Question about IBM ThinkPad T40 2373 Notebook
Password problem I have a Toshiba 4600 old laptop. and i tried to udate my optating system and i format the drive but when i tried to reinstall the xp operating system again it asked me a password. What can i do to get rid of the password!
  • 813 Answers
Posted on Apr 13, 2008
Toshiba Satellite Pro 4600 laptop - which Keys to reinstall all windows after a formated hard drive error?
Do you have the Recovery Disks? I hope so because if you reformatted the drive you wiped out the Recovery Partition.
Apr 25, 2012 | Computers & Internet
Just put the Recovery Disk in the drive and the system should start booting from it. If not, pay close attention to the screen and when it shows you which key to hit to change the boot order or boot sequence hit it. Change the boot sequence to read from the CD drive. This is a temporary change on the boot sequence.
If you want to make a permanent change to the boot order or boot sequence you will need to hit the key that says enter Bios or System Setup and change it there.
Apr 25, 2012 | Toshiba Computers & Internet
How do you delete a failed operating system on dell 4600 using windows xp
Start to reinstall Windows XP -- one of the options will be to "format" (write 'zero' values everywhere) onto the disk-drive. Voila! EVERYTHING will be "gone".
Jun 15, 2010 | Dell Dimension 4600 PC Desktop
How do i format satellite pro 4600
Caution: formatting the will lead you to loose all the data on your computer.
To format the drive you need to boot from the cdrom/dvd drive
to boot from the cdrom/dvd drive you will need to chnage the boot sequence you will need to tap the F2 key at the toshiba logo and here you can change the boot sequence or try tapping the F12 key at the toshiba screen to enter one time boot menu here you can select the drive you want to boot from for one time only and to reinstall windows here is one helpfulll ink
http://www.windowsreinstall.com/
Further queries are welcome
Please do rate me if you find my solution helpfull
Mar 17, 2009 | Toshiba Satellite Pro 4600 Notebook
Lost installation cd
ask toshiba to send one for a nominal fee.
Nov 29, 2008 | Toshiba Satellite Pro 4600 Notebook
Can't reboot windows cd on with cd drives
If you have it available, boot to the Dell DImension Resource CD and run the diagnostics on the hard drive. From the description of you problem, you may have a failing hard drive.
Other things to check:
1. Ensure the system BIOS (F2 at boot) sees the hard drive and has the correct date and time. If the motherboard battery is failing, the time and date will not be retained when system is powered off.
2. If you are able to format the hard drive, but the windows XP installation process gives you file copy errors, then you may have a bad RAM module. If the system has 2 or more modules, take out all but 1, retry the install. If you get file copy errors again, try a different module.
3. If the Hard drive passes dieagnostics, but fails to complete a format, replace the hard drive.
Jun 01, 2008 | Dell Dimension 4600 PC Desktop
Re install 98se on new hard drive
Try a newer version, windows 2000 or xp.
Im runing windows xp on my 500mhz laptop, yours seems to be 900 witch is more than enought.
if you insist on 98se,
1st make sure your laptop starts up from cd drive from bios
to enter bios press F1 or F2 or Delete Depending on your bios.
drop me a line if you need more asisntace.
Mar 21, 2008 | Toshiba Satellite Pro 4600 Notebook
How to install XP in toshiba Satellite L45-S7423 laptop
You cannot uninstall Windows Vista, but you can reinstall your previous operating system, which then replaces Windows Vista. To reinstall your old operating system, you must have the original installation disc. Back up your programs and files, insert the installation disc into your computer, and then reinstall the old operating system. To regain the hard disk space used by Windows Vista, reformat the disk during the reinstallation process. After reinstalling your previous operating system, reinstall your programs and files.
Feb 29, 2008 | Microsoft Windows XP Professional
Rebuild
A PCMCIA CD drive will work, but only some models. Toshiba makes one, and it would be your best bet.
Dec 05, 2007 | Toshiba Portege 3490CT Notebook
IBM ThinkPad T40 2373 Notebook Logo
24 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
