Question about Intel Motherboard
Dayin after i loud windows and reboot it start all over like windows was not just instaled
  • 407 Answers
Some file miss you format & setup OS now
chack your SMPS & RAM slot it clean ........
Posted on Apr 13, 2008
Nothing happens when rebooted
If you a downloading for free check a youtube tutorial if that doesn't work buy it.
Jul 10, 2013 | Empire Interactive Taito Legends
Loud high pitched squeel through speakers and will not boot-up either from my Acer 4150LMi
Run the check disk utility.
To run the check disk utility you will need a repair disc ora operating system disc. Put the disc in the cd drive and boot fromit. You want to get to the Dos Command Prompt (Black screen with whiteletters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.
May 04, 2012 | Computers & Internet
Keeps dayin wrong password
Hi davidowens19...
Try this solution to your problem.
Start your computer
1. Keep pressing "F1,F2 or F8" as the laptop computer starts.(Depending on your computer)
This will start the computer in Safe Mode.
2. When the window "Advanced Boot Options" opens, choose "Safe Mode" with arrow key and confim by pressing the Enter key, then PC enters the Safe Mode.
3. Once you are in the Safe mode Click "Administrator" on the Windows login screen.
Take note that you have set the Administrator password before, you need to input the changed password instead of leaving "Password" field blank.
4. Then click Start > Control Panel > User Accounts > Select the account that is locked and change the password.
5. Restart laptop and login into the account you just created using your new password.
Please take time to rate me thumbs up
Sep 24, 2011 | Computers & Internet
How to install windows xp sp2 by using dr-dos
1. Check your BIOS to be sure your computer will boot from a CD. Enter the BIOS setup by pressing the "Delete" or F2 or "F12" key, or as directed at the startup screen, immediately after booting. Set the first boot device to "CDROM" or "DVDROM" instead of "hard drive" if it isn't already.
2. MS-DOS command prompt
Insert the Windows XP installation CD into your CD or DVD drive and restart the computer. When prompted, choose to start from the MS-DOS command prompt with CD support. The MS-DOS command prompt will appear in a moment.
3. Start SMARTDRIVE by typing "SMARTDRV" at the DOS prompt and pressing enter. You don't have to run SMARTDRIVE, but copying the files will be much quicker if you do. The computer will display the DOS prompt again.
4. Enter "CD I386" at the DOS prompt to change to the directory where the setup program starts.
5. Enter "WINNT" at the prompt to start Windows XP setup. The installation program will copy files to your computer and then display a message requesting to reboot.
6. Press the "Enter" key to reboot. The setup program will start again and check that your hard drive format is compatible with Windows XP. If not, it will guide you through partitioning and formatting the drive and then ask you to reboot once more.
7. Press "Enter" to reboot. The computer will restart in Windows XP mode and automatically start the Windows Setup Wizard to detect your hardware and finish the installation.
Feb 21, 2011 | Computers & Internet
How to reformat
hi you should be able to reformat as part of a fresh windows installation.when you run your disc after the initial checks /and window file installation you are given a opportunity to choose a partition/usually you will select ;c;/you are then given an opportunity to delete the old window(reformat).choose the long reformat as quick is only used for new hard drives .when after reformating.windows will reboot .if your not familiar with installing a new window be aware when windows reboot to start instalation .dont touch any of the keys on your keyboard .just let it reboot .hope this helps.
Aug 29, 2010 | Microsoft Windows XP Professional
I dont know how to reboot my ASUS eee LapTop
Hi there, If you want to 'reboot' or re-install windows, then you will need to locate your windows CD, insert this into your Eee PC then re-start, then follow the prompts on screen to re-install windows.
Cheers.
Jul 09, 2010 | ASUS Eee PC 1000H Laptop
I want to upgrade my computer so I just purchased a maxtor 320 gb harddrive for my computer. I install the new harddrive and put the restore cd and choose the quick format. Computer reformat normally and...
Here are some solution that might help
Option 1 Do a fresh install, used the original Operating system CD
Option 2 Install Norton ghost 2010 or Acronis Migrate on your OLD HDD and make your new HDD as Slave then Clone your Old HDD to the new one..
i hope it help.
Jun 15, 2010 | Computers & Internet
Can't get the Latitude D600 to reboot
You will need to re-install windows, or use the windows recovery solution..
To use the recovery solution:
Insert your windows installation CD
reboot the computer
when prompted, push any button to boot from the CD
When asked if you want to install, or use the recovery console, select " install "
You will be promted again to install or use recovery, use " recovery "
Windows will delete hardware profile information, then continue to install as normal. Once completed, you should be able to use windows normally again, and you should not lose any data on the drive, nor any software installed or settings.
May 31, 2009 | Dell Latitude D600 Notebook
How to reboot my acer 4100 laptop
Reboot or reformat?
To reboot
  1. Click start
  2. click restart
  3. when system starts it has been rebooted.
To reformat,Repost with details of current OS and OS in which you will be installing.
Feb 23, 2009 | Acer TravelMate 4100 Notebook
Windows can not start
put your window disk in cd drive,reboot ,option press any key to boot from cd should apear,press any key.new options select install windows ,not repair,system will find os already installed,now select repair.
Mar 01, 2008 | Toshiba 2405-S221 Notebook
Intel Motherboard Logo
16 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
