You can also look here to find all Radio Shack user manuals
http://manualsbrain.com/en/brands/radio-shack/popular_categories
SOURCE: code and instructions foremote radio shack 15-2114
I lost my manual for my remoet cat,no, 15-2114. Could someone help me with the code for a hitachi 60" TV?
fandrewszion
SOURCE: Graphic Equalizer installation
record out from stereo to equalizer in----equalizer out to stereo pb[play back]in.
SOURCE: The settings on my Peavey Q215FX dual 15 band
Assuming that you eq is installed in your system correctly add a source like a cd of the type of music you will be putting through the system. Now starting at 0 on all frequencies adjust to your liking. Try to avoid going above 0 as much as possible because this will be adding to that particular frequency and could damage your speakers if done incorrectly.
If there is too much bass lower your sliders to the left. If there is not enough highs boost the sliders to the right up to about half way then start decreasing the bass to get the desired effect. Small increments is important.
I found that if you go to your local music store the people there are more than willing to help you.
SOURCE: Program Radio Shack 15 2142 remote for converter box
only if the converter box is using older codes that were in use when the remote was made.
SOURCE: Need code for olevia tv with radio shack remote
call radio Shack or Google the company who makes the tv.
