Good day Sir, to run scan Hp officejet 4315 follow the instructions below.
1. Load your originals print side down and top first in the center of the document feeder tray.
2. Press Scan. the Scan To menu appears on the display.
3. Press OK to select the default application to receive the scan, or use the arrow buttons to highlight a different applications, and then press OK.
4. To stop scanning press Cancel on the control panel.
Tip: To force the scan to be in black and white, press Start Black instead.
Have a nice day hope this will help you.
SOURCE: HP OFFICEJET 7410 "NO SCAN OPTION"
1.open the HP Director/Solution Center 2.click on scan menu and go to destination list tab 3. on the left side u will find a list of available destinations , move them all to the right side (front panel destination list) and save and then try to scan again , IT MAY WORK
SOURCE: driver needed for hp officejet 4315
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&cc=ca&dlc=en&product=1138342&lang=en&
Follow this link and select your operator system ( XP, Vista...)
Go to the driver section and download what you need !
SOURCE: hp officejet 4255 unable to scan
reinstall printer drive use the software that came with printer
SOURCE: My HP Officejet 4315 states Cartridge Error. Can
HP F2480
Align Cartridge:
If you have just installed a new cartridge it is recommended that you align it. Click on "Align" to align your new cartridge
SOURCE: how to scan with hp officejet j4680
Please install the printer software and try to scan via the installed software from the computer. Or, start scan using scan button from printer; after installing software.
Regards,
Rizwan
