Question about Coleman Propane Forced Air Heater w/Electronic Ignition (50,000-80,000 BTU)
MY COLEMAN HEATER WILL NOT COME ON
THE HEATER IN MY MOBLE HOME WILL NOT COME ON THERE IS A LIGHT THAT IS FLASHING THREE TIMES WERE FREEZING HELP PLEASE
  • Anonymous Aug 28, 2008
    I have a 1997 MDL: DGATO70BDD, S#: 970228826 propane furnace, that will not come on. If I turn the thermo., to the desired temp., all I can hear in the furnace is some sort of humming noise. There is a blend air box, that has a steady green led and a red led, that flashes just once. But according to what I have read, that flashing red light has nothing to do directly with the furnace. I have looked for another light, but nothing. So....where do I begin to check? I live in MT. and winter is just a couple of steps away. Any help in getting me in the right direction, would be greatly appreciated.
    Respectfully,
    SV
  • Anonymous Jan 21, 2009
    my aut limit keep poping off
Turn power off to heater then watch operation. if it has a combustion blower motor it will come on, then after that next you should see the hot surface / or spark ignitor try to light pilot. Also on the door panel or controler you should be able to find out what it means when the light flashes three times. If you need more help then email at smagill73@yahoo.com. If i have more info on the heater i can help you more
Posted on Apr 14, 2008
I have a coleman furnace in my mobile home & green light is flashing 3 times. I guess its a centrifugal switch is this expensive and is it something i can do myself?
I would not try to do this, in the uk you need to be properly certified to work on such items. If you make a mistake you could blow up.
Oct 17, 2015 | Coleman Heating & Cooling
Wher can purchase parts for my coleman heater #5045A751 ?
Generally sporting goods stores handle coleman parts, also some heater parts are available at mobile home parts suppliers. ....also online at coleman's website... Hope this helps...
Feb 04, 2015 | Coleman Electrical Supplies
I have a gas furnace model # 2sg13b36090p-1a green light flashing 2 times slow
Hello, Maybe this will help you some.
http://home.howstuffworks.com/how-to-repair-gas-furnaces.htm
I hope it does, Mike
Oct 26, 2011 | Coleman Propane Forced Air Heater...
Light blinks three times, when trying to start heater. it is only four seasons old. what is the fix for this.
check out the pressure switch some times you can jump them out and they light , only to find fault check flame senser is clean and check connection to board
Nov 03, 2010 | Coleman Propane Forced Air Heater...
Coleman echelon 9.T furnace will not turn on. Red light blinking
sounds like it is the pressure switch try jumping it out on some models you fool the heater in too working or see if the tubes are blocked , there should be some codes on the front panel or the fan panel
Apr 27, 2010 | Coleman Propane Forced Air Heater...
Turning heater on : combustion air switch failed to close?
This air switch proves that the inducer motor is running and moving air. If not, check to make sure that the inducer motor starts and that the flue is free of restrictions.....eg. bird nest, ice/snow, or some other critter that found a new home.
Oct 03, 2009 | Coleman Propane Forced Air Heater...
Coleman Gas Heater for home
I have a Coleman gas heater. My heat won't come on. I can here the blower comming on when I turn on the thermonstat. However no heat will come out. I went up in the attic and the heater instructed me not to light it with a flame. There was a yellow spiral kind of pipe with what look like a little yellow open and close valve. It looked like you should turn it and let the gas come in the heater from the gas line.I wasn't sure if it really was how to turn on the heater. I need some help. should I call the gas company or another company.
Nov 27, 2007 | Uniflame 200209 Open Flame Patio Heater
Heating & Cooling Logo
268 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
