Question about Konica Minolta DiMAGE Z5 Digital Camera
Same SD card problem with Dimage Z5
Have you solved it?
  • doardo Jun 29, 2008
    Same prob:-any SD card gives the message "unable to use card".Is it faulty contacts inside the camera??
Dimage z5 will not auto focus as it should leaving non sharp pictures
Posted on Feb 05, 2011
Your Card may need to be formatted. to fix this problem:
[note- before you start, make sure that your SD Card is blank, or that the information is unimportant, because formatting your card will erase all of the information.]
1) Plug the card into your computer, if you can, in the SD slot, or use a USB - SD transformer to plug your card into a USB port.
2) After its plugged in, go to 'My Computer'.
3) Right Click on the drive its plugged it into
4) press format
5) Make sure all of the correct settings are on and start the format.
now your SD card is formatted and should work in your camera and you can continue taking pictures. YEA :^)
Posted on Jul 14, 2008
4 Suggested Answers
toto
  • 425 Answers
SOURCE: How many images can the DiMAGE Z5 save in a 16MB SD Memory Card?
Still image Image Size: 2560x1920/2048x1536/1600x1200/640x480 Economy : 18 / 26 / 37 / 142 Standard : 9 / 15 / 22 / 101 Fine : 4 / 7 / 12 / 67 Movie 640x480 Fine: 30 fps: 9 sec. / 15fps: 18 sec. 640x480 Std.: 30 fps: 14 sec. / 15 fps: 28 sec. 320x240 Std.: 30 fps: 29 sec. / 15 fps: 57 sec. *The writing speed of the memory card may prematurely end the recording of a movie clip.
Posted on Sep 13, 2005
nicknkell
  • 41 Answers
SOURCE: SD max size
I don't have any first-hand information, but you'll probably be ok as long as you stay under capacities of 2GB. The original SD specification only allowed cards up to 2GB to be compliant with the standard, so I think that pretty much every camera that has an SD slot can handle 2GB capacities.
Posted on Jan 25, 2009
  • 7 Answers
SOURCE: When inserting SD Card in to Dimage Z5 the camera
http://ca.konicaminolta.com/support/americas/digital_cameras/dimage-z/dimage-z5/compatibility/detail.html
Your card is probably not supported by the camera.
Posted on Sep 12, 2009
What is the maximum size sd card I can use? Mahalo for your assistance
This camera model is about 12 years old now and most cameras of the age had small memory cards as the camera produced relatively small image files. The camera was supplied with a 16 Mb (not Gb) SD card so I wouldn't have thought the maximum capacity would be much over 64Mb.
Check this http://www.dpreview.com/reviews/konicaminoltaz5/2
Sep 16, 2015 | Konica Minolta DiMAGE Z5 Digital Camera
I can't get rid of Error message on my Konica Minolta Z5 : SD card seems blocked, even after reformatting, because some pix may have been rotated 90 degrees ???
The Z5 can display photos that it took. However, it cannot display edited photos. Due to the way the JPEG standard is defined, a rotation of the picture constitutes editing. If you rotate it four times, or once and then undo, it still constitutes editing. If you open a picture and then save it without doing anything else, it still counts as editing. Thus, if you want to put pictures back onto the card, you'll have to use the original pictures.
The proper workflow is to download the pictures to your computer. Then, if you're going to do any work on any of these pictures, do it on copies. This way, if you totally mess up an edit, you'll still have the original.
Feb 01, 2012 | Konica Minolta DiMAGE Z5 Digital Camera
When inserting SD Card in to Dimage Z5 the camera will not read card. (''Unable to use card.) Please help.
Jul 05, 2009 | Cameras
SD max size
Jan 25, 2009 | Konica Minolta DiMAGE Z5 Digital Camera
My Konica Minolta Dimage z5 won't play back photos
What size memory card are you using? I have had this problem trying to use a a 4gb card, which apparently is not compatible with the Z5. Using a 2gb card seems to alleviate the problem.
Jan 03, 2009 | Konica Minolta DiMAGE Z5 Digital Camera
Konica Minolta Dimage Z2 camera will not read any SD card
hi there
you don't say how big the card is, my guess is its bigger than 2 gig which is the maximum allowable size for that camera.
hope this helps
beergut707
Oct 20, 2008 | Konica Minolta DiMAGE Z2 Digital Camera
Dimage z5
I have formatted the sd card and now I can se the picthures
Apr 04, 2008 | Konica Minolta DiMAGE Z5 Digital Camera
Memory card
Format the SD card. Use the menu button to find FORMAT.
Aug 21, 2007 | Konica Minolta DiMAGE Z5 Digital Camera
Sep 13, 2005 | Konica Minolta DiMAGE Z5 Digital Camera
Konica Minolta DiMAGE Z5 Digital Camera Logo
296 people viewed this question
Top Konica Minolta Cameras Experts
Greg Cann
Greg Cann
Willem.
Willem.
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
