Question about Kyocera Switchback KX21 Cellular Phone
Switchback doesn't charge
I started having problems with the charging of the phone when I would plug the charger into the phone I would wiggle the cord and have to hold it in place not letting it move or it would loose the connection to the phone then it just didn't work at all so I got a new charger but the phone still didn't charge. When I looked into the place the charger plugs into the phone it looks as if one of the little copper pieces may be missing but I'm not sure. I tried to call virgin mobile but they were no help at all. I can't return the phone and would like to be able to use it again. Do you know what I can do? Maybe a place that I can take it to get it fixed? Please if you have any suggestions I will gladly accept them Thank you very much
  • Anonymous Apr 18, 2008
    I just recently had the same issue. All night long it would make the charging noise then the uncharge noise. I never realized that the phone was not charging. I had to put tape on the cord to hold it in place so that it could charge. I took the phone to the Metro store and they had no clue. So I bought a new charger. It worked fine in the store but as soon as I got it home and plugged it in for a while it still wouldn't fully charge. I have had this phone for over a year and have had no problems with it at all. Is there some sort of recall on this type of phone.
  • mekmek Apr 30, 2008
    can't get my phone to charge
  • 36 Answers
I suggest you buy a new battery, if that dosent work, send it back to Virgin Mobile for repair
Posted on Apr 24, 2008
My Nokia E73 won't charge
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Sep 15, 2012 | Nokia E73 Mode Cell Phone
Wont charge
First Option:
Second Option:
Sep 09, 2012 | ZTE Avail Bluetooth Music 3G GPS Android...
Wont charge
First Option:
Second Option:
Sep 09, 2012 | AT&T Avail
AT&T Impulse 4g says phone is charging when it is not plugged in. Will not charge when plugged in!
First Option:
Second Option:
Jul 26, 2012 | Huawei Impulse 4G
Phone says its charging when plugged in but battery doesn't charge
Hello and Welcome to FixYa!
Well, it seems like either bad charging connection. Look, sometimes, it happen, that as soon as you plug in the charger, the charging indication starts showing that the device is under charging mode, but in real its not. You can say, that the charging animation showing on the screen is fake. Secondly, it could be due to bad charging IC in worst case, or can be due to weak battery (in most cases), And to rectify the problem, first you need to try charging the battery with some other OEM charger, Secondly do make sure that there is no carbon deposition on the battery terminals. If the problem still persists, then either the charging IC or the battery is the bottle neck of the trouble. Hope, now you get a wider picture on how to deal with the scenario.
Have a nice day,
Concerned.
Aug 12, 2011 | Samsung Jet S8000 Cell Phone
Ambiedabambie@aol.commy phone won't charge
Charger connector to phone worn out, wiggle it around to see if it starts charging.
Not plugged into a live outlet.
Charger broken, replace.
Phone battery failed, replace.
Call or visit your carrier and ask for help.
Jun 16, 2011 | Cell Phones
Cell won't charge even with a new battery
Try to use or buy universal charger. Get your battery and charge it to universal charger. so that you can use your phone. This is the easy way so you can use your phone.
Jan 25, 2011 | Cell Phones
Env help plz
The reason the phone won't charge is because the internal power port pins are broken off of their solder joints to the main board inside the phone. Wiggling it helps at first because the pins can still touch their connection points but after a short time that will cease to help. Google "cell phone repair". It usually cost around $50 to get it fixed with a new power port installed. Turn-around is usually 2-3 days.
Mar 05, 2008 | LG enV VX9900 Cellular Phone
STROBE WON'T CHARGE
you gotta go buy a new charger,or see if your company will replace it.The chargers for the strobe are garbage
Oct 19, 2007 | Kyocera Switchback KX21 Cellular Phone
Kyocera Switchback KX21 Cellular Phone Logo
74 people viewed this question
Top Kyocera Cell Phones Experts
Computer Repairing
Computer Repairing
DROPNDEAL
DROPNDEAL
Are you a Kyocera Cell Phone Expert? Answer questions, earn points and help others
