman's pliers to grasp the tab on the inverted "basket" and pull it straight out. These filters can be packed full of sand and small gravel inside--they were in my case.
Good luck,
Aug 03, 2008 | Miele Novotronic W1918A Front Load Washer
Water inlet flashing ,not filling, Miele Novotronic W939 Super
Hi Paul,
We currently have a similar problem with our W939. I took the front panel off and found that the Miele service folks had incorrectly routed the ribbon cable linking the fill level sensor with the control panel and severed one of the wires. The machine was reporting a series of errors, one of which was an outlet blockage and the discharge pump was not working.
The relevance to you is that your problem may be a loose or broken wire or corroded terminal.
Apr 14, 2008 | Washing Machines
Miele novo w526
Can you hear the drain pump running??....If so the WPS system has been activated and there is water in the base.
If not, please post back if any water is going into the main wash compartment once it's started. No water, then faulty inlet valve.
Jan 21, 2008 | Miele Novotronic Premier 500 Front Load...
Miele washing machine
All Miele washing machines and dishwashers need to fill in a required time. Flashing inlet (Tap icon) indicates that the machine can not fill in time. There are filters in the end of the hoses which connect to your water supply from the machine and filters in the inlet valves which you can get at by removing the hose from where it fixes onto the machine it'self. You will need some long nose pliers to grab the little tab on the small filter to get it out. Clean all filters and hoses. Still same problem then check the pressure of the water coming into the machine. There should be a good pressure coming out of the hose and will be difficult to stop the flow of water with your finger.
Dec 20, 2007 | Miele Novotronic Premier 500 Front Load...
GE 24 in. Profile PDW7800 Built-in Dishwasher Logo
383 people viewed this question
Top GE Dishwashers Experts
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
