Question about KitchenAid 24 in. KUDS01FLSS Built-In Dishwasher
No power just finished a cycle. now no power to the control pane? what can i check
    Genius:
  • 1,073 Answers
Look in the control panel the door will need to be dissasembled there is a fuse in the control panel it is mounted to the side of the control its self is is actually cliped onto the black portion of the control check the fuse with a meter if it has blown then replace it 675796 or 675813 is the part number you will need it will be written on the old part it will say fsp???????
also check the wiring from the house to the dishwasher for a loose connection this can cause the fuse to blow
Posted on Apr 22, 2008
My Bosch dishwasher Model #SHX4APO5UC/06 wont finish the cycle and it wont drain. We have checked hoses and they are not clogged. Is it something with the control panel?
Check your motherboard for burnt contacts. Easy to remove in the door. If you able resolder and give it a try. Cheaper then a new mother board.
Aug 11, 2014 | Bosch Dishwashers
It doesn't finish the cycle and stops and flashes F02
Possible that the drain cycle is not active and so the program trips off. Check the drain for clogging , check the power to the drain from the controller during the cycle, if there is no power the program controller is faulty.
Jul 02, 2012 | Baumatic BTWM4 Front Load Washer
The screen on my plasma tv cracked. i looks very minor but when i turn on the tv the power light flashes a few times and then finally comes on but there is no picture. is there something i can do get get...
I am sorry to give you the bad news..... Your TV is finished.
Plasma sets operate by creating a plasma between two glass panes spaced very closely together. A vacuum is created between the two panes and is it backfilled with a very small amount of rare gases.
When one of the panes is cracked, air enters the space and the set is no longer capable of producing a plasma.
Feb 15, 2011 | Insignia NSPDP50 50 in. HD-Ready Plasma TV
Calypso washer stops/runs every 5 - 30 seconds in the middle of any washing cycle. No error codes. It just stops and than runs again all the time and cannot finish any washing cycle. It is 8 years...
I had the same problem. The washer control board has an intermittent failure. If you unplug power for about 30 minutes then plug it back in you will get a PF code (power failure). Ignore this code and push start again. It may run till it finishes the cycle or it may start cycling again right away. A new board costs about $180 at repairclinic.com
Aug 21, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
What is an error code E0000500-0000 for? Is it cleared with usual function, 2-8, function, err, clear, ok, power off and on? Or is it something harder to clear?
is a communication issue between the finisher controller and dc controller dc controller for the copier......
you might try unplugging the finisher from the copier and cycle the copier without the finisher then shut the copier off and try reconnecting the finisher if that doesn't fix the problem then you will need to call for service on it.
Jun 10, 2010 | Canon imageRUNNER 6000 Copier
Get error SUD and will not finish cycle
The Motor Control Unit senses a suds lock condition by analyzing the current draw on the drive motor. If "Sud" is displayed a potential Suds Lock is detected. This may signify a bad pump, an extra heavy load, excessive detergent, or excessive suds.
Possible Causes / Procedure
• If too much detergent was used:
- Run the unit through a Rinse/Spin cycle.
- Run a Normal cycle without adding any detergent.
This should clear the unit of the excess detergent.
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the drain pump, pressure switch, and Central Control Unit (CCU).
4. Check/clean drain pump filter of foreign objects.
5. Plug in washer or reconnect power.
6. Check drain pump.
7. Check the pressure switch.
8. Verify CCU operation by running a Diagnostic test or any cycle.
Sep 30, 2009 | Kenmore HE2 Plus Front Load Washer
Whirlpool control locked
Power shd be on. Press and hold "end of cycle" button for 3 seconds. Always wait for 2 minutes after the wash is over for the machine to release the door lock; an inbuilt safety device. Never force washer doors, you'll have probs.
Check out your filter too.
Feb 19, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Cycles improperly
hi there,
please let me know the make and full model # off your d/w.
thanks
Mar 26, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
PDW7880G-No power to control panel. Just stopped at the end of drain cycle
Solution Found!!
Checked for power to dishwasher. According to the manual, shutting off the breaker for more that 30 seconds resets the dishwasher. It did!!! The dishwasher works fine now. THANKS!!!
Feb 19, 2008 | GE 24 in. Profile PDW7880G Built-in...
KitchenAid 24 in. KUDS01FLSS Built-In Dishwasher Logo
179 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
