Question about Refrigerators
How to reset fridge light - Kitchenaid side by side
How to reset the refrigerator light in the kitchen aid fridge. Large side by side type. I left the door open too long and the light went out. The bulb works I tested it.
  • 6 more comments
  • Missy1Diana Apr 13, 2008
    Hey, Thanks. I could only turn the fridge off with the push button on the panel since the fridge is a huge built in. I let it stay off for about 5 minutes and turned it back on. The light did not come on. I pressed the HOLIDAY MODE button and the LED settings and the lights came on.
    Thanks for your help. It got me to start thinking.
  • Missy1Diana Apr 16, 2008
    OK Thanks. I'll look for the panel if this problem should occur again. I appreciate all of your help.
  • GlenSXM Feb 01, 2009
    all lights go off, the fridge seems to be cooling. When I unplug the fridge, and after about 5 minutes I plugged it back again, everything worked fine.
    About 5-10 minutes after, same problem. The only light flashing is door open. When I press the holiday mode button twice, everything comes back on, HOWEVER, after a while all lights go off.
    Doing a master reset, pulling out the AC plug, and waiting close to 10 minutes does not help. It resets, but then happens again after a while.
    I have the Kitchenaid side by side door KSSC48QMS01
    Thanks,
    Glen
  • Anonymous Mar 14, 2014
    Our fridge is side by side with freezer. The fridge door was left open, light burned out and now fridge is not working, but freezer is.
    KTRS25KGWH00 KITCHEN AID REFRIGERATOR
  • Anonymous Mar 15, 2014
    fridge whirpool imperial series, light inside of fridge went out and the controls lights too. I tested the light bulb and is fine, fridge still running, but controls are out?
  • Anonymous Mar 18, 2014
    Model KSS048FMX
    I replaced one of the bulbs in my fridge last night and then decided to clean a shelf while I was at it. The door was open for 5 minutes and the next time I opened the door none of the lights went on.
    I turned the power off for 10 minutes to see if it needed a reset but that didn't help either. Thanks in advance for your help.
    Model KSS048FMX
    Scholar:
  • 35 Answers
This may or may not help. Most SMART devices forget their SMART functions when your unplug them and wait a few seconds then plug them back in this should reset it!!
Posted on Apr 13, 2008
  • Cary Micheau
    Cary Micheau Apr 13, 2008
    Circuit breaker? Most panels are clearly labled and you could remove power this way by switching off the circuit breaker doing a hard reset in effect. Please look away when switching off and back on for safety reasons.
My kitchen aid refrigerator won't stop buzzing
If everything is cooling right, take the front grille off at the bottom of the fridge and move the plastic drip tray. It might be touching the motor or pipe, causing the noise.
Jan 28, 2015 | KitchenAid Kitchen Aid - KSC23C8EYY...
My freezer is too cold
There should be a freezer and a fridge side temperature setting , look for both is fridge side
Oct 05, 2014 | KitchenAid Kitchen Aid - KSC23C8EYY...
Have kitchen aide fridge ice maker stoped working, replaced ice maker still not working, red light blinks twice? Help
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
hkhjkd
Jan 06, 2010 | KitchenAid Superba Architect KSCS25INSS...
Kitchen aid top shelf warm
  1. check gasket
  2. check the light switch on top of the refrig. section. If then pushed the switch turns the light off, but the light is still on with the fridge door closed - door needs adjustment.
Oct 13, 2009 | KitchenAid KSS48QM 48" Built-In...
Ksrs25ikss01 kitchen aid fridge portion not
1.check if the fan inside the freezer is running
2. if ref runs none stop, defrost timer is out.
3. or it could be the high limit that paired in series with the defrost heater
good luck!
Jun 25, 2009 | KitchenAid Superba Architect KSCS25INSS...
Kitchen Aid side by side referigerator KSSC42QMSO
the freezer does all the cooling for both sides a few shelves down in the fridge on the left hand side there is an air intake make sure nothing is blocking it also listen for the freezer fan to run if its not look at the coils in the bottom of the freezer to see if they are heavly frosted in the fridge side at the top left side should be some vents hold your hand there to see if air is blowing through if not reply to me well go from there
Nov 29, 2007 | KitchenAid KSRP22FNSS Side by Side...
Kitchen Aid Fridge
how long does it take for fridge to cool if its not been used in months?
Nov 23, 2007 | KitchenAid KSRD22FKBT / KSRD22FKWH /...
Refrigerators Logo
2,092 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
