Question about Infinity Reference 7541a Car Audio Amplifier
Channel not working
The back rear channel has never worked. Putting a multimeter to it showed almost no power coming through. Do I need a new amp, or is there a way to fix it?
    Problem Solver:
  • 5 Answers
Get it repaired by a car audio shop, if its expensive get a new amp.
Posted on Dec 13, 2008
Amps turn off and cut out
You just gotta get your gains set up right. Look Up "How To Set your Gains with a Multimeter" your over powering your subs or speakers and your amplifiers cant keep up. you also have to make sure your speakers are wired to the right ohms. your amp cant handle. if your amp cant handle, for Example:1 Ohms your gonna blow your amps. ......Speakers and subs are a science too.
Dec 27, 2012 | Kicker 10DX5001 Car Amp
We have an old amplifier from back in the 80's and 90's. Its 500watts, the right channels (both main and sides) work fine and loud, but the left channels produce very low sound. I checked the fuse and its...
Have you checked the final transistors on that weak channel? They may look fine but may be weak. You can pull them and check them on your multimeter with the diode check and cross it with the data sheet for that transistor.
Mar 07, 2011 | Kenwood KAC-5204 350 Watt Max Power Stereo...
Behringer EP2500 Clip light Channel 2 stays on & heatsink HOT!
There are so many components that can fail that troubleshooting this can be an expensive problem.
HINT: Put a 150 Watt light bulb in series with the power going into to limit current for/during troubleshooting.
Go through and compare the voltages on the teo channels. If power amp transistors have failed, likely the driver transistors also are gone.
Testing components in-circuit is very dificult. Resistors are pretty reliable and usually show damage by discoloration.
Furhter use before repairing MAY cause further damage.
Jun 03, 2010 | Behringer EUROPOWER EP2500 Amplifier
I have an Infinity 530a 5 channel amp. new
May be the problem is on the sound you are using is not a 5 channel coded sound or check in the menu´s of the amp if the rear channel´s have sufficient db output, check the connections, check if you amp. is not working only as simple stereo (menus also)
Hope this helps
Jun 24, 2009 | Infinity Car Audio & Video
I have all the wires running right but for some reason my amp is not picking up or pushing my subs. could the rca jacks be messed up on the stereo?
According to the specs for the xo 1945- the output is; 50W x 4 Max Power Output , and I do not see a pre amp output listed. So I think to connect subs, you will need a separate AMP.
The way this works; the rear speaker wires from the xo 1945 hook into the Add-on amp, for example a 4 channel amp. In a 4 channel amp, the rear speakers come off two of the channels of the add-on, and the subs come off the other two channels. There is also the option of bridging two channels for more output power to ONE sub.
You did not mention what size sub(s) you were thinking of adding, but keep in mind that the ox 1945 puts 50 watts MAX per channel. So, if you add two 12" subs and a 1500 watt amp to drive them, your total sound is going to be very uneven.
If you go on line and look up auto audio or amps, you'll get a good idea of all the Sub and amp options that are available.... Hope this helps.
May 02, 2009 | Car Audio & Video
I have a Denon AVR 887 surround sound receiver head unit in my living room. Today I was putting in new speakers, and it worked fine for about5 minutes, then it shut off. Now I keep getting a red flashing...
If your amp looks like it's going to work as normal (ie the front display lights up as it should etc), but then the amp goes into protection mode when the anti-thud circuit times out, then I know what's likely to be wrong.
It's one of the power amplifier channels which has gone faulty.
I just found this out after having this problem with my AVR-1906.
I took the amp apart and de-soldered the suspected channel power transistors (centre channel in my case).....and hey-presto! it fired up as normal (obviously the centre channel would be out of service).
I have ordered the replacement transistors from Farnell (UK) at a miserly cost of around £2-£3 each.
Just waiting for them to arrive.
An alternative is, if you don't use all your channels, take the transistors from a known working but not needed channel and swap them over with the duff ones.
Hope thats of use!
May 03, 2008 | Denon Audio Players & Recorders
Trouble shooting XM-1652Z Amp
Grab yourself a test light and make sure that not only the 12v red power wire is putting out power but the thin blue or 12 volt turn on wire is also showing power. Then test the ground terminal and make sure u have a good ground. If that doesnt work try checking the amps fuses and check the fuse and connection on the battery. If everything checks out ok and the problem persists then put a small test speaker to the channel outputs and make sure that u are getting noise from those channels if you dont get any noise then u most likely have bad outputs and blown channels, you will need a new amp. Good luck, hope i was good help.
Jan 26, 2008 | Sony Xplod XM-1652Z Car Audio Amplifier
Vision 708 mixer amp
Jimbo
I am not sure about the LED fault lights....but I have a few troubleshooting angles to provide a start:
Try checking the power supply at the output devices and compare with the good (Left) channel.
The distortion you are hearing may be due to
low voltage.
This is a stereo amp, so you have a good (Left) channel to compare with. Use a multimeter to compare resistances (no power applied) or voltages (power on) at the components working back from the outputs of each channel. When you find a difference you have located the faulty area.
If you can get an oscilloscope it can also be used to trace the path back from the output of each amp. Good Luck Be careful!
Jan 08, 2008 | Food Mixers
I do not hear any music through my 10" M Audio Subs (M Audio Sound System)
If you know how to use a multimeter, you can test the amp this way:
-unhook the subs
-hook up a cheapie speaker you know for sure works to one of the channels
-unhook the audio inputs
-turn the amp on
-set your meter to VDC
-put the positive probe on the inside of the input connector, being sure you make contact with th inner contact
-take the negative probe and tap it on the outside of the connector
What you are doing is sending a low voltage (replicating an audio signal) into the amp audio circuit and allowing the amp to amplify it. If the amp makes the speaker pop each time you strike the probe, the amp is working.
You mentioned you need a 4 channel amplifier make the two, dual voice coil subs operate. The is not true and by hooking them up like that, there's a chance of damaging the subs. The reason is that the dual voice coils are interwoven and they have to get electrically identical signals or they fight against each other. The can mechanically fail, then, electrically fail, then even damage the amp too.
Nov 21, 2007 | Nakamichi PA-504 Car Audio Amplifier
Infinity Reference 7541a Car Audio Amplifier Logo
60 people viewed this question
Top Infinity Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Colin Stickland
Colin Stickland
Are you an Infinity Car Audio and Video Expert? Answer questions, earn points and help others
