Question about Motorola Mobility SLVR L7 Cellular Phone
Added memory card blocks pictures from showing
Memory card has been installed for aprox. four months. with card in pics. are unavailble. card removed pics on camera will show.
  • SEXCLIPZ Apr 15, 2008
    I have the same problem. I am unable to get into my memory card info. I was takin a pic one day and it just locked up and kicked me out to my main screen. So now when I try to change storage devices to the memory card it locks up and kicks me out. I can't figure out how to erase info on the card. I've even tried to see it on the computer and I can't.
    Brigadier General:
  • 7,752 Answers
Reformat boths cards and try again.
Posted on Jun 04, 2008
My memory card is full so I can't take more pictures. I want to delete the old ones which are saved somewhere in the disk but it only shows the old pics in the camera, only when i put the memory card...
If your memeory card is a SD card then -
SD and Micro SD memory cards has a smallslide switch on the edge of the card, which write protects data on the memorycard. Slide the switch from the READ position tothe WRITE position, which is furthest away from the contacts.You can then delete the phots using your computer OR format the memory card using the camera.
Jul 15, 2011 | Computers & Internet
The 4gb Micro SD card is not working. First I formatted it with my phone then I put it in my computer and a picture on it and safely removed it from my computer and put it back into my phone. It showed the...
ok the first thing to do is find out is , is it the phone or the memory card, so try another memory card. with a bit of luck it will be the card that is unstable. if its not the try updating the the firmware on your phone but do it using the pc suite that maches your phone and backup your entire phone contacts pics etc to your computer. now dowload and install the update usually the pc suite will do this for you. i hope that helps.
Jan 12, 2011 | PNY 4GB microSD High Capacity Mobile Media...
Does anyone know how to transfer pictures from the camera to a memory card? I thought my card was in there when I took the picture, but it wasn't.
most all cameras cannot move pics from internal memory to memory card. You first have to save them to your hard drive with a usb connection. Then you can move the pics to the memory card if you have a card reader. Or... replug the camera into usb after installing the memory card. Then you can move the pics to the memory card. Note: if trying the later you have to name the pics following the same naming convention as the pics already on your memory card. otherwise, they will not show up or will replace those that already exist on the card.
Aug 09, 2010 | VistaQuest VQ-5115 Digital Camera
Camera says it has 1741 pics but only shows 14 in review.my daughter had the setting on internalmem, so how can i get to those pics kodakm753
Sounds like you have 1741 pics on the memory card and 14 on the internal memory. To get to those pics, you need to remove the memory card. Also, keeping 1741 pics on a memory card is a recipe for disaster. The pics can become corrupted over time and you will lose them. Also, that many pictures slows down your camera.
Dec 07, 2009 | Kodak Easyshare M753 Digital Camera
I installed S3000 software for Windows XP on my Windows Vista. Now it won't run. I downloaded the driver fix for Vista but something is blocking the program from running - it says: Windows 4.1 has stopped...
Sounds like a compatibility problem related to Vista.
If your pics are stored on a camera card then i recommend that you purchase a card reader/writer and pop the camera card in that to transfer the pics to the computer.
They are very cheap at around $2( £1) and you can get them anywhere from places like PC World, radio shack etc.
Regards.
Sep 08, 2009 | Fuji FinePix S3000 Digital Camera
When taking a picture it will not go to my memory card
i recently added a new memory card to my camera,i have selected auto in image storage under menu button my internal memory says full and i have deleted all memory and internal memory pic and it still says full internal memory and won`t let me take any pics,what can i do on this matter?
Apr 19, 2009 | Kodak EasyShare Z760 Digital Camera
Kodak easyshare 5300 not showing ALL pictures on my memory card
maybe the resolution of other pictures is more thyan the printer reader supports
check uninstall and install printer and try again
also make sure that the 4 readable photos Format is like the other pics
plz rate!
Feb 23, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
When viewing picture from camera question mark appear no picture
try formatting ur memory card sometimes after adding deleting pics it gets corrupted or becomes in such a format that is hard for a camera to show u , becoz sometimes u use ur memory card on card readers and then edit them there so they are unable to be read in camera try formatting the card temme if it helps
Feb 20, 2009 | Canon PowerShot A700 Digital Camera
Pictures on lg shine won't show on computer.
I think the problem might be that your phone is set to save pics you take with shine to phone instead of card. Try opening your camera, click "options", click "primary storage", then select "memory card". Take a test pic, pop the card in computer and see if it shows up. You should see a new folder choice -- "graphics". Hope that works for you!
Dec 27, 2008 | LG Shine KE970 Cellular Phone
KODAK EASYSHARE Z710 DIGITAL CAMERA
Hi Tanya
It sounds like something was corrupted when you transferred your pictures to the computer.
If you have all the pictures safely on your computer, it will be ok to reformat the memory card and then just copy and paste the pictures back to the card.
Insert the card in your card reader, go to My Computer, you should be able to see the card as a removable drive. You can click and open it just like a folder and see what is on the card.
I would also back up the pictures to an external drive or dvd so they are extra safe!
Feb 16, 2008 | Kodak EasyShare Z710 Digital Camera
Motorola Mobility SLVR L7 Cellular Phone Logo
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
