Question about Sony Cyber-Shot DSC-F717 Digital Camera
Flash doesn't work
I have Sony DSC-F717 camera, few months ago flash stopped working but camera still works. When i take a picture flash doesn't opens, if i open it manually, it still doesn't work.
What may cause the problem?
  • angie ortega Feb 18, 2012
    hi,
    not sure if you still have this problem but i just figured what mine was i went to set up and on camera 2 changed the hot shoe to off.
    hope this helped.
hope this helped.
Posted on Feb 18, 2012
    Novelist:
    Champion:
  • 214 Answers
The fault may be a simple setting that may have been changed, have you checked your Manual to see if you can disable the flash? Is the flash disabled?
If no, take it to a Camera Repair shop (can be sent through any Camera Retailer) and get a quote to fix it, then decide whether it is economical to fix or better to buy another camera.
Note: this is still a "good" camera for it's features, so don't rush out and buy another camera unless you really want to.
Good luck.
Posted on Apr 13, 2008
Built in flash on Sony DSC-F717 will not open up. Have reset and checked all settings.
BAD battery !!The high quality Rechargeable Sony Cyber-shot DSC-F717 Battery [Non-OEM], It can provide extended power for your Sony Cyber-shot DSC-F717 digital camera, this battery is made specifically for your digital camera and to meet or exceed the original manufacturer specifications, we will ensure optimum performance saving you time and money.
Sep 04, 2011 | Sony Cyber-Shot DSC-F717 Digital Camera
Defective CCD - Sony DSC F717 Digital Camera
yes sony chang the ccd free of cost all over the world
Feb 04, 2010 | Sony Cyber-Shot DSC-F717 Digital Camera
How do i use the flash on the Sony Cyber-Shot
on many sony models such as the dsc f707 and f717 and probably on your model as well ... sony uses a special flash that actually flashes twice .. it does it so fast that it looks like one flash .. the first flash sets up the metering.. the second takes the picture .. so if you try to use a standard flash you will get a dark image since they only flash once .. so you have to use a special flash attachment that is capable of double flashing .. sony, of course, makes them (HVL-F1000) and some outside suppliers as well .. sony calls it "intelligent flash"
here is a low cost "auto slave" flash for your camera:
http://www.amazon.com/Cybershot-DSC-F505V-Complimentary-Super-Deal/dp/B002LCTXG2
you dont have to hook this one up .. it uses the normal camera flash to trigger itself .. so you can move it around to get lighting effects or mount it on the camera to augment the normal flash
if you just want to use the internal flash (good to 8 feet) then here is some info ....
http://www.steves-digicams.com/f505v_pg2.html
Jan 19, 2010 | Sony Cyber-Shot DSC-F505V Digital Camera
Flash stopped working on Sony Cybershot DSC-H10
What a coincidence. Even my camera is 14 months old & I too have exactly similar problem.
Can some one throw some light on this pls??
Oct 17, 2009 | Sony Cyber-shot DSC-H10/B Digital Camera
Flash is not working
how repaire blitz camera samsung s750, becouse i'm counfiusing..
helft me me please.
Sep 15, 2009 | Sony Cyber-shot DSC-S750 Digital Camera
I bought a Sony DSC t700 approximately 6 months
If the built-in flash does not function, then the camera may be set to Auto and will only flash when taking pictures in poorly illuminated environments.
To set the camera to the Forced flash setting so it will flash regardless of the surrounding brightness, press the UP ARROW on the control button until a lightning bolt icon appears on the LCD screen.
If the Forced flash setting is already enabled and the flash is still not working, then the issue may be due to another camera setting. Even if the Forced flash setting is enabled, the flash will still not work in the following circumstances:
When shooting MPEG movies
When set to the Twilight mode
If an external flash is connected
If in the Burst or Multi Burst mode
Please touch the MENU option on the screen of the Camera.
Then, select the REC MODE under the MENU.
Then, select NORMAL under the REC MODE.
If you're not able to select the NORMAL under the REC MODE, try Initializing the Camera.
First, please touch the HOME on the LCD screen of the Camera.
Then, select the SETTINGS in the HOME menu.
Then, select the MAIN SETTINGS under the SETTINGS.
Then, select the Initialize under the MAIN SETTINGS.
If the issue still persists after performing the troubleshooting steps provided above service of the Camera is required.
It's required to physically examine the Camera to determine the exact issue at the service center.
Jun 16, 2009 | Sony Cyber-Shot DSC-S40 Digital Camera
I have a sony DSC-F717, and when i take pictues, the white colors on the image come out pink and other types the picture has like a green shadow over the picture.
Symptoms shows its start-up of CCD Imager problem in DSC-F717 and in few days, CCD Imager will not give picture data to camera circuit. CCD Imager is part which converts image in electronic signal and that signal / data goes to camera circuit for further process.
Sony will repair CCD Imager problem in DSC-F717 free of cost. Check Sony CCD Imager Support for details.
Jan 06, 2009 | Sony Cyber-Shot DSC-F717 Digital Camera
Built-In Flash Not Working
Hi, I am certainly not an expert, however, I was having problems with that also. In addition, my viewfinder was almost black & white with a greenish tinge.
Come to find out there is a reset button inside where the battery is. You might try taking the battery out and leaving it out for 5 min. or so and see if this works. It fixed mine but not the screen. Then I tried the reset and that did not work. Then I took the battery out and then it worked!
When you reset the camera, you will have to re-enter your setting, ei, dates, etc.
Hope this helps.
Claudia
Sep 01, 2008 | Sony Cyber-Shot DSC-F717 Digital Camera
Flash
i think the firmware is corrupted ..... you must install new firmware ....
just visit the nearby showroom or technician he will install the new firmware ..........
for installing firmware it may costs some 300 to 400 bugs ....
how ever there may be other problems too may be the battery is dead just change battery and check....
check whether it is detecting in pc or not..........
Feb 11, 2008 | Cameras
Sony cyber-shot dsc-w55 flash doesnt work
hi
the flash doesnt flash anymore, you may need to replace th bulb for that. the yellow light means its a warning that the bulb is wor out.
hope this helps
Jan 22, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Sony Cyber-Shot DSC-F717 Digital Camera Logo
102 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
