Question about Whirlpool Duet GHW9150P Front Load Washer
Leaking My washer has been making a sound like ball bearings rolling around. Today it flooded my house. I'm not sure where the water is coming from. It sounds like it's below the washer. It is only 2 1/2 yrs old.
  • 96 Answers
Flooding like that usually means a bad drain hose or bad hose connection either at the bottom of the basket or at the drain pump. Need to check both.
Posted on Apr 13, 2008
What is causing a whistling sound when the lg dish washer is in wash or rinse cycle but not when emptying wash or rinse water?
This does sound like the problem caused by the washer motor front bearing. The sound is more a whining sound. The bearing is of poor china quality and does start giving problems due to the water seal of the impeller that has the smallest water leak. The drop of water ends up on the front motor bearing causing the bearing to eventually pack up. You need to replace the water seal that is in the plastic impeller housing. Also replace the front motor bearing and this bearing is relatively cheap. Not necessary to replace the complete motor and impeller housing. Just the bearing (number 608) and the water seal (impeller housing includes seal)
Oct 09, 2014 | LG Dishwashers
Noise during high speed spin cycle
sounds like the bearings need replaced, when replacing bearings you need to replace all of them to ensure proper function and life longevity.
Dec 11, 2007 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Water is coming out where the cleaner is suppose to siphon from. Do you have a schematic of how that port should be , i.e the small spring and the bearing?
If water is coming out, then you just need to reverse the spring and ball bearing (swap them around). Right now, the spring is where ball bearing should be and this is keeping the ball bearing from seating against the o-ring inside. Shouldn't take more than a few minutes. Usually, the small end of the cone spring goes against the ball bearing.
May 07, 2014 | Coleman Garden
GE adora front load makes loud rattling sound in spin cycle. nothing in drum. sounds like a ball bearing
its the inner baskets bearings behind this basket as water gets past the rear seal into these bearings and ruins them,you need to dismantle the entire unit to remove the inner basket from the outer tub to replace these bearings
Oct 27, 2012 | GE WSXH208A Front Load Washer
How to Replace Bearing Ball on a LG Front Load Washer??? The bearing ball is leaking water and makes loud noise. need to fix problem please help.
The rear half of the outer wash drum (which contains the rear bearing and tub shaft seal) needs to be replaced. On a 1 - 10 scale, this rates a difficulty rating of about an 8. An experienced appliance tech can do it in about 2 hours, and hit you up for about $500. I do not suggest this as a do it yourself repair. Did you know that the new LG machines use a balance ring to make them much smoother running? (Hint: It may be wiser to replace the machine.)
Jul 04, 2010 | LG WM-0532HW Front Load Washer
How to replace the Bearing Ball on A front load LG Washer? The Bearing Ball on My Front Load LG Washer is Leaking Water and also the tank makes a loud noise while its running. I would like to know how to...
main drum bearing is pressed into the rear outer drum 1/2. you will need to replace that part. hopefully, the motor isn't damaged by the leaking water.
Amana ALW480DAW top load washer 9 yr old
You're not done yet. The washer pump probably is leaking. Lots of basements being pumped out in this area as a result of the snow.
Jan 16, 2018 | Amana ALW480DA Top Load Washer
Something rattling under the drum
Strangely enough, I found the problem to be in the motor. If the noise becomes pronounced during the high speed spin cycle, then that is the problem. I had a repairman out for mine and they wanted to replace the drum, however when I took off the back and removed the belt, I could turn the drum separate from the motor and could hear that the problem was in the motor bearing, not the drum. Hope this helps.
Nov 18, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite Washer (He3t) front load
The bearing in the duet is attached to the outer rear tub of the washer. You have to remove the whole rear half of the outer tub. Take off the back and you will see all the screws around the tub where they attach together. you have to buy the whole rear half too. They wont let you replace just the bearings.
Agitator is making noise
bearings in the transmission are going out. they are fairly cheap if you can change them yourself.
Mar 29, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
90 people viewed this question
Dan Webster
Dan Webster
Sal De
