Question about Concept CM-1100DR 11.2 in. Car Monitor
No picture my monitor stopped working. when i open the back you can see there is some type of transistor burned out. unfortunately it also burned out the transistor part number. how can i find out the #, or should i send it to fix. it's like i can't find anyone here in virginia beach, va that does these repairs.
    Problem Solver:
  • 12 Answers
Get a hold of concept via there web site and they should be able to help you with a local repair place or at least you can send it to them and have it repaired.
Posted on Dec 10, 2008
The monitor has no picture at all and the light goes from green to yellow
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for:
Post back what you see inside so we can guide you further and it will help out other people in the future also.
May 20, 2010 | Planar PL1910M (Black) 19 in. Flat Panel...
P61940 Sound but no picture
Could you gives us more info on how or from where you get the video source to your TV?
Jul 04, 2008 | RCA P46921 46" Rear Projection Television
My viewsonic vx2235 has a blue light on but no picture at all. Can i still use this monitor? I really dont want to buy another one so i am hope that i can just replace a part cheaply. Theres power but no...
Assuming your cable is good & your PC (video card) is properly functioning & everything is plugged in correctly,;
If the screen flickers a bit when you start it, then the problem may be in the power circuits. Open the back & look for burned components on the circuit board. (capacitors, fuses, resistors, transistors, whatever.)
If it does not flicker then the bulb is likely burned out.
ALSO: you should read this guy's experience. ---->
Sep 05, 2009 | ViewSonic VX2235wm LCD Monitor
No picture on monitor
The Q7 has a tendency to burn up transistors and a high voltage capacitor on the one half of the inverter board which is part of the power board.
I have repaired 1/2 dozen of these with that problem.
Only way to tell for sure would be to open it up and look at it.
If you can do that and send me a picture to, I may be able to confirm this.
The other possible problem could be a bad bulb, but since it is fairly new ? that is probably not the issue.
Jul 20, 2009 | ViewSonic Optiquest Q7b Flat panel TFT 17"...
Color problem
Hi, it is more likely from an open green and/or blue picture tube's electron gun transistor driver.
If you have an experience on electronics / or use of solder gun, you can just open your monitor and look for the electronic board at the back of the picture tube. Take a look in all transistor ( components with three legs) and solder / check if their legs are not fully soldered to the board. Note: just be careful on the high voltage diode / line ( the one with a thick (like the car distribution wire cable) single wire going to the tube). good luck
Dec 19, 2008 | IBM E74 17" CRT Monitor
Power transitor for 17ince dell monitor
purchase new transistor of original company duplicate transistor may heat and burn solder the capacitor of same value solder fuse and better to work on series lamp protect from burning if transistor burn again then check zener and replace if faulty
Nov 12, 2008 | Dell (TR-142M4TD) CRT Monitor
Viewsonic va1912wb monitor goes blank for few seconds and comes back and this happens very often
Your power/inverter board needs to be overhauled.
Your capacitors on the board are probably burned out.
If you open it up and send me a picture , I may be able to tell you if they are or aren't.
There is also a chance a transistor has gone bad on the board.
I repair many viewsonic boards on ebay
Oct 21, 2008 | ViewSonic VA1912wb Monitor
Tv screen not working
will buy your non operating fujitsu p55xha40us i have one with a broken pdp glass please e mail
Jan 05, 2008 | Samsung LN-R328W 32 in. HD-Ready LCD...
AOC 5En monitor
replace new moitor....
Nov 13, 2007 | AOC CT720G 17" CRT Monitor
Horizontal scanning does not work
You have high voltage. Horizontal sweep is not working. Mostly we see shorted sweep transistor. Mike
Jul 03, 2006 | iiyama Vision Master Pro 510 22" CRT...
Concept CM-1100DR 11.2 in. Car Monitor Logo
110 people viewed this question
Top Concept Car Audio & Video Experts
jamie suver
Level 1 Expert
Robert Rankin
Are you a Concept Car Audio and Video Expert? Answer questions, earn points and help others
