Question about Canon PowerShot S1 IS Digital Camera
Blurred image in viewfinder
When I look through the viewfinder the image is blurred with vertical lines as if it was fax paper with drag marks on it and has a purple colour to it
  • ManojY Apr 20, 2008
    I am also facing the blurred view in view finder .Please help
  • Anonymous Apr 30, 2008
    When I look at the screen the image is blurred as if dragging through a fax. When I tried to take a photo, of course, it was the same distorted image. The camera was fine; but unused for eight months. The saved photos in the camera all appear normal.
  • Canon Master
  • 4,738 Answers
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
Posted on Apr 27, 2008
Clean the printer head, The paper has a blurred vertical lines. Looks like it it printing different blurred words in vertical column
take out the drum unit look for scratches along that vertical area, or check the fuser unit along that vertical area for any damages
Dec 10, 2013 | Brother International Brother HL-3170CDW
When scanning and copying get lines
clean the scan glass,it's usually a .5 to1 inch strip of glass that the paper runs over while it is scanned and it probably has white out or something similar on it
Nov 06, 2013 | Canon Pixma Mg6120 Wireless Inkjet Photo...
Canon powershot a470 vertical lines, white picture, blurred
The image sensor is defective. There is no quick fix other than replacing the image sensor.
May 13, 2017 | Canon PowerShot A470 Digital Camera
Viewfinder shows blurred images
First, rotate the mode selector dial to "Auto", then check to ensure that you're not in macro mode. Also make sure that your lens is clean and there are no smudge marks.
If you've done all the above, and you're still getting blurred images, this then might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check this link for more info.
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 30/30a/200a/300a/D320/400/ 450/500
Dec 19, 2009 | Canon PowerShot A80 Digital Camera
When i look through the viewfinder of my D60, the
There are 2 possibilities. The viewfinder lenses are dirty or, depending on the model, there is an adjuster, right at the viewfinder, to adjust the focus of the viewfinder. It has NOTHING to do with the picture, only the viewfinder.
Oct 18, 2009 | Cameras
Picture on viewfinder is blurred Everything in my viewfinder is blurred, even the numbers and stuff in there. The picture I take isn't blurred.
I think your camera has a diopter adjustment. If it does, it'll be located on the right side of the eyepiece. It's a small wheel with a + and -. Adjust that until the image is clear.
-or-
It's possible that it is in need of cleaning. If you plan to remove the focusing screen, be exceptionally careful not to scratch it. Has it been subjected to extreme moisture conditions?
Aug 31, 2008 | Canon EOS 400D / Rebel XTi Digital Camera...
The image is getting blurred
Hi
The camera may have moved when the picture was taken. Try steadily squeezing the button intead of a quick press.
2.Try using a tripod, this could fix the blurred images.
3. faster shutter speed will be needed if you need to hold the camera, and cannot use a tripod.
4. Main reason for the lines could be that the subject is to bright.
A vertical bar of light(red, purple) appears on the LCD monitor/ in the viewfinder This is a normal occurrence in devices containing CCDs (Digital Cameras) and does not mean a malfunction. (This red bar of light will not be recorded when shooting still photos, but it will be recorded when shooting
movies.)
Solution to the last point would be to try and switch of the flash if it is in use. Turn the ISO setting (50, 100, 200) to a lower one as well.
Hope that helps.
May 26, 2008 | Canon PowerShot Pro1 Digital Camera
Samsung Digital camcoder VP-D305i : LCD image blurred
OK IF YOUR PRERECORDER VIDEO'S PLAYBACK CORRECTLY THIS IS THE CCD AND CANON WILL FIX FOR FREE. THANKS TO SONY
Feb 19, 2008 | Canon ZR85 Mini DV Digital Camcorder
Optic viewer blurred image
Not much that you can do with that, try adjusting the small focus lever on the underside of the viewfinder, as this might fix the blurred image, your lucky that you didn't, break something on the camera.
Jan 05, 2008 | Sony Handycam CCD-TRV37 Camcorder
Blurred image
The viewfinder image should look sharp & clear, as long as the camera is turned ON. If the camera is OFF, the viewfinder image will blur. At least this is how it works on my C2000z. If your viewfinder is always blurry, I would return the camera for exchange.
Sep 07, 2005 | Olympus Camedia C-3030 Zoom Digital Camera
Canon PowerShot S1 IS Digital Camera Logo
69 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
