Question about Car Audio & Video
Problem with pickup on guitar washburn d46
Hi I bought a used guitar washburn d46 with a lr baggs pickup 3.2
When I plug the cable into the amplifier the sound is very low even if my battery is new and even if the sound and the gain on the guitar and on the amplifier is to the maximum.
What is the problem with my guitar
    Genius:
  • 1,139 Answers
Hello woizo,
The windings of the pickup might be bad. Basically these are magnetic pickups that take the string vibrations and by using transducers converts the vibrations into electrical energy and the by using preamplifier's and finally a main amplifier it takes the electrical energy and then turns it into sound. It sounds like in your case the pickups need to be repaired or replaced.
Now I would check the amplifier first and the run a test on the output of the guitar to make sure the potentiometers (volume, tone, etc) are ok. If these are ok then I would really suspect the pickups.
I hope this helps,
Thank you,
Shuttle83
Posted on Apr 22, 2008
A high pitched ringing through the PA associated with strumming
You are proabably getting regeneration. This is nothing more than feedback as these acoustic guitars are good microphones. Make sure the guitar CANNOT "hear" the speakers of the PA system. Crank the high frequency EQ for that channel all the way down. This is common when soundment decide they ALSO need to boost the high frequencies of the PA up when they shouldn't. Regeneration is a feedback that is below that to fully sustain, but will cause a ringing "tail" on notes.
Sep 10, 2011 | L R Baggs Lr Baggs Imix / I-mix Acoustic...
Sometimes pickup doesn't work depends on what amp I use. Thanks, Ed
These pickups have a very high impedance so you must run into a high impedance input. Many amps expect low impedance guitar outputs and these piezo pickups just can't drive them.
We currently use an X2 wireless system which has over a 1.5 megohm input impedance which works well with these piezo pickups. Long guitar cables degrade the signal as well and running into a DI just won't work.
Mar 12, 2011 | L R Baggs Violin Pickup W/ Carpenter Jack...
The light is constantly on on my LR Baggs - elemejnt on board system in my Larrivee quitar
You've definitely got some wires crossed in there. The light shouldn't come on unless a cable is plugged in (I'm assuming it's not.....it if is, unplug it!). My advice would be to take it to your local guitar tech and he/she will be able to tell you what's going on.
Mar 01, 2011 | L R Baggs Eas Element Active Acoustic...
Short battery life with imix system
It is important to turn off the battery when not in use... they may have a switch OR often when you plug the guitar cable into the unit that completes the circuit to the battery. Another thing the 9 volt batteries are not the greatest. With continuous pwer I would expect the battery to last a couple days. Remember that the devices that have a pushbutton to alternately turn on the device DO still place a small current drain on the battery... For those devices REMOVE the battery when unit is be idle for a week or more.
Feb 12, 2011 | L R Baggs Lr Baggs Imix / I-mix Acoustic...
I have the LR baggs Element Active VTC in my Seagull. It works fine, except when I plug it into the PA system at church. There is a windy, rumbling-type sound that happens whenever the volume knob is...
In the first place you CANNOT connect your guitar directely to the snake ! You must use a DI box to convert the unbalanced output of the Baggs to balanced (differential) drive to the snake using either XLR or TRS cable. The DI should be driven as a HIGH impedance in and using "ground lift".
If the pots are noisy, lube sparingly with CRC 226 available in the electrical dept of Home Depot in a spray can with spout for about $2.70. Spray using the spout into the side where the leads go into the pot.
The volume pot is overly sensitive because you are overdriving the mixer at the other end. The trim on that channel of the mixer probably has to be reduced as well.
Dec 23, 2010 | L R Baggs Eas Element Active Acoustic...
I have a washburn rr 2v and when it is plugged into an amp there is no sound but all the wires are connected in the back and the pickups are still magnetic
Here are some things to check:
- Are all volume controls turned up 1/2-way? - Try a different guitar patch cable. - Does your amp have remote switchable inputs? Is your guitar plugged into the *active* channel on the amp? - Is the amp turned on?
Feb 15, 2010 | Washburn X10 Electric Guitar
How to get the best sound
punk and metal tones (late 80s): treb-7 mid-6-7 bass 6-8, presence 6-10, gain/distortion all the way up. classic rock just turn down the gain/distortion to 6-7. bridge pickup
metal mid 90s & up: treb 6-7, mids 3-5, bass 7-9, gain all the way up, presence (which is a mid and treble boost) 4-6. bridge pickup
blues SRV: treb 6, mid 6, bass 7.5, presence 8, gain 5, reverb (if you got it). use your neck pick up
of course this is subjective and depends on the guitar, cable quality, etc. it looks like a small speaker with a low watt output. that little speaker in there is going to be hard to articulate any tones. more than likely it will have a harsh bit to it cause the value of the pots and the logarythm you hear. reduce treble as needed to smooth out the harsh, keep the mids up.
Nov 02, 2009 | Washburn Amplifiers: 25 WATT Guitar...
I need a wiring diagram for a 1986 strat style washburn guitar with humbucker and two single coils pickups. three toggle switches and a volume and a tone knob
Hi vallast
Here is a diagram on how to wire your 3 toggle setup.
3cd7a58.gif There are endless variations on how to do it. Pickups can be switched in and out of phase, in parallel or series.
Check out here for more details on the above wiring diagram.
Strat style wiring is done with a 5 way switch generally. Using the toggles allows you to rephase vitually all the pickups getting heaps of different tones. Thanks for using FixYa, good luck. A decent guitar Tech can easily help you to rewire your Axe. If you get stuck. hit me back here and I will help you further:) Cheers.
regards
robotek
Apr 13, 2009 | Audio Players & Recorders
Guitar Problem I Think.
First check your guitar to amp cord.
The pickup, audio jack, or pickup selection switch may be defective.
Nov 04, 2008 | Washburn Amplifiers: 25 WATT Guitar...
I have not played my electric guitar for months now there is no sound coming through the amp, the amp works ok
probably have active pickups on the guitar.
if there's a plate on the back, get a small phillips screwdriver, take the plate off, and put a new 9 volt battery in.
Oct 14, 2008 | Washburn Amplifiers: 25 WATT Guitar...
Car Audio & Video Logo
189 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
