Question about Panasonic PT-56WX51 56" Rear Projection Television
Convergence problem I am having trouble with the convergence. I am getting a blue arc across the top of the screen. I have tried fixing this by adjusting the convergence using a remote with no success. What's my next step
  • barrera91402 Feb 26, 2009
    i have blue faded lines on everything in the screen specially on any letters. is there something i can do to fix it
  • 2,326 Answers
The reason you can not adjust it is because there is hardware failure in the convergence board.
Visit this website and ask them for a convergence assembly for your TV. Once you replace that assembly, the convergence might still need to be adjusted manually.
Good Luck.
Posted on Apr 13, 2008
Projection TV no picture flashing horiz arcs across top of screen sound okay
You will need convergence work to this unit. Not cheap.(Not recommended for DIY unless already experienced in this type work). Might contact a local servicer experienced with Toshiba & see if they can give you a quote over the phone. Be sure you are sitting.
This is probably a good time to consider entering the 21st century & look at LCD or LED flat screens.
Jul 24, 2014 | Toshiba Televison & Video
I have some distored blue color across the screen
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit from the link below.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on - TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
93a1209.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
Mar 27, 2010 | Panasonic PT-53TW53 53" Rear Projection...
Blue arc and ghosting across middle part of screen.
Replace Both of your convergence ICs they are big Black ICs will have STK on them! Use STK392-150s or the 180s Better ICs Call Mats Electronics 1-800-628-1118
Dec 21, 2009 | Pioneer SD-533HD5 53" Rear Projection HDTV
The scroll on the top of the screen is arced
Convergence IC's are bad. You can get the parts over the inernet or you can get a complete kit - parts - instructions - etc from www.TvRepairKits.com
May 05, 2009 | Philips Magnavox 51MP392H Rear Projection...
Blue Ghost from Defective Blue
this is the convergence IC's that are causing this and if you can replace them( unsoldering and soldering them ) then going to an electronic parts store to get your IC's for your set is what you will need to do , here is an example of the convergence IC's http://www.nteinc.com/specs/7100to7199/pdf/nte7178_81.pdf
if you need further assistance then just let me know and i will help
otherwise hope this info is at least worth a fixya
Dec 30, 2008 | Samsung HCM4216W 42" Rear Projection...
43fdx01b arc at top of screen
Usually this means convergence ic's have to be replaced and possibly a few resistors on small convergence board. Sometimes it requires digital alignment after new parts are soldered in. This repair can cost 175.00-375.00.
Apr 20, 2008 | Hitachi 53FDX01B 53" Rear Projection...
Blue color is out of position
sure sounds like convergance problem
http://www.partstore.com/Part/Samsung/
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Jan 30, 2008 | Samsung HC-P4752W 47" Rear Projection...
convergence amp ic bad
Jan 15, 2008 | Hitachi 43FDX01B TV
Blue Halo Across screen
Hello Damianian, I too have this hdtv and had problems with the convergance and self-focus within the first year of ownership. I called Samsung within the waranty period and they sent out a tech who replaced the convergance board for free and did the manual convergance in my home. After this, with the new upgraded convergance board installed, the self-focus was not necessary anymore so I turned it off. Some time later the convergance needed done again so I called to get a price on them coming out again to do it. I didn't like the quote they gave me over the phone (around $200.00usd) so I looked for a Service Manual online and found one on an Ebay store for a total of $13.00usd including shipping. I now perform the manual convergence on this set myself and it's easy to do.
Anyone wanting to get a Service Manual for their hdtv or other technical device should check these guy's out. They now have their own website. http://www.thecdguyz.com/
I hope this helps, good luck!
Dec 12, 2007 | Samsung HC-P4752W 47" Rear Projection...
My Hitachi 65SWX20B Model, made in 02, just developed Picture disturbance
Can you post a picture of the set. This might be a convergence problem. seeing the set will confirm this.
Thank you,
shuttle83
Oct 28, 2007 | Hitachi 65S500 65" HDTV-Ready Rear...
Panasonic PT-56WX51 56" Rear Projection Television Logo
97 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
