Question about Hitachi P50H401 50 in. Plasma HDTV
NO POWER!!! Just bought a new 50", got home set it up, plugged it in and no power to the unit, I checked the cord and there is power getting to the TV. There are no lights or anything coming on. Any Ideas?
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 35 Answers
I'm sure you have it figured out by now, but, there is a power switch on the right hand side, underneath the television, about a foot from the end. Make sure that it is depressed.
Posted on May 15, 2008
I could be one of your fuses, the only problem is you have to take it appart and if you don't know how is better to take it back where you bought it.
Posted on Apr 13, 2008
HELP???
What was the voltage that you measured? Are the units 220 volt or 120 volt. Units that size are usually fed by 220 volts. What is the current rateing of the circuit breakers? Are they a double breaker with a handeling capacity of 20 amps or are they 15 amps.
You didn't mention if they ever worked? Are you feeding 120 volts or 220 volts to the two units?
Good luck,
Marty
May 11, 2014 | Dometic Rooftop RV Air Conditioner
LG LDS5811BB power cord is good, however the dishwasher is not getting any power. No lights no nothing.
There is a fuse on power unit, that should be tested first, check also a different outlet.
Aug 09, 2008 | LG Dishwashers
Bought a Collins power recliner by home meridian from samsclub that has only half of the power supply. (It was on clearance) Where can I find a replacement power supply for it? I have searched everywh
try liftchair.com I bought a new motor and button from them. They have parts for many makes and models. I took old assy apart and found it was a defect in the wire between motor and push button. I drew a schematic of mine here is the drawing.d5ed86f4-7c9d-4a33-8615-2eb2c5fa16f7.jpg
Apr 17, 2013 | Home Meridian Fletcher Power Recliner
I have a Simply Perfect For The Home brand Microwave Oven that I bought from the U.S. Military post here in Schweinfurt, Germany for $50 I live on the economy in my own apartment. The microwave is a 120...
Just as a NOTE: When I bought my Panasonic microwave from AAFES, before I took it home, they sent it through their maintenance department to adjust the internal voltage. Power for the US is 60 HZ. Power in Europe is 50 HZ. Long Technical Explanation shortened: there's more energy (Heat) in 50 Hz than 60HZ especially when used in anything that uses high power. AAFES adjusted the internal power down to compensate and keep from blowing up the unit. Look for a fuse inside. Replace it, then ask AAFES to reconfigure the product for lower power or 50Hz.
Also as a note, many, dare I say most, clocks from the US count the HZ to count time. So if your US clock, say on your coffeepot timer, looses time overseas; it's probably losing 4 hours a day (do the math: 50 hz/60hz=83.333_%. 83.3_%*24 hr=20 hrs or 4 hours lost). So, if your time is set for 7AM coffee start, when you get that cup of coffee at 7:10AM, set your clock forward to 11:10 AM; or at 7PM, make sure it actually says 9PM. It will loose enough time by the next 7AM to be correct.
Aug 11, 2011 | Microwave Ovens
Tv sparks bad when i apply the cable cord to it
EXTREME DANGER!!!!!
PLEASE LISTEN CLOSELY:
all appliances made in the last forty years have a polarized power cord.
One pin on power plug is small and other larger--the larger goes to the neutral side of the electrical outlet.
If you get sparks when you hook up the coax to the cable fitting--only one of two possible reasons.
Either the polarized cord has been defeated (plug modified) or the outlet you are plugged into is not wired right.
Understand--it does not have to be at the set you are using---if somewhere else in you home a cord is defeated or an outlet is bad--it will feed the problem via the coax to every other set in the home connected to the same line.
What you are seeing if you get sparks is the coax fitting has 120 volts AC getting to it either by the coax or from the power outlet--
The easy way to find this is disconnect all coax connectors in the home and with a voltmeter hooked to a earth ground (like a ground rod or pipe made of metal) measure for AC voltage to the coax.
THIS IS A VERY DANGEROUS SITUATION-BE VERY CAREFUL--
If even one set or outlet is bad it will feed this via the coax to all sets in the home---I have seen this before-yes it can destroy a TV! but it can also hurt or kill someone--this is the reason all power cords are now polarized.
IF YOU HAVE ANY QUESTIONS ASK ME--IF IN DOUBT HAVE AN ELECTRICAL EXPERT CHECK THE WIRING AND MEASURE FOR AC VOLTAGE TO THE CABLE--ac voltage can kill--it is the same as connecting a wall outlet to the exposed areas of the set.
THIS IS SERIOUS STUFF--DO NOT TREAT IT LIGHTLY!
SD TECH
Dec 19, 2009 | Samsung PN50B450 50 in. Plasma TV
Delphi Skyfi2 won't turn on anymore.
I have the Skyfi 2 with car cradles. I have had them for about 7-8 years. I bought two brand new power cords to use with the cradles so I could move the Skyfi 2 to different vehicles. Neither power cord will power up the Skyfi 2 when in the cradle. I contacted the company I bought them from and they sent me two more cords. These cords are brand new as well. They too do not power the unit. My original power cord still powers the unit but I am trying to eliminate having to move it to each vehicle. I then bought a complete unopened kit from ebay. Using the new kit parts only, my Skyfi 2 will not power up. Did they change the kit since I bought mine and now it is not compatible. Everything looks identical so it is driving me nuts. Any help is appreciated, Thanks!
May 29, 2009 | Delphi SKYFi2 SA10101 XM Radio Receiver
Won't stay on when plugged in. Battery? Power cord is new, could it be the power port on the computer?
Hi !
It might be your power adaptor !
I am not sure, but usually it should have a red/yallow led while charging and green when charged !
Read your manual.
Also, check power settings in control pannel.
There, you can find power schemes that turn off your laptop automatically when some time pass.
Set NEVER when plugged on power!
Check screen saver settings (and turn it off - NONE)
Also it should not turn off if there is any user activity!
At the end, if you are sure that there is no problem with your power unit, than checking and setting power OPTIONS in control pannel, should solve your proplem.
Regards.
Apr 21, 2009 | Sony VAIO Notebook
Scpt960- i am not able to open the disc
Try cold start.
Power off main set manually by press power button on main set.
Unplug power cord from main set.
Wait for about 5 sec.
[Without plug in power cord] Press and hold "Power" button without release it.
Plug in power cord (must have power) to main set by using another hand [while another hand still press on main set power button]
Keep holding until u see ------ on main set FL display.
Then release you hand which just now pressed on main set.
Power on main set again by manual press power button on main set.
Result should be OK (unlocked)
May 25, 2008 | Panasonic Home Theater System System
AC Adapter
Hey thats one of two things your (internal charging unit) if so your SCREWED if not its the sowtware issue witch means you gotta tweak the settings especially if you just upgraded your OS if tweaking doesnt work then re-install your OS then set your OS setting Correctly to the best of your knowledge have fun...it take a bit of patience and a couple hours i had the same prob.....seeya
Oct 28, 2007 | Dell Inspiron 2200 Notebook
Home plug in power cord
I would suggest Radio Shack or similar local electronics store that specializes in electronics for hobbyists(meaning Best Buy and Circuit City would not be my first choice). The trick will be to match the output voltage and amperage, which should be listed on the label attached to the unit (sometimes on the bottom) or listed on the old home AC adapter if you still have it. The other thing to keep in mind is the size of the plug connector which the adapter uses to connect to the unit. Take the unit to Radio Shack and they should be able to figure out which AC adapter is right for your unit.
Aug 22, 2007 | Durabrand Portable DVD
Hitachi P50H401 50 in. Plasma HDTV Logo
126 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
