FixYa.com
Tags:
Jetway AMD V400DBL KT400 ATX AUDIO LAN Motherboard
MEMORY DUMPING.....
posted by KIKXZ on Apr 13, 2008
BLUE CREEN APEARS , FOLLOWED BY AUTO RESTART.
comment for this BLUE SCREEN error ...." if this is your first time to see this stop creen error, restart your computer....CHECK if you have installed hardware or software....consult your hardware/software manufacturer.....check for harware updates...ect....
i have removed every single PCI hardware device devices including external devices, lan connections disabled and still THIS BLUE SCREEN apears...
Please help me....
KIKXZ of BAGUIO CITY PHILIPPINES
kikxz_jr@yahoo.com
Comment by KIKXZ, posted on Apr 22, 2008
dileep007,
F8 ...SAFE MODE.. &...LAST KNOWN CONFIG DEED GOOD
SHOWED ME WHAT THE PROBLEM WAS...
PINNACLE AV/DV E4 CANNOT FIND DRIVER FOR THIS....
MULTIMEDIA DRIVER NOT FOUND (ERROR STATE)
I TRIED REINSTALL DRIVER...NOTHING HAPPENS.....(ERROR STATE) ROLL BACK DRIVER....NO DRIVER FOR THIS DEVICE WERE INSATALLED ON THIS COMPUTER...
I TRY TO FORMAT AND RE INSTALL EVERYTHING.....
DID NOT ASK FOR PINNACLE AV/DV E4 DRIVER
FOR 2ND TIME INSTALLATION....
I CHECK THE PROPERTIES
FOR THIS DEVICE AND SAID
(THIS DEVICE IS WORKING PROPERLY)
...ALL WORKS FINE NOW.... 7 DAYS IN COUNTING
THANKS DUDE...!
"KIKXZ" BAGUIO CITY PHILIPPINES
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Apr 13, 2008
Helpful (85)
dileep007
Rank:Wiz Wiz
Rating: 85%, 426 votes
go to safe mode(by pressing f8 before the OS loads ie at the starting of the system) and uninstall the software which you have recently installed due to that there is some conflict....
uninstalling that & by rebooting will solve your problem..
if problem persists then press f8 and select last known good configuration....
then it will work...
if problem persists then go to safe mode & give system restore to some previous date...
after system restore 99% it will surely work
but in 1% if problem persists then just reinstall the operating system.....
any doubts reply me
i am always here to assist you
thank you
bye...
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Motherboards problems?
Motherboards
mother board jumpers setting
sis mother board jumper setting... Answer This...
Motherboards
disque cod?
Bonjour,j'ai un probl?me avec... Answer This...
Motherboards
soundcard aspire m1620
i have an acer pc and degrade... Answer This...
Motherboards
motherboard drivers fo intel...
I cant find any motherboard... Answer This...
Repair Service
Find Motherboard Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
