Windows will not recognise my Iomega LPHD 160-U external hard drice.
  • Anonymous May 10, 2008
    Windws XP no reconoce mi disco externo Iomega LPHD 160-U
  • 3 Answers
1. Start > Run > type in cmd then click OK to get a command prompt.
2. Type in chkdsk e: /r (replace e: with the drive letter of your external hard drive).
This won't do any harm, it will fix errors on the disk and try to recover data from bad sectors. It might not solve the problem but it's worth a try.
Posted on Dec 22, 2009
Lphd-up
No there is no external power supply for that hard drive.
Jan 03, 2013 | Iomega (34959) 500 GB USB 20 Hard Drive
Iomega Portable hard disk service center in kerala
Look for the warranty center for Iomega, I did a quick google and found Accel the company to provide warranty. Look for their branches.
Nov 02, 2012 | Iomega Media Xporter Lphd up 160gb Usb 2.0...
MY IOMEGA LPHD-UP3 external/usb memory device, thinks it is full.
click start control panel administrative tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes
automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start
you might tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive
I found that you get best results by ticking one box then returning after it has finished then tick the other box
hope this helps
Jun 27, 2012 | Iomega Computers & Internet
Manual for Iomega lphd-up
Try the manufacturer's website.
Get onlineand got to www.google.com In the google search box type: "IomegaSupport" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operatingsystem when requested. Look for manuals throughout the site.
Jun 04, 2012 | Iomega Computers & Internet
No read or write turned on with a mistake
You have to be the computers administrator to change any values on any hard drive on your computer
click start control panel user accounts on the users tab click the name of the computer administrator you must have full control
click start click to open on my computer you should see your usb drive could be E: or something right click select properties there will be an array of options
select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box
then click permissions make sure you have all 3 boxes ticked full control changes and read in windows 7
click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP
click start right click on my computer select open
Right click the icon of your usb drive (It should be E:/ or something)
Click Properties in the menu that comes up
Click the Sharing tab
Click permissions
And finally, click Allow next to Full Control.
if you need more help with this post a reply
hope it helps
May 16, 2012 | Iomega Media Xporter Lphd up 160gb Usb 2.0...
Iomega LPHD-UP 500GB power issue?
The fault sounds like a power supply problem. The USB port on your computer supplies up to a max. 500MA and this may not be sufficient for the external hard drive to work properly.
I suggest you get a new AC power adapter for this drive.
Apr 13, 2012 | Iomega 500GB Prestige USB 2.0 Portable...
HI,my ext hard drive iomega lphd-up which holds my saved data is not recognised on my pc running windows xp (from which the data was transferred )or my new pc running windows 7. Tried a few tips from...
Hi Joyce,
You must check to see if your PCs have the correct drivers installed and active for this external HD. For some reason, often the PC will "forget" that there is a driver already installed, and you need to re-install it to get the HD to be recognized. If the drive came with a separate CD, or Mini-CD, containing an install program, you might need to run it all over again. It cannot hurt to do so. Most of the time, they do not want your external drive plugged into the PC when you are running the install. Be sure to check the instructions or if you don't have them, go to the manufacturer's web site and find them by the model number, under Support.
Let us know how it went?
Cheers!
-a.
Apr 10, 2012 | Iomega Prestige 1 TB USB 20 Hard Drive
How do I delete folders from my iomega 1TB external hard drive (LPHD-UPC)? I keep getting a message saying access denied / hard drive may be full (it's not) or in use? thanks
This can happen when you place a drive in multiple computers with windows. Also this can happen if the system used the drive to extract system folders.
right clickt he items and then click security. click advanced and you can go to the owner tab. under that there is a way to take ownership for the selected items and all subitems.
Mar 21, 2011 | Iomega 500GB Prestige USB 2.0 Portable...
Win 7 can't recognise my iomega hard drive LPHD-UP with s/n 54bk506524
Install the driver of the external hard drive first before connecting it to your computer, or when an icon appears on the lower right side of your desktop, right click on it and try to repair it by using troubleshoot compatibility. Maybe, your hard drive doesn't work with windows 7. You can run it in older versions of Operating Systems even if you have windows 7 in it.
Nov 19, 2010 | Computers & Internet
Computers & Internet Logo
869 people viewed this question
David Payne
David Payne
