Question about Asko 24 in. D3120 Dishwasher
Drainage Problems My ASKO D3120 doesn't drain properly leaving water in the bottom. I have had this problem before (2 yrs ago) and called the helpline who told me how to reset the machine by pressing the buttons in a particular order which fixed it immediately. Now when I call them they claim this can't be done and they will have to send a technician. Sounds like a money making exercise to me. Does anyone know how to reset through the programming function? Next time I'll write it down and wont have the problem with the so called helpline!
Turn off the dishwasher by pressing the on/off switch on the top left of the dishwasher. Wait 5 seconds. Press and hold the program button on the right side of the front of the dishwasher. As you are holding the program button, press the on/off switch again. Release both. This should reset the machine
Posted on Jul 25, 2008
Dishwasher stops mid cycle
Do the foll. things:
1)Check if there is water on the bottom pan. Remove the panel down on the backside of the machine and look. If it's water there, wipe it well up with a towel or so. 2)if ur dishwasher doesn't starts then: First, check the usual suspects: Make sure the circuit breaker isn’t tripped and that the wires at dishwasher’s power junction box aren’t burnt. If all that checks out, then go right to the control panel area.
Asko dishwashers have had problems with the wiring in the control panel area burning or melting– very messy. While your problem may not be as dramatic as that, the problem may still be visible. You may find burnt or discolored wire terminals or the spades on the start button switch may be burnt– anything burnt or discolored has to be replaced. You can buy any replacement parts you need right here.
Goodluck,
Dont forget to rate me as fixya..
Jan 29, 2008 | Asko 24 in. D3120 Dishwasher
Water will not drain out but the water pump keeps running even when the door is openned or closed.
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Jun 16, 2011 | Asko 24 in. D3120 Dishwasher
DO NOT DRAIN
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Water will not drain out
heatman101
Oct 30, 2010 | Asko 24 in. D3120 Dishwasher
GE Externa Tritan XL (7 yrs old): Standing dirty water
Hello, there isnt much that you can do, there could be a number of problems. It could be a slight blockage somewhere from your drainage hoses to your pump. It could also not be spinning properly. If you want to drain the rest of the water out you will need to get your drainage hose and lay it flat on the floor to a drain, this will stop things getting smelly. You just may have to get a repair man in, I hope this helps.
Nov 07, 2009 | GE 24 in. Profile PDW7800 Built-in...
Asko D3120 I have resolved the problem of pum always running by tilting the dishwasher but now I have a new problem of the pump not draining the water in the bottom of the dishwasher. I thought it was...
In the bottom where the filter are, you can see a yellow 'thing'. Remove this and stick one finger in an try to rotate the pump wing. Try to remove particals that is blocking the pump.
Or there is something in the drain hose. Try to drain the machine by holding the drain hose over bucket. If it drain here, then the problem is under the sink.
Jul 17, 2009 | Asko 24 in. D3120 Dishwasher
I have a asko d3120 and it's only draining water and will not start or stop draining :( what can i do?
check the float switch under the pan .. you could have water in the pan or float stuck in the up postion...
Hope it helps if NOT let me know more about your problem... and I will help
Jun 08, 2009 | Asko 24 in. D3120 Dishwasher
Asko d3120 flashing coffee cup
I had to slide the dishwasher forward (undercounter installation)and tip it forward as far as possible. Water leaks onto floor, but then the internal controller seems to reset and the ASKO now works normally again. What kind of idiot would design a control module that does not incorporate a power-off interlock? FAIL FAIL FAIL - Bad, ASKO, Bad. Go to your room.
Nov 18, 2008 | Asko 24 in. D3120 Dishwasher
ASKO Overfill protection tripped
Remove the backpanel of the machine, and look if there is water at the bottom of the machine. If so, use a towel or so to dry up the water. This should solve the prob.
Dec 31, 2007 | Asko 24 in. D3120 Dishwasher
Ok, heres what you have to do. Remove the lower toe kick and then remove the panel behind that to gain entry to the lower portion of the dishwasher wher the guts are. You will also have to pull out the little brackets that hold the toe kick and all the screws will be t-15 or t-20 torx (little star shaped bits) Once you have all the panels out of the way, you will find water in the bottom of the tray there tripping the overflow switch. Remove the water with a wet vac or towel or something and the drain pump will stop running. If you can't or don't want to do all this, then just let the dishwasher sit for a few days or so and eventually the water will just evaporate and everything will work normally. Hope This Helps!
Nov 24, 2006 | Asko 24 in. D3112 Free-Standing Dishwasher
Asko 24 in. D3120 Dishwasher Logo
775 people viewed this question
Top Asko Dishwashers Experts
Owen Barnes
John Tripp
John Tripp
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
