Question about LaCie 160GB Mobile Disk USB2.0 160 GB Hard Drive
Lacie 160gb usb 2.0 not being recognised by PC USB
Has been working fine. Only 1/2 the light coming on
Does it give an error code 10?
Posted on May 01, 2009
PC doesn't recognise hard drive connected via front panel usb?
Use one of the rear USB ports. Mind you, my PC won't deal with it when connected to any IUSB port although it's fine when connected to the router. This is driving me mad...
Nov 02, 2011 | LaCie Space 2 (301515EK) 1000 GB Network...
LaCie Big Disk 500GB not showing up
1. the usb connector in the PC may have a broken board contact needs soldering or replacement.
2. there may be a broken USB cord to the external usb drive
3. the electronic controller in the USB case may not be working.
4. A new case may be needed with a new controller.
Jul 08, 2010 | LaCie Big Disk Extreme 500 GB Hard Drive
The harddrive wont power up witout the power cable attached to an extra usb port but now I keep getting a message saying USB device not recognised and when i go to the device manager it says unknown usb...
You need the power from the 2 USB ports in order for the Drive to have enough Power.
Try moving the USB Ports to another Port or Flip Flop the 2 USB Cables.
Another option is to uninstall the unknown device. Remove the USB Cables, Uninstall Shut Down, Re-Start.
NOTE: Certain Ports on your System are USB 2.0 and some are not. Try to use the 2.0 port listed in the Manual... it will be faster and may carry the Power.
Jan 07, 2010 | LaCie 160GB Little Disk USB2/FW400 160 GB...
External HD not recognizing USB ports as being Hi-speed ports
I have the same issue. I have 4 Simpletech Signature 250GB drives. They all worked fine at first. After about six months two of them started connecting at USB 1 speeds. It occurs on 4 different computers!!! The post about it being the computer assumes is wrong. How can it work fine for six months and then suddenly change. Also it occurs on different computers. I have submitted a tech support request with simpletech and will post the results.
Jun 14, 2009 | SimpleTech Signature Mini 160GB External...
Installing LaCie Mobile USB disk killed my Windows 2000 server
First, remove the usb disk, then when the computer boots up, press F8 continuously. Run the Safe Mode and try to uninstall the usb software and driver.
Jan 13, 2009 | LaCie 160GB Mobile Disk USB2.0 160 GB Hard...
I purchase a FreeAgent Go 160gb,getting started it does not do anything. the diolog window does not come up,unit just beeps...
If this is an External USB Hard-Drive, your problem is insufficient power provided by the USB Port.
1:- Try Another USB Port If You Have One.
2:- If you have a 2 into 1 USB Cable, connect 2 into 2 individual USB Ports ( On Computer ) And 1 into Hard-drive Unit.
If none of this works, your drive is faulty.
Mike @ Compurepair.
** Please do not rate this, until your problem has been resolved ** Thankyou for using Fixya.
Feb 27, 2008 | Computers & Internet
LACIE Porsche 160GB
What system is the laptop? File differences is the ext-hard drive FAT32 or DOS? Therefore XP [NTFS] is not 'seeing' its content. On the XP machine go to start/Control Panel/Admin tools/computer management/storage/removable storage/and check the file type
Sep 27, 2007 | LaCie Design by F. A. Porsche 160 GB Hard...
Drive Shredded
Open Administrative tools, Computer management applet; under storage, disk management. You will probably need to partition and reformat. If this drive is used only on XP machines, then format NTFS, otherwise FAT32.
Sep 18, 2007 | LaCie (300740) 160 GB Hard Drive
LaCie 160GB Mobile Disk USB2.0 160 GB Hard Drive Logo
291 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
