Question about Fuji FinePix Z1 Digital Camera
Zoom error and intermittent flash out of sync
My little one's Z1 came up with "Zoom error" when she turned it on. I "cured" it by manuallly winding the zoom motor out of limit and putting it back together. It did it again (I don't know how many times) and she found that a gentle tap on the table tended to sort it. What's going on? Is it just a grubby limit switch, or do I have to go deeper?
This was some time ago. Now it has developed a habit of randomly flashing out of sync, resulting in a very dark picture, so she has to retake it (sometimes a bit difficult if the moment has gone). How is the flash sync done? is this again mechanical, am I looking for a pair of contacts? or is it done in software?
I found a tiny 2 blade shutter/iris looking thing, in the middle of the lens assembly, driven by a stepper motor!! What is it? What does it do? With the inertia of the weight of the rotor and so on, it can't be very fast...can it??...
If there are software problems, do you have any firmware upgrades or whatever to sort them, and if so, how do I go about getting/installing them?
Can you help at all please?
Many thanks,
Bob. (mcnab "at"
  • 6,831 Answers
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Posted on Nov 22, 2010
Intermittent dark images
Sounds like they are a little out of sync. Try adjusting the timer settings.
May 06, 2012 | Nikon Speedlight SB-800 TTL Flash
Battery doesn't fully charge. Over three years. Do I need a new battery and if so how much are they?
I have the same problem, maybe. My Z1 worked fine for maybe 4 years, it was a rebuilt one with original battery. After much use, videos etc, I replaced the battery and even bought a charger. This has not really helped. When I slide it open I get zoom error. When I press the button to review and set format it goes off while I am in the process of setting the date. What to do? Jan 12, 2011
Nov 29, 2010 | Fuji FinePix Z1 Digital Camera
Ref: xbox 360, ring of light gone red, whats the cause/remedy?
First you need to determine the secondary error code. You can do this buy holding down the sync button while the RROD is flashing slowly. While holding the sync button press the eject button 4 times. It will give you a certain number of lights blinking quickly with each press of the eject button. The 4 digit code you receive will provide a much better way to diagnose and cure your specific error.
Dec 23, 2009 | Microsoft Video Game Consoles & Games
Zoom error
If you are in a mode such as macro of some other modes then the camera is unable to focus when the telephoto lense is extended past a certan point, mine has never told me in that way, but I am sure that that is the problem, just zoom out to the widest angle possible then in photoshop you can crop the image later.
Jul 21, 2009 | Fuji FinePix S1000FD Digital Camera
Problems with older Vivitar flash and Pentax K-100 DSLR?
That is true. Older flashes used sync voltages as high as 250V. That much extra juice can quickly fry newer cameras. You can use a Wein Safe-Sync between the camera and the flash to electrically isolate the two.
Apr 16, 2009 | Vivitar 840AF AutoFocus Zoom Electronic...
Fuji fine pix z1 error
I had the same problem and finally had the time to look at it. I was reading some other posts, when I read try the telephone trick. Leave the camera closed and kinda slam it on a hard surface. I slid the shutter open and focused and it took a pic with no problem!!!
Mar 21, 2008 | Fuji FinePix Z1 Digital Camera
Fuji Finepix Z1 Zoom Error
I saw another post in this forum were someone suggest banging it on a table a couple times, not to hard that you'd dent it but a good enough bang. Worked like a charm! I tried the trigger and slide method but while the error message went away the zoom wouldn't focus. Try banging it, it sounds bad but it worked wonders!
Mar 06, 2008 | Fuji FinePix Z1 Digital Camera
I assume you have tried removing the battery and re-inserting. If this didn't work, I suggest you give the camera a firm knock a couple of times against a hard surface such as a desk. Obviously I don't mean anything that would dent the desk or damage the camera. This worked for me with exactly the same message on a Z2.
Sep 03, 2007 | Fuji FinePix Z1 Digital Camera
Camera not working-please help
No promises but if you take a roll of film that is already light fogged etc. and load it into the camera. Let it wind as normal. Now we need to work quickly: Press the rewind button. While it is winding OPEN THE BACK. It won't rewind very long because very little film is out of the cartridge so be ready. This will fogged a bit of the film but it does seem to clear the error. You can still shoot the roll if you just skip the first few shots.
Dec 06, 2017 | Fuji Zoom Date 60 35mm Point and Shoot...
Connect an external flash
For external flash use with the C-3030 Zoom, you will need the appropriate flash cable and grip. Please use the following as a reference: Exclusive Grip FL-BK01 - used to mount external flash to the C-3030/C-3000 Bracket Cable FL-CB01 - this cable is required for the dedicated FL-40 flash PC Flash Cable FL-CB04 - this cable is required for any "other" external flash/strobe use that connects with PC sync cable
Sep 01, 2005 | Olympus C-3000 Zoom Digital Camera
Fuji FinePix Z1 Digital Camera Logo
41 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
