I am trying to compile a source code of vb6 name building the time tracking system. The problem is somewhere in procedure. Kindly let me know the solution. The code is
Private Sub cmdOK_Click()
Dim sngBilledTime As Single, iMinutes As Integer, iHours As Integer
Dim iResponse As Integer
If txtAmountOfTime.Text = "0.00" Then
Msgbox "Your must enter the time spent."
txtAmountOfTime.SetFocus
Exit Sub
ElseIf txtBillingRate.Text <= 0 Then
Msgbox " You must enter the Billing Rate."
txtBillingRate.SetFocus
Exit Sub
ElseIf lblBillingName.Caption = " " Then
lblBillingName.Caption = InputBox("Please enter your name:")
End If
iResponse = Msgbox("Do you want to perview the invoice?", vbYesNo, "Invoice")
If iResponse = vbNo Then
End
Else
Load frmInvoice
With frmInvoice
.lblBilledBy .Caption = frmBillingInfor.lblBillingName
.lblClient .Caption = frmBillingInfo.lstClient.Text
.lblDate .Caption = frmBillingInfo.mskDate.Text
.lblRate.Caption = Format(frmBillingInfo.txtBillingRate.Text, "Rs ####.00")
.lblWorkCategory .Caption = frmBillingInfo.cboCategory.Text
If frmBillingInfo.optByHour.Value = True Then
.lblHourOrJob.Caption = "an Hour"
iMinutes = Val(Right(Me.textAmountOfTime.Text, 2))
iHours = Left(Me.txtAmountOfTime.Text, (InStr(1, Me.txtAmountOfTime.Text, ":") - 1))
Select Case iMinutes
Case Is < 15
If iHours > 0 Then
sngBilledTime = iHours
Else
sngBilledTime = 0.5
End If
Case Is >= 15 And iMinutes <= 30
sngBilledTime = iHours + 0.5
Case Is > 15 And iMinutes <= 30
sngBilledTime = iHours + 1
End Select
.lblTotalAmount.Caption = Format(frmBillingInfo.txtBillingRate.Text * sngBilledTime, "Rs####.00")
.lblTotalTime.Caption = sngBilledTime
Else
.lblHourOrJob = "form item"
.lblTotalTime = "N/A"
.lblTotalAmount = Format(.lblRate.Caption, "Rs####/00")
End If
End With
Unload Me
frmInvoice.Show
End Sub
On compilation the message "invalid use of property" is coming and invoice window is not displayed.
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Operating Systems problems?
paper rolls out when tring to...
expressit lable for dvd rolls...
boot sequence order for dc5700...
Defragment does not work
