Question about Hotpoint WD52 Front Load Washer / Dryer
Whirlpool AWZ 412 - Door not opening..
I have broken the lever of this front loading machine. Temporarily I want to just open the machine as all my office clothes are inside..and later probabily I will call someone to fix it..
Can someone please suggest how to open the door..
Thanks...
  • 32 Answers
FIRST switch off and unplug.
Pull machine out and remove lid by undoing self tapping screws at the top back. May have to slide lid back a bit to lift off.
Internal catch mechanism will be reachable from top for manual release. You may need someone to push door inwards while you release catch.
Good luck
Posted on Apr 13, 2008
Door won't open on front load washer
How to Unlock a Whirlpool Duet Washing Machine ' Home ...
homeguides.sfgate.com > Mortgages > Mortgage Options
If you must manually unlock the washer door after each wash cycle your drain ... to Change a Water Inlet Valve for a Whirlpool Duet Front-Loading Washing Machine ...Causes and Repair for a Whirlpool Washing Machine That Won't Spin or ...
How to open a washing machine door that won't ... - YouTube
? 3:57
https://www.youtube.com/watch?v=-65_eoT6zuk
Aug 22, 2013 - Uploaded by how-2-repair.com
Your washing machine door won't open this video will show you a technique ..... Front Load Washer Repair - Not Draining or Spinning - How to Unclog ... Washing Machine Repair - Replacing the Door Bellow (Whirlpool Part
Nov 05, 2015 | Whirlpool WFW70HEBW Duet 4.1 Cu. Ft. Front...
My whirlpool duet front load washer thre a code 28 and cant get the washer to finish cycle and can not get door open
Bottom front panel comes off is a release lever you can pull to open the door,inside that panel is also where they hide the manual. Sears repair told me the electronic brain box go/s after 2 years
May 25, 2015 | Whirlpool Washing Machines
Hi, I am not able to open the door of my Whirlpool washer dryer AWZ 5140 E after it finishes the cycle. It shows up E13 with ticking noise. There is no water left at this stage and I am able to open the...
E13 is a dispenser error the appliance diagnostic believes the appliance is full of water so won't release the lock first thing to try is the drain filter bottom right hand corner at the front unscrew it clean and refit just be prepared it's likely u will get some water out it when u remove it.
Dec 08, 2013 | Washing Machines
Cannot remove rubber door/drum seal on whirlpool 1000 awz 410
I also need to replace the door seal on my Whirlpool AWZ 410 washer. Does anybody have detailed instructions of how to do this for this particular machine model (not generic instructions) & know if it is necessary to remove the front panel on this machine in order to remove the existing seal please?
Feb 23, 2013 | Washing Machines
WHIRLPOOL AWZ 410-1000 parts
I bought before through Ebay , might get it cheaper there though .
Just make sure you got the right part number :) and search it ..
Regards,
Feb 19, 2013 | Whirlpool AWZ410 Front Load Washer/Dryer
Whirlpool awz 412 not spinning
You will need to replace the motor control board. It is malfunctioning on the high speed control.
Apr 24, 2012 | Whirlpool AWZ412 Front Load Washer
I need a user manual for a whirlpool AWZ 412 washer dryer
Unfortunately FixYa cannot provide manuals direct - members of the forum are just people from a
ll over the world, probably working from home, and not representing any particular manufacturer ;-0)
Manual
You will need to type into your search engine/web browser '(make model number) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
You could also try the manufacturer's web site direct ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Oct 05, 2011 | Whirlpool AWZ410 Front Load Washer/Dryer
Duet GHW9150P Front Load Washer: how do we open a whirlpool front loading machine w...
1. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. HINT: If you prop up the front feet of the washer with some small blocks of wood, this will make access to the screws much easier.
2. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose.
3. Reach your hand up inside the washer behind the front casing on the right-hand side. This is where the door latch assembly is located.
4. At the bottom of the door latch assembly is a small pull tab. This is the manual release for the door. Pull the tab straight down and the door will come open.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 17, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Door wont open
Here is a tip that will tell you how you can get your washing machine unlocked manually...
Washing Machine Door Jammed
http://www.fixya.com/support/r3864434-washing_machine_door_jammed
heatman101
May 05, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Front load Whirlpool Duet
Hi, Has the door catch,which protrudes and goes into the hole, broken off, it should have a sort of hooked end. Tom.
Mar 14, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Hotpoint WD52 Front Load Washer / Dryer Logo
291 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
