Question about Mitsubishi WD-52627 52" Television
Light Engine Problem?
Yankeegurl,
Thanks for your help. I found a manual and downloaded it. I will look into your suggestions but it may take me a little while. Off hand, do you know what the best resource is for parts if I need to replace the ballast?
Thanks again
  • 121 Answers
You can try alltvlamps.com
Posted on Apr 13, 2008
The Check engine light blinks occasionally (not all the time, and about the speed of about 2 times per second). The previous owners pilfered the owner's manual, so we cannot look it up. Any ideas or...
Hello Richard, the owners manual would not help you on this problem. A flashing engine light means the engine is doing something abnormal, but it hasn't happened enough to turn the light 'solid.' - There should be a trouble code(s) saved which can be read by a scanner. You need have it scanned and get the codes, from there, repairs needed can be determined. I hope this information is helpful.
Oct 10, 2011 | 1999 Chrysler Cirrus
Toshiba 62MX195 faded flashing screen
There are some parts in any television set that can be DIY, In your case, I would suggest to read in the light engine replacement and see if that is something you can do.
Sep 17, 2008 | Toshiba 62HM95 62" HDTV
User manual lost
I lost a user manual, then found these guys. They emailed it to me in about 2 hours and it only cost about £3, which i thought was very reasonable.
http://findmymanual.com/
Hope this helps.
Jane
Jun 29, 2009 | Panasonic NN-SN657SMicrowave Oven
Engine managment light
found it at rear of sump on lefthand side also thanks for your help in solving engine management light it was the crankshaft sensor as suggested by someone on fixya
Jun 02, 2009 | 2000 Daewoo Leganza
HELP WITH A HUSKEE TILLER #21A-340-131
The pdf manual can be found at mtdproducts.com. You need to know your model and serial number to access the download. Really not that good a manual.
Mar 23, 2009 | Mtd 21a 643b066 Bronco Rear Tine Tiller
Emergency brake dash light consistently on.
What Console Are You Talking About? Also Just So You Know The Brake Light Always Being On Means Either You Need Fluid Or New Brakes.
Mar 10, 2009 | 1992 Toyota Camry V6
Light Engine for Toshiba 62HM95
Hello thuertam,
I would first suggest that you spend $19.00 for the schematic and service manual for this device. In the service manual you will see the factory approved instructions on how to remove the light engine. This is the best course of action, because even though some here can give you excellent instructions, the warranty on the parts might be voided if you install incorrectly. In addition if you have the service manual it can guide you through steps that might be left out with secondhand guidance.
A good sight to get schematics frrom is http://www.servicemanuals.net and http://www.manualsparadise.com
I hope this helps
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Feb 12, 2009 | Toshiba 62HM95 62" DLP HDTV
Johnbmw 528 i -Lost Power-.
Wow! Amazing that it seemed to run fine 'til that tank of regular. Good u checked the codes as suggested, did the check engine light ever go on? Glad it's ok, and thanks for the update!
Oct 28, 2008 | 1999 BMW 5 Series
Ballast Assembly Circuit Board
If that is sparking the ballast is ok. Change the bulb although it looks ok it is not firing up. also make sure the bulb is plugged securely in its socket.
Apr 16, 2008 | Mitsubishi WD-52627 52" Television
The bread is too doughy
Hi I have just bought one of these -and so far following the recipe-have found the same thing heavy and not like nice light bread--I was looking for alternative recioes to try but seems like it may be machine?
Jun 01, 2007 | Millers Choice Chrome Bread Maker
Mitsubishi WD-52627 52" Television Logo
54 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
