Question about Smeg S1100MFX5 Electric Single Oven
I have a Smeg oven SA708, but all of the symbols on the front of the oven (functions / temperatures) have been wiped off by a previous tennant. Just after a picture or diagram of the front of the oven so I can work out what the symbols are. Thanks! Michelle
  • Anonymous Jun 01, 2008
    I have exactly the same problem. Searched Google for images, but found nothing at a resolution that works.
    Giles
  • Julie Sowry
    Julie Sowry Mar 06, 2014
    The best solution is to go to ovenlettering.com
I have a Smeg Double Oven DO4SS-5 that I need to remove the control panel on
it. I've removed the 2 bottom screws but is still reluctant to come off. Help please
Posted on Oct 23, 2012
  • Phill Otum Nov 06, 2013
    theres a total of 8 little screws you have to pull out the bottom two when open the oven door, then u have to pull the whole oven out of the housing and and you will see the other screws you need to remove two behind two on top then you see the rest. hope this helps
We had the same problem with our Smeg SA708 oven, I found a website that sell transparent stickers that stuck on the panel. Now my wife can cook again.
We found it here: http://www.stoveconnection.com.au/shop/index.php/sa708xset.html
I ordered one day and it arrived the next, very very impressed.
Posted on Aug 27, 2012
    New Friend:
Someone may stumble over this thread again with the same problem. I have found someone who has a solution to this issue. I have just used these transfers myself and they are fabulous.
www.ovenlettering.co.uk
Its really simple and I am thrilled with the results.
Posted on Aug 24, 2015
    Scholar:
    New Friend:
  • 48 Answers
For Manuals try:
http://www.smeguk.com/user-manuals/ Note: this is in the UK.
For Smeg parts in the US (Scottsdale, AZ) find the Service Center info if you have any problems by clicking on the "Parts" column. (877) 913-8999.
Posted on Nov 23, 2012
Smeg sa708 where do I find the fault code
what country are you in and why are you looking for a fault code if you cant find it.
Dec 12, 2017 | Smeg Ovens
SMEG SC399X oven.I have accidently switched on the demo mode when leaning on the buttons. we can't turn it back on. we have tried the bell & holding down the - and + buttons
Hi,you have have probbably done this already but have you tryed unpluging it at the mains,sorry if you have already done this,all the best.
Oct 19, 2015 | Smeg Ovens
I can hear a zapping noise.the front green display is not lit.
Most of the time a zapping or crackling sound is a bad electrical connection. I would check the connections were the power from the source is connected to the oven.
Aug 18, 2015 | Smeg Ovens
Smeg FU65-5 Oven temperature & timer & function knob lights not turning on and oven does not heat up but the fan comes on.
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Dec 02, 2012 | Smeg 24 in 60 cm Stainless Steel Electric...
The house I've just bought has a Smeg 60 cm wall oven installed. Possibly 4-5 yrs old. I can't get it to work. An orange light comes on on the door panel when the temp control is turned on. Light goes...
Most of these ovens have two fans. A fan forced fan in the oven and a cavity extractor fan inside the cavity of the unit between the outer skin and the oven wall. The cavity fan blows hot cavity air out the front of the unit so it remains cool. If the orange indicator light is coming on this would normally be the oven element thermostat. Leave it on and see if it gets hot. If the light goes off when you select the function switch it means you are turning it off the oven function. Your interior oven light may be blown.
Hope this helps.
Feb 07, 2011 | Smeg SE399X/5 Stainless Steel Electric...
Don't know what the symbols mean
Here is a link for the manual. Page 8 describes what the functions are.
http://www.smegtech.com/site/smeg/pdf_libretti/914773713-GB.pdf
Sep 30, 2009 | Ovens
Symbols have rubbed off for the Smeg SA708 oven
I Have The Same Problem Have You Managed To Work Yours Out??
Aug 31, 2009 | Smeg S1100MFX5 Electric Single Oven
SMEG SA708 oven's symbols have rubbed off.
The oven symbols have rubbed off my electrolux oven. It's not even 3 years old. Please can you help?
Jul 26, 2009 | Smeg S1100MFX5 Electric Single Oven
SMEG A21X-5 Freestanding Cooker: Main oven has smoke/fumes everytime its used!
usual cause of fumes is if the grill is in the oven, when for example a roast is done, fat spits onto the grill element and the circular element and smokes. if you leave it on, the smoke will clear. some ovens have a fat guard which clips over the grill in the centre of the back panel to prevent this.
to clean glass, just use scouring pads - glass is virtually impossible to scratch
Oct 01, 2008 | Smeg Ovens
Smeg S1100MFX5 Electric Single Oven Logo
3,036 people viewed this question
Top Smeg Ovens Experts
ashburton
Hjalmer Lamminen
Hjalmer Lamminen
Jason Harris
Jason Harris
Are you a Smeg Oven Expert? Answer questions, earn points and help others
