Actiontec GT704WG Wireless Router (gs583ad3-01) Logo
Posted on Jun 15, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Red power light on our 3-year-old Actiontec router
The power light on our 3-year-old Actiontec GT704WG router/gateway suddenly turned solid red rather than green a few days ago. Verizon, our DSL ISP, simply said that it "went bad" and of course tried to sell us a replacement. We have temporarily borrowed something from a friend to use until we can decide what we want to buy. But I hate to spend $100 right now if there is any chance that ours is salvageable. I have seen other people with similar problems post them online, but have yet to see a clear resoluton. Can anyone help?
Anonymous
Level 2:
Novelist:
  • Expert 116 Answers
  • Posted on Jun 16, 2010
Anonymous
Expert
Level 2:
Novelist:
Answers
116
Questions
0
Helped
27889
Points
244
If the power light is red, it means that the router is already defective.
You can still try to reset the router by pressing the reset button for 10 seconds then power cycle it.
If the power light is still red then you will really need to replace your router.
I upgraded the hard drive ram and OS on a 3 year old macbook core 2 duo. Now it won't connect to my wireless network. It will connect to wireless network at the local coffee shop. I have tried rebooting...
All you need to correct is entering in the WEP key for the wireless network- you will connect, but will be unable to browse wirelessly otherwise. The WEP key is found on the bottom of the actiontec- unless you changed it to something else- at which point you would need to log into the modem to find out your WEP key.(192.168.1.1 on a working computer in internet explorer/safari/firefox, un/pw admin, password or admin, admin; wireless settings)
I’m happy to help further over the phone at https://www.6ya.com/expert/susan_42b401e0b1603d8a
My actiontec gt704wg wont work
1. Check the light status of the dsl or cable light
(solid).
2. Go through the basic setup and see if you have the correct settings.
Actiontec Gt704WG wireless problem
fist try to enter modem config site at 192.168.1.1
admin user: admin
admin pws: password
wireless setup
check if wireless is on
check chanel
las step
try this with ips suport is you reset mdoem it returns to factory settings
try to reset it with a paper clip or pen hold it for 20 seconds
1helpful
Power light is red
Power light being RED indicates that the Router has gone bad.
Try to push and hold the reset button for a minute and check if it works.
Else time to change the router
When power switch is turned on the Power light is rapidly flashing & the 4 Ethernet lights are flashing. The box is Actiontec GT704wg
I do not have a solution to the problem. However, I am having the same problem. This morning the Actiontec GT704WG power and ethernet lights were rapidly flashing. The modem was non-functional. I could not even connect to the modem through the browser to see if I could find a problem.
The problem lasted a couple of hours. Then all of a sudden the modem started working again. I won't be able to tell if the problem recurs until I restart the modem. And if the problem does occur again, I won't be able to connect to the internet.
2answers
Actiontec (GT704WG) Router wireless access point problem
first of all try to turn the router of, wait for atleast 5 mins and then turn it on, if it still doesnt work,
click on start on the bottom left of ur screen
click on run
type cmd and click on ok
on the black screen type ipconfig
look for ethernet adapter local area connection
take down the default gateway written ther it is usually, 192.168.1.1
open internet explorer, type these no.s on the address bar
it will ask for a username and password, if you havnt changed it
it will be
username:- admin
password:- password
then click on wireless setup and c if wireless is turned on or off, turn it on if its off and then click on apply
if its on already, turn it off and turn it on again
check if this works. else we will have to reset the router but then u will loose all the settings on it done by your isp (if any)
Power led solid red, internet led solid green
This is a sin of a bad unit already, first thin that you can try here is to reset the router by pressing the reset button of the device for 30 seconds , but after that and still the same light better contact your device manufacturer...
1helpful
After several years of service, now my Actiontec
electronics like these usually have a reset button behind them, try it. If not, it could be a problem of age, since staying on 24/7 for years really wears electronics out.
3answers
Power Light Is Red, Internet Light Is Green, Other Lights Off
Check cable connections.
Try unplugging router from power for five minutes.
If that does not work call Internet Service provider to check if there is a problem with their server.
Actiontec wireless router
This is a Wireless Gateway not a router. Although the Actiontec website says that it uses NAT firewall like a router would.
If you do not get any green lights this usually means the wireless gateway is broken. Try plugging it into power but not the modem. Wait a few seconds. Are there any green lights?
If so, then the gateway is not configured correctly to work with your modem. You may have a smart modem. Call your ISP, for help.
If not, then it is probably a bad gateway. You can try to connect to the configuration web page that comes with the gateway. OR Power on the unit while holding down the Reset button for a minute. This will reset it to factory defaults.
ActionTec
Top Actiontec Computers & Internet Experts
Jesse Walters
Jesse Walters
NOEL
NOEL
Are you an Actiontec Computer and Internet Expert? Answer questions, earn points and help others
