Question about Lexmark Office Equipment & Supplies
I have a Lexmark 83 printer. When I changed the black ink cartridge the cartridge carrier just slams to the left, and I have been unable to correct it. What do I do now.I am winding up my Income Tax business and have several returns that have to be copied. HELP !!!!
I put in a Lexmark black cartridge to replace the Office Depot one,and wonder of wonders it worked
Posted on Apr 14, 2008
I changed the black and color ink cartridges on my Lexmark 2500 printer but both of the ink lights continue to blink off and on. I'm unable to get the printer to reset by disconnecting the printer and...
Make sure you are inserting the correct versions of cartridges for your model. Try to re-seat the cartridges by removing and re-inserting the cartridges in the carrier. The black cartridge goes in the left carrier while the color goes in the right. Also, make sure you are using genuine Lexmark cartridges.
Jun 27, 2011 | Lexmark X2500 All-In-One Printer
Lexmark x83 carrier stall
Hello there.
I have checked lexmark's website on troubleshooting this problem for you.
As per the link here we need to try the following steps to resolve the problem.
Carrier stall" Error and the Carrier Slams in the Printer ID:ENUS12078 null.gif null.gif null.gif
If the printer carrier is slamming into the side of the printer, please try the following:
  1. Disconnect the power supply from the back of the printer.
  2. Open the front cover of the printer where the cartridges are located.
  3. Look for two black bands that span from left to right (they should have one serrated side and one smooth side). Just above the black bands there is a transparent strip; this strip is called the Encoder strip.
  4. Flick this strip lightly with your finger to make sure that it is running smoothly from left to right. You may need to do this two or three times. CAUTION: Do not pull the strip!
  5. Close the front cover of the printer and reconnect the power supply.
  6. If the problem persists, you may need to contact Lexmark Technical Support.
Let us know how this goes and we can assist you futher, if the printer is damaged and is under a year old, lexmark may be able to repair or replace it for you.
Hope this helps.
Jun 16, 2008 | Lexmark X83 All-In-One InkJet Printer
How do i change my lexmark x4650 print cartrige?
Installing/Replacing your ink cartridges:
1. Open the printer, and then press down on the cartridge carrier levers. printmastert_52.jpg
2. Remove the used print cartridge or cartridges. 3. If you are installing new print cartridges, remove the tape from the back and bottom of the color cartridge, insert the cartridge in the right carrier, and then close the color cartridge carrier lid. 4. If a black cartridge is included in the box contents, remove the tape from the back and bottom of the black cartridge, insert the cartridge in the left carrier, and then close the black cartridge carrier lid. 5. Close the printer.
Sometimes the ink cartridge carrier won't automatically move to its loading position even when the printer is on and the cover is open. Follow the steps below:
1. Unplug the printer from the power source.
2. With the cover open, hold the solid white strip that connects from the carrier assembly to the ink cartridge carrier and gently slide the cartridge carrier to the center of the printer.
3. Remove the used cartridges.
4. Load the new cartridges. Close the cover.
5. Plug the printer back to the power source.
May 15, 2011 | Lexmark X4650 InkJet Printer
Lexmark 5400 cartridge carrier slams up against back???? Won't stop!! It's a new printer, put in a high cap black and low cap color cartridge. Any ideas how to fix this?
Cartridges may not be seated properly. Remove all the cartridges from the printer. Close the cover. Unplug the printer from the power source. Wait for about 10-15 seconds. Plug printer back to power source. If printer ink cartridge carrier still slams on the sides, encoder strip of the printer might be damaged. If it's still within warranty from where you bought it, have it replaced at that store. If ink cartridge carrier is not slamming to the sides, re-insert the cartridges. Make sure there are no obstructions along the carrier's path. Close the cover. Let the printer print the alignment page. If it's still going to slam the carrier, have it replaced.
Apr 07, 2010 | Lexmark 83 Color Ink Cartridge (Twin Pack)...
Put in new ink cartridges - when powered on, cartridges slam against end of printer and I get a carrier stall mesage - the slam also loosens the ink cartridges from their position.
Does the problem happen when there are no cartridges in the carriage? What happens if you manually pull the belt to move the carriage to the park position or a position it's not normally in when you turn the machine on when the problem happens. There should be some kind of encoder that lets the printer's computer know the position of the carriage at a given time. This may look like a plastic or metal ribbon. Try cleaning it with rubbing alcohol or window cleaner.
Sep 17, 2009 | Lexmark 83 Color Ink Cartridge (Twin Pack)...
Lexmark x6100 wont print black ink just changed thought it might
To solve the printing problem..
# Hold the cartridge upside down, with the bar-code label facing you and take a damp paper towel. # Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right). # Continue doing this until it looks clean. # Then dab the cartridge on the towel to make sure the ink is flowing. # Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
1. Look for a shiny piece of metal underneath the contacts at the back of the carrier. 2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
# Reinstall the cartridges, making sure you snap them correctly into the printer.
Aug 18, 2009 | Lexmark X5150 All-In-One InkJet Printer
Ink cartridges make a slamming sound from left to right and wont print
The encoder strip is most likely the problem. Unplug the power from the printer. Open the front cover and move the cartridge carrier to the center. You should see a white ribbon cable, a thin plastic strip and a black belt with teeth.
The thin plastic strip is the encoder strip. It rides in a sensor on the back of the cartridge carrier that you will not be able to see. Reach in with the first finger of either hand and carefully strum the strip as if playing a guitar.
The strip will need to be lowered slightly and brought towards you slightly. Please be careful not to break the strip or your printer will not function. Once you believe the strip is set correctly, plug the power back and try printing the self test. If it slams to the left again, the strip is not yet set correctly.
If you cannot repair the strip, please let us know so that we can assist you further.
Please Note: Fixing the encoder strip is a delicate procedure. During the troubleshooting, if the strip breaks, you will not be able to use the printer.
May 28, 2009 | Lexmark X2580 Wireless All-in-One InkJet...
The ink carrier has a clear carrier jam message...
  6. If the problem persists, then its a hardware issue and you should contact Lexmark for replacement of the printer.
Apr 08, 2009 | Lexmark X5470 All-In-One InkJet Printer
Carrier Stall is the error
Please do the following..
To check the cartridge carrier:
  1. Unplug the printer.
  2. Move the cartridges to the left by hand and then take them out.
  3. Try to print without the cartridges in the carrier. Do you still receive a Carrier Stall error message?
  4. If not, put the cartridges back into the carrier and snap them in at the back. The message should no longer appear.
If the power light on the printer is not blinking, the error message may be caused by a communication error. Do the following:
  1. Remove any other devices attached to the USB/LPT port.
  2. Uninstall the Lexmark printer.
  3. Connect the printer directly to the PC and ensure that power is being supplied to the printer.
  4. Reinstall the printer.
Thank you....
Jan 26, 2009 | Lexmark X83 All-In-One InkJet Printer
Ink Cartidge reset
I ahve the same problem can anyone help it keeps slamming !!!!!
Nov 07, 2007 | Lexmark X83 All-In-One InkJet Printer
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
