How to install windows xp in this motherboard P5RD1-VM? it goes no hard disk found.... i already check the bios for enabling sata but no option for that... help me pls... Thanks!
Yes, it's compatible with the motherboard, no, it's not compatible with the XP install disk because it doesn't have SATA support. And since Asus doesn't provides it special driver needed (one that must be put on a floppy) it means that you simply cannot install XP on this disk.
All you can do is to obtain another PATA hdd what ever its size and install XP in it. Then put the new SATA disk in and use it to store all the installed programs and all your files on it. As a bonus you won't lose them if the new PATA disk fails or XP gets corrupted. Or install Vista or 7 instead of XP, the have support for SATA disks
The problem is that XPinstallation CD does not have a SATA driver, unless you have a SATA drive on adisk etc. and can install the driver when XP asks for a hard drive driver then,XP cannot detect the hard disk and therefore won't install XP.
The FIX.
Go into the BIOS anddisable the SATA drive, this will make XP think it is a IDE/PATA hard disk.Then install XP normally. After Windows XP is installed then install all the device drivers (including the SATAdriver), then shut down and boot up and got into the BIOS and enable the SATAdrive.
The Windows installation CD does not have a SATA driver. You need a SATA driver of a floppy disk or turn off SATA native driver in the BIOS.
Please click on this link and follow my instructions on how to Install Windows on a SATA hard drive :- http://www.fixya.com/support/r4335035-installing_windows_xp_sata_hard_drive I suggest you install SP3 (service pack 3) rather than SP2, it contains the latest bug fixes. The SP3 cannot be installed from a floppy, it can be downloaded from Microsoft, it is a large file approx 300Mb, I suggest you install it from a CD if you can borrow one.
Make sure all the connectors are plugged in and in the correct spots. Then go to the bios and enable the SATA drives to be read. After that you should be able to boot from CD and install XP.
Check in the BIOS settings. You probably want to either enable legacy AHCI support, or you need the appropriate AHCI/SATA drivers for Windows XP. Otherwise, the system will install in compatibility mode, and then be unable to recognize the disk once booting in standard mode.
If you're using a scsi card and connecting the hard drive to the card you need to have the scsi set-up floppy disk. When the blue screen starts during windows installation watch the bottom of the screen. It will tell you to press F6 key then to insert the floppy disk.
If you're using a sata drive connected directly to the motherboard (not in a raid configuration) you shouldn't need anything but the windows disk. The motherboard drivers and utilities disk should have the files to create the scsi install disk.
1. put Motherboard Cd (come with p5rd1vm) in cd/dvd rom.
2. BIOS configur as boot from cdrom.
3. restart machin Motherboard CD boot with press enter
4. command line shows 4 option
5. Select 1st option for exact and proper copy ULi sata driver for winxp.
6. Insert floppy press enter
7.you see d copy procedure.
8.then this floopy insert when winxp setup asking F6 for additional driver.
Check the SATA/RAID controller setting.
It could have been set to [Disabled]
Refer to your user?s manual for a detailed description on how to enable the onboard SATA/RAID controller by adjusting the jumper or BIOS settings.
Regards
SparkGap
