Hello,My fridge is freezing things:
Most times this is a bad cold control, but
there are other things to check for. Make sure the condenser fan is working and the coils
are not covered with dust. A separated heat exchanger ( small capillary tubing soldered to
the large suction line ) can separate from one another and make the fridge run too long. -
tape tubing back together. A poor working evaporator fan motor could also make the fridge
run too long and freeze - replace the fan motor. An inefficient compressor or
refrigeration system could make the fridge run too long and freeze - have a service tech
check this out. A misaligned control settings, make sure the air damper and cold control
have not been bumped and are out of normal settings. Stuck open air diffusers or
air dampers are becoming more and more common for allowing too much air to be
blown into the fresh food section and freezing things. On all frost free fridge's the
freezer temp air is blown into the fresh food
section, if you have "easy" to freeze items ( eggs, veggies in water, etc ) in
front of or under where the freezer temp air comes out, they could
freeze - store them in a different spot. Doors not closing properly making the fridge run
too long is something else to check for.
please kindly rate the solution if it's helpful.
take care.
