Question about Panasonic PT-AX100U-EC DLP Projector
Shutting down after 2 min
Dear Sirs
I have recently replaced my projector's lamp after 1900 hours. I use my projector as a TV, so the lamp laster abou10 months.
I have followed the manual exactly and now my projector shuts off after 2 min (as on end of lamp life mode). If I switch of the mains for 10 sec and power up again, the projector is back to normal.
What did I do wrong? Should I repeat the proces? Is there a munual rest butten I shoul push?
Regards
Jaco van Jaarsveld
Dubai
  • 3 more comments
  • Anonymous May 16, 2008
    I have the exact same problem, where I have replaced the lamp and it keeps turning off after a minute of being on. I have reset the timer, but the problem persists. What else could be causing this.
  • bobbychetal Sep 01, 2008
    I have the same problem, but I have used my projector for less than 200 (two hundred)hrs. I have not changed the bulb or anything and the lamp timer in the user settings shows the lamp hours as 195. What else should I try??
    Bobby Chetal
    New Delhi, India
  • ms_catherine Sep 25, 2008
    i have the same problem, I reset the lamp run time, and clean the filter. still shuts off. Help!
  • Anonymous Oct 13, 2008
    Same problem.  Lamp runtime 1100 hours, happens randomly.  Starting to happen more and more often, and it's getting annoying..
  • fourml8r May 01, 2009
    same problem.
    http://www.avsforum.com/avs-vb/showthrea...
    this thread tells you how to fix it simply.
  • 3 Answers
Http://www.avsforum.com/avs-vb/showthread.php?t=762444&page=23
this thread tells you how to fix the problem simply.
Posted on May 01, 2009
Call panasonic-- they have extended the warranty on this issue up to 18 months, as it is a known problem with the sealant for the iris. If the sealant is not moving, the iris sticks and the projector goes into lockdown. Call this number and they will take care of your problem: 1-800-211-PANA (7262)
Posted on Oct 24, 2008
THE PROBLEM IS WITH THE DYNAMIC IRIS WHICH IS DEFECTIVE. IF YOU GO TO THE SELF CHECK MENU THE IRIS IS DISPLAYED IN RED. THE IRIS HAS TO BE EITHER REPLACED OR UPGRADED TO AN IRIS OF MODEL 200. THE PROJECTOR WILL RUN FOR A FEW HOURS MORE IF THE DYNAMIC IRIS SETTING IS SWITCHED OFF
There is a reported problem with the firmware. Panasonic repair center can fix, (i think for free).
Posted on Oct 06, 2008
  • 563 Answers
Hi Jaco
You have to reset the lamp timer when you replace a light bulb on your Projector.
This can be done by going into the Menu and then go to either User1 or 2 ( you'll see a lot of the Projector's info on it ) Go to the lamp time and reset it.
Should do the trick !
Posted on Apr 15, 2008
I just got a new bulb for my projector. it was fitted as per the instructions, and looked undamaged on delivery, but after about 10 min of viewing, the hight temp alarm sounds and the projector shuts...
hi,
Did you rest the lamp hour after replacing the lamp. It is recommended the you have to reset the lamp hour after replacing the lamp. For resetting the lamp hour do the following.
1. Power ON the projector
2. Press the Menu button
3. Select OPTIONS
4. In OPTION menu select Lamp Reset and press the enter button.
(If the lamp hour counter is at the heights level then the projector will turn OFF after some time.)
ok
Apr 28, 2011 | Optoma EP1690 DLP Projector
We have recently fitted a new lamp. I followed the instructions "replacing the lamp uni" then the "resetting the Lamp Runtime" instructions. It worked perfectly for 19minutes, then the lamp turned off,...
I think thelamp is running hot and shutting off due to the thermal cut off. So try to cool the system with a forced fan cooling and see if the projecctor runs for more time. Also see if the filters have choked and is not ventillating to the lamp resulting in the heat buildup. I sincerely hope this could be the fault as in cold condition it had worked longer.I hope this helps. Good day
Aug 13, 2010 | Panasonic PT-AE100 Multimedia Projector
After just recently replacing the bulb I am
Here is proceudre to reset lamp timer in your TV..
While pressing the VOL Down button on the projection display, hold down the PIP or SPLIT button on the remote control at same time for more than 5 seconds.
When reset procedure is complete, the screen message ' lamp time was reset to 0' will appear.
Hope this info will help you.
Thanks.
Nov 18, 2009 | Panasonic TY-LA1000 Projector Lamp for...
My tv plays about 1-1/2 hours then shuts down
YOU WILL NEED TO REPLACE YOUR PROJECTOR LAMP #BP96-01472A AND THIS SHOULD RESOLVE YOUR ISSUE.
HOPE THIS HELPS
Jul 07, 2009 | Samsung HL-S5087W DLP TV
Panasonic projector keeps shutting off
http://www.youtube.com/watch?v=6jGwB05_gdk
5 minute fix guaranteed
worked for me
Apr 05, 2009 | Panasonic PT-AX100U-EC DLP Projector
Mitsubishi HC900 Projector shuts down after 5 minutes.
You have 1 of 2 possible problems.
(1) You need a new lamp.
(2) You have an overheating problem.
Just a quick couple of notes about your projector. It is a DLP projector (not LCD) and as such the machine as no air filters to clean. It does have air intake and air exhaust grilles, but no air filters to clean. This next part comes directly from the owner' manual for your projector:
When the lamp operation time exceeds 2000 hours*1 *2, the projector automatically shuts off and can’t be used until the lamp is replaced and the lamp operation time is reset.
Your machine is designed to give visual warning messages at 1500 hours used, and 1900 hours used. Did you see any visual warning about lamp life over the past few months?
If you were experiencing an overheating problem, a "TEMPERATURE!!" message would flash up on the screen just before the unit shuts down. If there is no warning, you don't have a heat problem.
If you have a replacement lamp available, install it and reset the lmap hours according to your user manual. If you don't have the manual, google it on the web (it available).
Apr 01, 2009 | Mitsubishi HC900 Multimedia Projector
Projector shuts off sporadically
need to replace the lamp. i could have diminished not as much to frequent on and offs, but excessive dust. it's heating up too much and shutting down.
May 31, 2008 | Sharp XR-10X Multimedia Projector
My projector keep shutting down
After replace the lamp. Please reset the lamp hours and clean the filter. It should work.
Apr 07, 2008 | Office Equipment & Supplies
Panasonic PT-AX100U-EC DLP Projector Logo
927 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
