The Status monitor icon that should be in the system tray is missing. It can be accessed but when closed with the red x does not drop into the system tray. Instead it dissappears
  • 32 Answers
Delete printer using Control Panel and Turn off PC.
Reinstall from scratch
Posted on Apr 13, 2008
CANT TELL IF MY CAP LOCKS ARE ON OR OFF WHAT DO I NEED TO SELECT TO KEEP THIS FEATURE
if your caps light is on a light will/should show on your keyboard
hope this helps
http://download.cnet.com/%7Bvalue=http://www.download.com/numcapsscroll-indicator/3000-2072_4-10604212.html
On-screen real-time indicator showing the status of the Num, Caps and Scroll Lock buttons on the keyboard. NumCapsScroll Indicator monitors their status and indicates it in the System Tray with its icon, with a tool-tip when you mouse-over its System Tray icon, with a small On-screen Keyboard-like panel and a sound indicator. It's also an identical utility for laptops that are not supported with Num, Caps and Scroll Lock LEDs on their Keyboards.
What's new in this version: Version 7.0 is compatible with Windows 7.
Apr 06, 2011 | Computers & Internet
Printer: canon PIXMA Ip5000 inner tray problem
Then you close the tray so that it will continue printing. That is a warning that you should close the tray so that the printer will work properly.
Dec 18, 2009 | Canon PIXMA iP5000 InkJet Photo Printer
Red light on steady
If the ink light is on steady red, that means the black or color ink cartridge is nearly empty. Obtain a replacement black or color ink cartridge. To know which cartridge is out of ink, check the ink levels using EPSON Status Monitor 3 (Windows) or EPSON Status Monitor (Macintosh). If you just replaced the cartridges before you got the error light, that means that the replacement cartridge is not recognized by your printer. Please reseat cartridges. Then turn the printer on and off. The cartridges maybe bad also.
If the paper light is on steady red, try to reload 10-20 sheets of regular paper into your printer. When printing on CD/DVD, CD/DVD tray is not inserted in the printer. Insert the CD/DVD tray in the printer and press the paper button.Could also be that the printer has loaded more than one sheet of paper at a time. Load paper in the sheet feeder, and then press the paper button to resume printing. If the CD/DVD guide is open, close the CD/DVD guide, load paper and then press the paper button.
May 17, 2009 | Epson STYLUS R230 InkJet Photo Printer
Can't print
Generally means that something is either missing or not close correctly. Make sure cartridge assembly and paper tray are installed correctly and that all the doors are closed properly
Mar 19, 2009 | Samsung CLP 300 Laser Printer
Epson C46, changed coloured ink, won't print flashing red light
If the red light is flashing by itself, it means the printer thinks a cartridge is low on ink. Have a look at what the Status Monitor thinks (right click the printer Icon in the bottom Right-Hand corner and select Ink Monitor). This will show which cartridge it is. If it's the new colour cartridge, it means the cartridge is faulty (then replace it), or it is a refilled cartridge that hasn't had it's chip reset to "full". For this you will need a chip resetter, available on E-Bay very cheaply. If it's the black cartridge then replace it.
If both green and red lights are flashing, it usually means the Waste Ink Pads in your printer are saturated with ink and the waste ink "protection" counter has exceeded its limit. You can restore your printer to a working condition immediately by using the SSC utility - download from:
http://www.ssclg.com/epsone.shtml
Install it, and double click the ssc printer icon in the bottom right corner (System Tray). Choose Configuration and set your printer type (C4x), then close the ssc window. Now right click the ssc icon in the sytem tray and choose Protection Counter. You should see that the current count is above the limit; then choose reset to set it to zero. You will need to fib about having changed the waste ink pads! Turn the printer off then back on again. This will stop the lights flashing and restore normal operation.
However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. This requires the disassembly of the printer.
If you decide to have a go at replacing the ink pads yourself, report back and I will provide further help. It is a pretty simple job once someone explains how to get the case apart!
Mar 11, 2009 | Epson Stylus C46 InkJet Printer
HAVING PROBLEMS WITH MY LAPTOP TO GO WIRELESS...!!!!! keeps telling my about connections iv'e talked with my internet provider and they said everything is working on their end and with my...
try right clicking on the monitor icon with the red cross on in your system tray, and select connect to network, choose your wireless network and enter your password to gain access.
I hope this helps
Nov 25, 2008 | Belkin Computers & Internet
Need to change my ip address
there will will be a network status icon in the system tray
Click on the icon bordered in red and a window will be opened showing the status of the connection.
Click on the properties button and a screen showing you the properties of the network connection will be opened.
Under the general tab, there will be an option called , Internet Protocol (TCP/IP). Click on it and select properties. Now u can enter the required IP address.
all the best
Oct 06, 2008 | Computers & Internet
How to display battery status on Aspire One
Go to Start, Settings, Control Pane, Power Options.
Under the "Advanced" tab, check the box that says "Always show icon on the taskbar". Click "Apply, then "Ok", and close control panel.
Look at your taskbar/system tray (by your clock) ...you should now have the battery status meter.
Hope this helps - remember to rate!
Oct 02, 2008 | Acer Computers & Internet
Maxstor shared Storage II 500GB
Try mapping that drive as a network share under windows XP. This is done from "MY Computer" Map network drive. The set up your backups to back up the network drive you have created. If that does not do it then there is a contention between vista and xp as to the owner of the drive. Making the drive a mapped network drive should resolve this as neither should have ownership. Thats my best quess without knowing in detail your network setup.
Jun 27, 2007 | Maxtor Shared Storage II (S01R320) Hard...
210 people viewed this question
k24674
jasbo
jasbo
