Question about LG 32LC2R 32 in. HD-Ready LCD Television
PIP doesn't work
When I press the pip button in the remote control a warning sign appears. As if its telling me that pip is not available.
    Problem Solver:
  • 53 Answers
Hello Rozel:
When using the Pip you have to make sure that there are two different signals one analog and one digital if so then there may be a issue with the small signla brd processing the signal.
Posted on Aug 19, 2008
How do I do picture in picture
How to turn on PIP in Samsung TV SAMSUNG STEP 1. OPENING MENU SETTINGS
Click here to know about PIP in Samsung TV.
a). Press MENU key ( 20130724181903971_281z433j.jpg ) from TV remote.
b). Select Picture option and press ENTER key ( 20130724182110969_vyofsac0.jpg ) from TV remote.
c). Select PIP option and press ENTER key ( 20130724182110969_vyofsac0.jpg) from TV remote control.
20130724182409386_3o5go25e.jpg STEP 2. TURNING ON PIP SETTINGS
d). PIP window will open on TV screen. Select PIP and press ENTER key ( 20130724182948520_6zvcucfc.jpg ) from TV remote control.
e). Select On option and press ENTER key ( 20130724183213111_ln8iy22v.jpg ) from TV remote control.
f). Enjoy watching PIP screen.
Oct 19, 2014 | Samsung New 55"" Class 54.6"" Diag. Led...
Turn on pip wiithout remote
If your TV has a Menu button on its front panel, enter its Menu widow, surf through, come to wards picture control window, and make PIP function OFF. If it has no such button, you must have its remote control to turn it OFF.
Jun 07, 2012 | Televison & Video
PIP function does not work, the settings is greyed out also! I have a wii, PS3 and freesat :)
Hi nikkicollier,
PiP for your TV works between two different sources. This means between a component source and an HDMI source or between an HDMI source and another HDMI source. PiP also works with a PC connection, e.g. when using the TV as a computer display. PiP does not work between two component sources. The setting will be grayed out when you don't have a configuration that is supported, as the Samsung TV's are usually able to automatically detect which sources are plugged in and available.
I'm not exactly sure what sort of configuration you want your PiP to work in, but try one of the following configurations.
  • TV Cable (through VCR or other via Component input) with Satellite in PiP (via HDMI input)
  • PS3 (via HDMI Input) with Satellite in PiP (via Component Input)
  • Wii via HDMI Input) with PS3 in PiP (via HDMI Input)
You can usually find an HDMI cable for much cheaper at an electronics supplies shop, Radio Shack, or on eBay or Gumtree.
To change your PiP settings:
  1. Press the MENU button on the remote control. Select Picture and press Enter.
  2. Select PIP and press Enter.
  3. Press the enter button again, and press up or down to change the setting to On and press enter again.
    Note:
    If PIP is activated the screen will display in widescreen (16:9 aspect ratio.)
  4. Press the up or down buttons to select the Source then press the Enter button.
    Select the source of the sub-picture by pressing the up and down arrows and then pressing the Enter button.
    Note: The sub-picture can serve different source selections based on the what the main source is set to.
    Note:
    You may notice that the picture in the PIP window becomes slightly unnatural when you use the main screen to view a game or karaoke.
You can download the full PDF manual for your TV here (large download at 26MB.) Much of the PIP information can be found on pages 13 and 14.
Good luck, I hope that helps.
Mar 01, 2011 | Samsung LE40R73BD 40 in. HD-Ready LCD...
I have a sony (model KP61V75) a split screen came on (two pictures) and I cannot figure out how to get it back to one screen. Im going crazy!
Some television remote controls have a PIP OFF button, while others only have a PIP button that needs to be pressed repeatedly until the PIP/Twin-View window disappears.
NOTES:
  • Some Sony rear projection televisions have a FLASH FOCUS button that will turn off the PIP/Twin-View feature.
  • Some Sony universal remote controls, if programmed to operate a Sony TV, can disable the PIP/Twin-View feature by pressing the REC or ENT button.
  • If the original TV remote control is not available or is not functioning properly, auto programming the television tuner orperforming a power reset may deactivate the PIP/Twin-View feature.
  • If pressing the appropriate buttons on the TV remote control does not work, then the PIP/Twin-View window might be from a two-tuner cable or satellite set-top box. If this is the case, use the remote control provided with the set-top box to remove the PIP/Twin-View window.
Jan 25, 2011 | Sony Televison & Video
I have a sony trinitron XBR 32 inch... The pip was turned on by accident, but i don't have the original remote. How do i turn off the PIP? Thanks in advance.
pls. use remot menu key and open main menu use DW key and select system menu see the PIP option is "ON" set option is"OFF" .
See the PIP screen is clear.
Oct 20, 2009 | Sony FD Trinitron WEGA KV-32FS100 32" TV
I have a sony trinitron XBR and the PIP won't turn off. Any help is greatly appreciated.
Please make sure that one input is connected to the UHF/VHF port of the TV and other is connected to composite or component ports. If you have connected likewise, please perform the steps below:
  1. Ensure the video source is turned on.
  2. Ensure the video source is connected to an available VIDEO input jack on the back of the television. IMPORTANT: The VIDEO 5 input cannot be used to view a program in the PIP window.
  3. On the television remote control, press the TV FUNCTION button.
  4. On the television remote control, in the PIP section, press the TV/VIDEO button to select the appropriate video input for the PIP window.
  5. If the issue is not resolved, connect the Audio/Video (A/V) cable from the video source to a different VIDEO input jack on the television.
  6. On the television remote control, in the PIP section, press the TV/VIDEO button to select the appropriate video input for the PIP window.
  7. If the issue is not resolved, replace the A/V cable.
Sep 15, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Can't remove blue PIP (?) section in lower RH corner
I have the Olevia TV with RC-LTU remote, To get rid of PIP just press the (VIEW) button twice.
Nov 13, 2008 | Olevia LT37HVS 37 in. LCD HDTV
PIP doesn't work
You emailed the following...
Dear BrettK,
We wanted to find out if you still need a solution for the Flat Panel Televisions Problem you posted on FixYa yesterday.
In case you do, we'd like to offer you our Premium Assistance Plan
By using this plan, your problem will be addressed by a group of Elite Experts who can provide you with professional assistance and often (!!) solve your problem.
Click here for more information about this plan.
If you already solved this problem, Click here to tell us how you did it.
Regards,
The FixYa Team
To answer your question. I found my solution by going to a group that was more interested in helping than in charging me money. Worked a treat. Problem solved.
Apr 28, 2008 | Televison & Video
Lamp reset
This also works for the Panasonic PT-61LCX65. You hold the volume button down on the projection display, then hold down the Split/ DVD button on the remote control at the same time. I just did it after reading the advice posted. Thank you!
Oct 11, 2007 | Panasonic PT-50LC14 50" Rear Projection...
Turning off PIP without remote
To turn off the "stuck" pip on a Panasonic tv without a remote:
1) Turn off the tv.
2) Then hold down the "Action" button on the front of the tv and press the power button.
2-b) Continue to hold down the Action until the tv powers all the way up, and the reset menu comes up - be patient.
Expected Reslut: Self check menu should appear.
Expected Reslut: The pesky pip screen will be gone!
If the self check menu does not appear, you did not hold the Action button long enough.
Simply begin from step one.
Thanks to Imhiro
Sep 28, 2007 | Panasonic CT-36D32 36" TV
LG 32LC2R 32 in. HD-Ready LCD Television Logo
148 people viewed this question
Computer Repairing
Computer Repairing
