When i press the button to turn on my phone he come to half way to be turnned on and just show me white screen everything is lost,and he try again to turn on but it just show me white screen, when he try to turn on several times he turn off. What should i do?
Look, i need something to rebot my phone and that rebote need to delete all files on my phone, but how i can to type in some number wehen i can turn it on, the problem isn't in screen i know that.Look, i need something to rebot my phone and that rebote need to delete all files on my phone, but how i can to type in some number wehen i can turn it on, the problem isn't in screen i know that.
You can't post conmments that contain an email address.
Try to dial emergency number,,if there is an voice from operator,,it means your phone is working with white screen display,,.you have to replace LCD. but if you dial emergency number,,and there is no voice..it means you need to reprogram your phone
Try taking the battery out and pressing the power button for 30 seconds to completely discharge it, then put everything back together and try to turn it on. If that doesn't work, there's not much else that you could do unless you have warranty, or get a new phone.
my samsung shows half white screen,top half plus freezes on certain screen & shows static.Can u tell me whats wrong with it as im not sure if its a battery error or malfunction??
Here is a walk through on how to set your convergence.
A quick and easy way to try and let the TV realign the convergence try this...
1) Turn on the TV and tune to a channel and let it warm up for about a half an hour to let everything settle into its normal operating mode.
2) Press the Flash Focus button on the original TV remote. A cross pattern will show on the screen and the process is complete when the cross turns white and the TV returns to the program you were watching.
3) Do not press any other buttons until this process has completed.
If this does not adjust it enough you can adjust the convergence manually as follows:
1) Press the menu button on the original TV remote.
2) Use the arrow keys on the remote to highlight setup and press + button to select.
3) Use arrow keys to select convergence and press + button to select.
4) A pattern of white crosses appears, with a yellow [ ] around one of the crosses. Aligned crosses (which do not need adjustment) look white and have little or no red or blue showing. Crosses that are not aligned show red or blue shades beyond their edges.
5) Use the arrow keys to move the [ ] to a cross that is not aligned. ***Note: start with crosses in the middle and work outward **** *** TIP: Set the alignment while about 5 feet from TV for better results ****
6) Press the + button to select the cross and the [ ] will turn red indicating it is ready to adjust the Red convergence.
7) Use the arrow keys to move the red cross on top of the white one or at least as close as you can get it.
8) Once the Red is aligned press the + key again and the [ ] will turn blue. This indicates it is now ready to adjust the blue convergence.
9) Use the arrow keys to move the blue cross on top of the white one or at least as close as you can get it.
10) Once you have aligned the blue cross press the + button again and the [ ] should turn yellow.
11) Repeat steps 5 through 10 until all the crosses are aligned. To exit back to regular programming press the menu button on the remote.
If you are talking about the MENU that shows up on the picture regarding the ISO, FLASH, APERTURE, WHITE BALANCE and Whatnot, you need to press the up arrow or down arrow buttons on the directional keys to remove the menu on the button
but if you are talking about the MENU which you can tweak different settings you just have to do a half-press on the shutter release button which will turn off the screen.
Power off phone. Press and hold Green, * and 3 and keep them
held whilst powering on and for a few seconds after
man the code written is hard reset for n95 **** .there is a hardware problem in the cell phone you need to change the strip of ur cell phone which connect the upper and lower portion.
Make sure the phone is charged. Press the Home button and the power button at the same time for about 10 seconds then release both, now press the power button briefly, the phone should start.
Take out the battery....then put it back in. Do not try to turn on the phone yet. Next plug the phone up to charge. Wait until the charging screen appears and then power the phone. Worked for me.....good luck.
