Question about Nikon Photography
Where can I get a 6v battery for my NIKKORMAT EL?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Nikon Master
  • 102,366 Answers
One possible source is http://www.batteriesplus.com/products/563-0/7529-Film-Camera-Battery/47473-Nikon/Nikkormat-EL/1.aspx
Posted on Jun 15, 2010
SOURCE:
1990 Dodge Ramcharger won't start. Battery output 12v, voltage across coil terminals 6v, voltage output at coil port to coil wire 6v, voltage of coil wire output to distributor 6v. Engine will c
There should be a small white ceramic block on the firewall - this component cuts the battery voltage from 12 to 9 volts for the coil and ignition system. It has 4 wires and is called a ballast resistor.
You may need a book with the wiring diagram to be able to test it. You should have battery voltage going in and something like 9 volts coming out.
You can also run a wire with a fuse from the battery to the positive side of the coil to check the system. Disconnect the factory wire from the coil first.
Jan 27, 2013 | Cars & Trucks
Le cambie el aceite del motor ami mitsubishi eclipse 6v gt. Le puse aceite 10 -30 sintetico y al ir manejandolo se escucha que el motor se forsa al aser un cambio y al prenderlo se aselera y luego se...
I think you could use this manual
method instead.. My nephew used it to repair my car and it's perfectly fine now. Here's the website he bought it from. www.reliable-store.com
Mar 06, 2018 | Cars & Trucks
I was given a nikon nikkormat el camera and i can't find a battery compartment
The battery compartment is inside the mirror box, on the lower side. To change the battery, remove the lens, lock up the mirror, then push the lid to the left and lift it up.
You can download a copy of the manual from
http://butkus.org/chinon/nikon/nikkormat_el/nikkormat_el.htm
Feb 17, 2011 | Nikon Photography
I was just given a nikon nikkormat el camera.i don't see battery compartment
Take off the lens and lock up the mirror. There you will find the battery. Google is your friend
Feb 17, 2011 | Photography
Nikkormat 35mm SLR light meter not working!
1) Clean the battery contacts and put fresh battery.
2) Open the top cover and clean the meter switch ( located and the wind cam )
3) Meter needle maybe stuck at the rest position. Remove the stopper and replace or clean.
4) If none of these help, check the meter cells and resistor band under the shutter dial behind the lens mount ( hard to do.)
Jun 14, 2010 | Nikon Photography
I need to find a manual for my nikkormat fs
I don't see a manual for the FS but you can find manuals for cameras of similar vintage at http://www.butkus.org/chinon/nikon.htm
Sep 30, 2009 | Nikon F65 35mm SLR Camera
I need a Nikon CS-11 soft camera case for my Nikkormat EL 1972. Where to find please? Also a lens cap for the f=50mm 1.4 lens please. BR Gerald Kingsbury
Try ebay. Search on Nikon CS-11 .
They don't any now but keep trying. Two were listed for $5.99 last month with no takers.
Sep 12, 2009 | Photography
Nikkormat FT
I have a Nikkormat FT, and I can assure you that there is no "timer" button on this camera. There is, however, a timer lever to the left of the lens if you are looking at the front of the camera. As for the light meter, have you tried moving the film advance lever to the "cocked" position, since that turns on the meter.
Jul 01, 2008 | Nikon Nikomat FT 35mm SLR Camera
Did I kill my el-wire with current?
I don't know anything about el-wire except what I have just read on this site:
http://www.elec2go.com.au/category5_1.htm
It looks like there are limitations to the inverters and length of liffe due to outputs and frequencies. Length of wire will govern which inverter to use.
Maybe your HD 10 amp 12 volt power supply simply burnt out the wire? Consider that (on the page I have just looked at) inverters are run on 2 AA batteries or 6v inverters and output 6 mAmps (not 12 volt and definitely not 10 Amp!). Is this Power Supply an inverter specifically for the el-wire?
Read up this web site (and others) and you may find the solution (and the cause of the problem).
Sorry I can't help any further than directing you to the Internet.
Apr 26, 2008 | Neon EL Wire / Wire
Nikkormat EL Battery
Yes, the battery will operate the camera, Silver oxides are likely only available at a true photo store.
Jan 18, 2008 | Photography
Photography Logo
168 people viewed this question
Top Nikon Photography Experts
Ric Donato
pictureman4u
Jeff
Jeff
Are you a Nikon Photography Expert? Answer questions, earn points and help others
