drive is not ready for use; its door may be open. please check drive \device\harddisk2\dr14 and make sure that a disk is inserted and that the drive is closed.
this is the message when i connect my Lacie 320 gb to my computer. i am not able to format it and access it.
-   i have got this problem in my ipod . ipod is still not doing anything other than blink. The drive is not ready for use; its door may be open. Please check
drive\Device\Harddisk2|DR5 and make sure that a disk is inserted and
that the drive door is closed. -   Guest
Apr 16, 2008
-   I'm having the exact same problem - were you able to find a solution? if so please write back-   Guest
Apr 14, 2008
-   I'm having the same problem. I can hear things moving inside the drive, but the computer is not recognizing it. I've tried accessing it from various computers but the same result occurs each time.-   afoster_va
I appreciate the attempt from the person who tried to help, and for some reason there seems to be no...
(More)
I appreciate the attempt from the person who tried to help, and for some reason there seems to be no way to respond...maybe I wasn?t
clear enough as to the issue?I have a Mac running OS X (Tiger) and a WD My Book external hard
drive. Automatic backups had been going well but are now failing. Error
message, not enough space left on drive. A check of storage space reveals
capacity 465 Gb with just as much spaced used, so error message would make
sense. But then I deleted large files and it doesn?t register the difference
when I recheck the storage space ? in other
words, I?m removing large files that would take up room (including 90% of the
old backups) and still there?s no change, I can?t back up to the drive. Help would be appreciated, thanks in advance.
I just want to use it like a flash drive. Why is that so hard to do?
I told it not to install...
(More)
I told it not to install any of the WD SmartWare applications, but I still couldn't move files to it.
Then, the way the website read, I needed to install a firmware update, which I did. Now, I still can't move files to it. Any time I try to save something to the drive, it tells me that the drive is "read-only." How do I fix this problem?
I am speaking of a portable Western Digital MyPassport 320 GB.
can any one tell me the brief procedure of how to connect two hard disks to one computer i.e how...
(More)
can any one tell me the brief procedure of how to connect two hard disks to one computer i.e how to set a hard disk master and the other as slave..?? please help me thanks -mumeeth
