Question about Hotpoint NVL333EY Electric Dryer
Hotpoint NVL333EYOWW mfg 9/99
This dryer has developed a sudden 'no-start' problem. I tested the wall current first, then door switch, then start switch, then belt switch. All test ok. I suspect the thermal switch. I would appreciate any/all ideas to repair this dryer. thank you in advance for any help you may offer.
I encountered the same problem. Turned out to be a blown thermostat, caused by too much moisture from the washer not spinning the delicate cycle enough and / or oversized dryer loads. Cut your load sizes in half and avoid using delicate cycles for cotton items. Very easy fix, Prices in the Midwest range from 30 to 40 USD. Godspeed.
Posted on Apr 28, 2008
Hotpoint dryer (nvl333eyoww) not heating
The thermostat and element are mounted on the back wall of the dryer. To gain access you must remove the drum. Here is my home movie:
My home movie and repair photos for GE hotpoint dryers
Dec 02, 2012 | Hotpoint Dryers
CTD85 tumble dryer: power is getting through to the machine but absolutely nothing happens
Hi.
If there is power then the door switch is probably broken. first make sure that there is power to the machine. The door switch is tested with power off, accessing switch contacts and reading Ohms with a multimeter. When door is closed the switch must have continuity, reading zero or few Ohms. With door open the switch contacts read infinity (circuit open).
If the door switch is OK, test power cord, main switch, wiring harness, motor and timer.
Here diagrams. Click on the pictures to enlarge:
This is a link to all the spare parts available for your Hotpoint ctd85a tumble dryer.
See also : Tumble dryer Video tutorial help.
Sep 18, 2011 | Hotpoint Dryers
Don't know how belt should run around tension pilley. model #NVL333EYOWW SERIAL# MZ710945W
first row far right, good luck Tim:
http://www.applianceaid.com/images/belt-config.JPG
Mar 13, 2011 | Hotpoint NVL333EY Electric Dryer
Hotpoint dryer nvl333eyoww, Motor runs, heating
Did you ohm out the thermal overload?
May 18, 2009 | Hotpoint Dryers
Hotpoint Dryer Heater stays on when door is opened
Strange. Heaters usually shut down with the spinning drum when door is open. If you check the schematic for unit you can check to see if in fact this is correct operation. Attached site usually has schematics for appliances. You might want to check. Search Over 2 1 Million Appliance Parts
Sep 01, 2017 | Hotpoint NVL333EY Electric Dryer
Hot point model nvl333eyoww will ot dry clothes
your dryer has a belt switch go here to see it www.repairclinic.com once there enter your model # and it will show you your parts
Mar 10, 2009 | Hotpoint NVL333EY Electric Dryer
You need to check the heater element and or thermostats for continuity. You will need a meter to do this
Replace if found to open circuit.
Plz rate this solution.
Thanks.
Dec 17, 2008 | Hotpoint NVL333EY Electric Dryer
I have a Hotpoint Electric Dryer Model Number NBXR453EVOWW, It quit all of a sudden and will not turn on.
raise top ck thermal fuse on element housing on rear wall top right side..also possible door switch ..if you have already verified breakers ok and unit has 220 volts
Jul 15, 2008 | Dryers
Hotpoint NVL333EYOWW electric dryer
If it doesnt run at all its nothing to do w the thermal aspects at all. The motor would run regardless just no heat. Check all paths electrically to the motor and be sure to check the motor itself.
Apr 13, 2008 | Kenmore 62882 Electric Dryer
HOTPOINT NVL333EYOWW sudden no start
Thermal switch is on the top in the back on the right side as you are facing the dryer. Pop the top off and voila, easy fix.
Apr 13, 2008 | Hotpoint NVL333EY Electric Dryer
Hotpoint NVL333EY Electric Dryer Logo
153 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
