D-Link DIR-625 Wireless Router is Blocking Web Address
I have a D-Link DIR-625 Wireless Router. Today I cannot access a specific website by browser, ftp or ping on any of the three computers in my home network.
When I disconnect the wireless router and plug my computer directly into my modem I have normal access to the website. No other website seems to be 'blocked'.
Is there something in the D-Link firewall which would begin blocking a specific web address for some reason?
Any help is appreciated.
  • 1 more comment
  • jshaw51 Apr 13, 2008
    01) The other two computers cannot access the website.
    02) It has been working fine for about a year. The trouble started several days ago.
    03) No new network hardware has been installed since the router a year ago. I don't use any third party firewall software. Just Windows XP
    04) I never tried pinging the other computers. they just share the wireless connection to the internet.
    05) Will attempt that as soon as I figure out their addresses, etc.
    06) I am not aware of anything different over the past several days, unless a virus got in.
    07) I have no other information.
    08) I have reset the router twice. It is back to factory defaults.
    09) It still doesn't connect for browser, email, ftp or even ping.
    I have looked through the router functions and everything is a blank. There are no custom settings to change that I can find.
    Thanks for such a speedy response.
    10) Yes none of the computers behind the router can access the one particular domain.
    11) I have only tried using my main computer, which is cabled into the router, to successfully access the problem domain. It connects normally when the router is removed.
    12-15) I understand what you are suggesting but I'm having trouble figuring out how to 'spoof' the router MAC address. I've been going through the menus on the router and haven't found anywhere to change it.
    BJ @:),
    Well it worked! I did find (finally) a section in the 'Manual Configuration' section on the router which cloned the MAC address.
    A reboot of the router and I am now connecting with the problem domain.
    I don't understand what triggered this black listing.
    In any case, I appreciate your assistance very much. Thank you.
  • 202 Answers
Hi jshaw51
HERE's D-Links listing for your router.
HERE's where you can find downloads, etc. for the router. (including an owner's manual) You'll need to choose your router's version then you'll be directed to the appropriate page.
(01) Can you access this web site from any of the other computers on your LAN (when this router is connected)?
(02) Have you ever been able to navigate to this web site from the computer you're referring to while this particular router is connected?
(03) Have you recently installed any other networking equipment or a software firewall on one or more of your LAN computers?
(04) Were you able to ping the LAN computers prior to the onset of this problem?
(05) Can the LAN computers ping your computer? If not, were they able to previously?
(06) Has anything occurred or any changes been made that precipitated or coincided w/ the onset of this problem?
(07) Do you have any other information regarding this issue?
(08) If you like, you can **first** backup your router's configuration and **second** reset it to factory defaults and see if the problem persists.
(09) You can readily restore the backup. This will just be a quick way to determine if the problem is w/ the router configuration (assuming you were able to navigate to the site in question when you 1st got your router.)
Please, post back here w/ answers to these questions along w/ any observations or questions you might have.
We'll continue to work w/ you until the problem is resloved.
Please, hold off on assigning ratings to any of the experts' contributions until you're all set and have no more questions for us. (Once you assign ratings, the problem will be automatically closed and we'll no longer be able to assist you.)
Thank you,
BJ @:)
Posted on Apr 13, 2008
  • 6 more comments
  • B Joan Rapier
    B Joan Rapier Apr 13, 2008
    1st, thank you very much for answering the questions (and in such an orderly fashion). That really does help.
    (10) In response to your answer to question (09), I want to make sure that I understand your issue correctly... (and completely)
    When you say that it won't connect for ping, ftp, nor email **from ANY of the LAN computers when the router is installed** are you still referring to the same domain?
    (11) If so, can you ping, use ftp and send and receive email on this domain if your computer is directly connected to your cable or DSL modem (router disconnected from LAN)?
    (12) If that is the case, then, yes, there's something definetly going on at the router level.
    (13) It is possible that your router's MAC address has been black listed or otherwise blocked from accessing this site.
    (14) The MAC address that the site is going to "see" will be that of the device that is connected directly behind the cable or DSL modem (either the router or your computer).
    (15) You can try "spoofing" the WAN-side MAC address of the router by giving it the MAC address of your computer's NIC (since it DOES work w/ your computer). See if the problem goes away then.
    (16) Also, please, check the following file (You will need to enable viewing of hidden and system files. If you don't know how to do this, please, let me know. Also, if your operating system is not Windows XP, please, let me know that as well.)
    (17) Navigate to: c:\windows\system32\drivers\etc\
    (18) Right-click on the file called "host"
    (19) Choose to open it w/ Notepad.
    (20) Look very closely at the listings in this file. Do you see ANY derivation of the domain name in question there?
    (21) If you do, remove all occurrences. (Be mindful, however, that if that domain name is listed there by a malware detection utility that there is a good chance that the domain is known to be "hostile" or "black-listed" for some reason.)
    (22) If you are running Spyware Blaster or Spybot Search and Destroy or any other malware detection utility that can block ActiveX or modify your "hosts" file, disable them and try accessing the site again.
    (23) WARNING!! Doing so may put your computer at risk!! Make sure that you create restore points along the way so you have somewhere to go back to should you run into trouble. This is NOT a panacea, however, (using System Restore points) but can be helpful for restoring your "System State" in certain situations.
  • B Joan Rapier
    Let me take a look at your manual and see if I can find where you need to go. I'll post back here in a few....
  • B Joan Rapier
    Oh yes. I need to know the revision of your router (there have been a few). Take a look at the sticker on the bottom and you'll find it there.
  • B Joan Rapier
    Page 20 of the manual for version C of the router has an option to "CLONE YOUR PC'S MAC ADDRESS" (My apologies. I should have used the word "clone" rather than "spoof".)
    This feature was originally intended to "fake out" those ISPs that wanted to charge subscribers for every computer using their service. By "cloning" the MAC of the computer that was registered w/ the ISP and assigning that MAC address to the WAN-side of the router, subscribers were able to circumvent their ISPs attempts at charging for every Internet-connected computer.
    To determine the MAC address for your computer:
    (A) START
    (B) RUN
    (C) CMD [ENTER]
    (D) getmac [ENTER]
    Enter this MAC address for the WAN side of your router and, please do, post back here letting us know what happened.
    Thank you
    BJ @:)
  • B Joan Rapier
    To make sure you get the MAC address for the correct NIC, disable the NIC you aren't using THEN follow the steps to determine your NICs MAC address.
    IOW, if you're using wireless, disable the wired NIC on your computer and visa versa.
  • B Joan Rapier
    Disable the IEEE1394 (firewire) connection, too, prior to running "getmac". Leave only the connection you are using to connect to the router enabled. This will eliminate any confusion as to what MAC belongs to what NIC or device in the "getmac" results.
  • B Joan Rapier
    Terrific! Please, remember to assign a "FixYa" rating to my contributions a solution as it did resolve your problem for you. :)
    Thank you for using FixYa. Please, do come back anytime w/ questions or problems you need help w/. We are here to help.
  • B Joan Rapier
    Once again, you are more than welcome, my friend. Thank you, kindly, for the "FixYa" rating, too!!
    If you end up w/ the same problem w/ this domain again, just enter a new MAC for the WAN side of your router. It can be any NIC MAC address (it doesn't have to be a MAC address taken from one of your LAN computers).
    BJ @:)
How do i access my wireless router
Go to the mfg web site and download the install software for the router and follow the directions.
Most have to use a "MAC" address that is printed on the router label.
Jun 22, 2012 | D-Link DIR-625 (790069292637) Wireless...
My router suddenly stopped working yesterday and I've tried everything I can think of to fix it. I have one computer wired directly in to it and a few laptops that use wireless connections. The...
Please try to access the router's configuration page by accessing using a computer that is wired on the router.
Default admin user name:Admin
Default admin password:
Please update firmware:
Note:Please do not upgrade the firmware over wireless connection. Anyway you wont be able to do that now but for future reference. Please use the link on the bottom.
DIR-625 rev C:
Jul 10, 2011 | D-Link DIR-625 (790069292637) Wireless...
HI, I updated my router firmware, and now it's aking for a 8 digit pin number that i don't have. Where do I find it? There is nothing on the back. Thanks.
You may find the user manual on this site, where you can download it to access your router's configuration utility.
On most routers it can be accessed using the IP address in your web browser.
Jun 06, 2011 | D-Link DIR-625 (790069292637) Wireless...
How do i access the website to configure a password?
Type in web browser to get into you router settings.
User Name : Admin
Password blank and click enter
please rate this if it helps, if it doesn't let me know and we can go from there.
Apr 15, 2011 | D-Link DIR-625 (790069292637) Wireless...
What is a key code for the dir 625 D link wireless router, is it maintained in on te set up page?
Welcome to Fixya.
If you need you Security Key or Key Code (Network Key) on your router you need to access the Wireless Settings Page. To access the router page you need a working computer that is connected to the router. To access the router page just open a browser then type, the Default username is admin and the password is blank. Go to the Wireless Settings and under Security Mode you'll find the Network Key or Passphrase. You can alsoThen Personalize you Network Key or Passphrase so that you can easily remember it.
Thanks for using Fixya
Mar 05, 2011 | D-Link DIR-625 (790069292637) Wireless...
I don't know how to set a password on my d-link router because my internet is insecure. How do i do this? I have the default username and password, but i don't know what to do from there.
1.Open your Internet browser and type in the default IP address for your DIR-625 wireless router: A window will appear asking for your DIR-625 wireless router network name and password. If you do not know your existing network name, enter the default network name, "Admin." Leave the password blank. If you have already set up a network name and password, enter it now. Select "Log In."
2.Select "Wireless Settings" from the left-hand navigation bar. Put a check mark in the box marked "Enable Wireless."
3.Type your new wireless network name for your DIR-625 in the box labeled "Wireless Network Name."
4.Type your new password for your DIR-635 in the box labeled "Pre-Shared Key."
5.Select "Save Settings" from the top of the screen to save your new password.
Feb 07, 2011 | D-Link DIR-625 (790069292637) Wireless...
How do I find my security key for a D-Link DIR-625 router?
You will need to log into the router's web page to view the security settings and access your security key. The default IP address of D-Link routers is normally; simply input this IP address into the address bar of your web browser.
You will be brought to a D-Link page and be prompted for your user name and password. If you have not made any changes then the default password should be admin. If you changed the user name and password simply enter them here.
You will need to click on the "setup" tab found at the top of the page. Now you will need to click on "setup wireless" or "Wireless settings" to access the manual configuration. Now you will be able to locate the security key.
If you are unable to locate any of these or you have changed the user name and/or password and no longer remember what they are, you will need to reset the router and set up your wireless network from scratch.
Nov 07, 2010 | D-Link DIR-625 (790069292637) Wireless...
My windows 7 pc wont port forward through my dlink router dir-625 for my ventrilo server
Normally the Router does the Port forwarding as below, try this, Prepare the Router
as this stage differs from one router to another. We will give you a general idea and you should refer to the manual of your router for confirmation.
  • Go to the administration interface of the router by typing its IP address in the web browser (for example
  • Enter Login and Password
  • In the page that comes up, search for Port Forwarding.
  • Then add following data:
    • Name: Give it a unique name like Remote Desktop
    • External Port: 3389 or whatever
    • Internal Port: 3389 or whatever
    • Destination IP address/server: Enter the IP address of the computer as defined in step 1 (e.g.
    If necessary punch through the firewall too, on those same ports.
Jan 28, 2010 | D-Link DIR-625 (790069292637) Wireless...
How can i lock my d link dir 625 router?
Access its built-in web-server (as per the instructions in the manual that came with the hardware) and:
1. change the "admin" password
2. add "MAC-address-filtering", to severely limit the MAC-address(es) of the computer(s) that you wish to allow to connect.
Sep 13, 2009 | D-Link DIR-625 (790069292637) Wireless...
How do I open port 30000 in a DIR-625 router?
Hello marquitos4,
Go to
and you will find all the info you need regarding port forwarding through your D-Link router.
The page is specific to the DIR-625 but just about any make/model is supported at
Dec 15, 2008 | D-Link DIR-625 (790069292637) Wireless...
Computers & Internet Logo
1,525 people viewed this question
David Payne
David Payne
