Question about Solis Master 5000 Espresso Machine
Part(s) needed for Solis Master 5000 in New Zealand
Hi all,
I am trying to find a repair part for our broken Solis 5000 (in New Zealand) - a broken "boiler" (?) or heating element or whatever is the correct English word for it (sorry, English is not my mother tongue).
Our local repair (shop) tells me that there are no longer parts available for that model?
Thanks,
Michael
    Problem Solver:
  • 11 Answers
Here are the links to get replacement parts for your system. They are listed under the Vienna model, which has the same boiler system as the Solis Master 5000.
Best Wishes,
Lane
http://www.shop.partsguru.com/product.sc?categoryId=-1&productId=937
http://www.shop.partsguru.com/product.sc?categoryId=-1&productId=282
http://www.shop.partsguru.com/product.sc?categoryId=-1&productId=1546
Posted on Jan 18, 2009
How can I determine what parts I need to repair my espresso machine and where do I get parts and service?
Solis Master 5000 Espresso Machine - YouTube
? 9:49
www.youtube.com/watch?v=MjBmlQXElag Sep 2, 2010 - Uploaded by Day Tooley
I have been enjoying the Solis Master 5000 for a year. It's time to ... I haven't been able to find an actual user manual online...for some reason.
Nov 03, 2015 | Solis Master 5000 Espresso Machine
Hi, My Solis master 5000 digital is having a problem. When we turn it on it says water tank is empty even when the tank is full. Thank you!
Check the water reservoir, if there is a float in the corner. Then that piece is not getting in contact with the reed switch in the machine. Try sliding the reservoir down the back of the machine so that it is always in contact with the back, or if the float is not rising when the reservoir is filled with water then the reed switch cannot detect the magnet in there. You might need a new float assembly.
Oct 20, 2011 | Solis Master 5000 Espresso Machine
I have got a master 5000 and the brew unit gets jammedor locks when goes on brew mode.
Hi
There are a couple (3) of things that can cause this.
1. You have a broken brew drive but you would hear a clicking noise if this happens.
2. You have an over charge going into you brew unit. There is a small knob in your bean hopper. Turn it back 1 mark and try again.
3. Your grinder has come apart and is grinding very coarse. (French press size) New grinder.
Jun 01, 2011 | Solis Master 5000 Espresso Machine
Solis Master 5000 won't warm up
Hi
Sometimes when you first turn the machines on you need to run water through the wand to get them to start heating. If you have run water through the wand and it still won't heat up, you could have a bad board or sensor wire off, boiler wire off, bad element or thermostat.
Oct 19, 2009 | Solis Master 5000 Espresso Machine
Need a new heater tank where can I get one and aprox. how much are they? for Solis 5000
The only place I know of for Solis parts now is Empire fulfilment. Sorry I do not know how much it will cast for the part.
Oct 05, 2009 | Solis Master 5000 Espresso Machine
CAN YOU PLEASE ADVISE ME ON WHERE TO GET INFO AND PARTS FOR THE SOLUIS C/MACHINE IN CHRISTCHURCH OR NEW ZEALAND MANY THANKS CATHY SAXON APPLIANCES
You should try their website at
http://solis.com/contents/customer_service/customer_e.htm
There is an email address for product support so you can email them with your parts. Although the company is based in Switzerland I am sure they will be able to assist you and ship parts directly to you or find you a local store.
Sep 15, 2009 | Solis Master 5000 Espresso Machine
Need to buy water tank of solis pallazzo coffee maker
The only importer of solis I know of is Barratza.com, they will have the parts needed.
May 29, 2009 | Solis Master 5000 Espresso Machine
Grinder not working on my solis master 5000
Order the replacement boiler, (be sure to empty all of the hot water from the boiler first using the hot water function on the right side of your Solis) take your time and open the machine up, the top comes off. There are 3 mounting screws that hold the boiler in place, remove them, be sure to take hold of the boiler before removing the last mounting screw. Remove and replace the wires and 2 water hoses (w/clips). The orange wires the connect to a unique plastic harness are clipped into the harness. Look closely and you'll see a little window in the plastic harness at the end of each orange wire. Use a tooth pick or a pointed device and push the metal clips thru these windows, this unlocks the wires for removal from the boiler.
Good luck and Best wishes
Lane
Dec 19, 2008 | Solis Master 5000 Espresso Machine
Solis Master 5000 Espresso Machine - Need Repair
If you can remove the grind hopper(two screws) you can re-index the grinder for a finer grind.
Apr 21, 2007 | Solis Master 5000 Espresso Machine
Solis Master 5000 Espresso Machine Logo
332 people viewed this question
Top Solis Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
AZBen
AZBen
gbob59
Are you a Solis Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
