Question about Microsoft Xbox 360 Console
IP address Can anyone help with fixing the IP address failed problem. It won't let me connect to Xbox live because something is wrong with connecting to the IP.....
  • 2 more comments
  • Anonymous May 11, 2008
    I NEED HELP
  • judy35 Jul 19, 2008
    i can get my xbox360 live to read my ip address
  • irving10 Jul 19, 2008
    cant go to xbox live because of my ip adress
  • Anonymous Dec 31, 2008
    mine is the same though im using a ethernet cable i would be pleased to hear a response thank you
  • 81 Answers
Try this fix:
http://xbox360help.blogspot.com/2007/04/ip-failed-xbox-360-live-test.html
Posted on Apr 13, 2008
My Zonet ZSR4134WE Wireless-N router doesn't connect to live. I've checked the MTU setting and everything. It works perfectly, until it gets to the "Xbox Live" part of the test, then it fails. Please help.
you need to open the ports on your router for xbox ports are TCP 88 UDP 88 UDP 3074 TCP 3074 UDP 53 TCP 53
first connect the xbox to the network and get the ip address (like 192.168.x.x) and then use the computer and login to router setup page and under firewall open these ports for the ip address of xbox . If you find a DMZ there , then enable it for XBOX ip address and reboot the router. ** imp: try to make a static ip address on xbox so when you restart the xbox teh ip address should not change -
to check what is the ip address provided from you router :- go command prompt (start ->run- > type cmd and hit enter) a black screen(command) type ipconfig you will find ip address of computer , so you can set the ip address of xbox like that -but just make the last number different (like ip address on computer 192.168.2.5 then make ip address of xbox to 192.168.2.6) perform this will help .. its all about the ports but be sure with ip address
Oct 01, 2010 | Zonet ZSR4134WE Wireless Router
Failed Ip adress for xbox live
First i want to know how is your xbox 360 connected to the internet? For example ( Modem Connection?, Router Connection?, Or Wireless Connection?
Here are some steps that you need to try:
1. Turn off your cosole wait for 20 seconds and then turn it back on, then test your xbox live connection
2. Go to your network settings
3. Select restore to factory defaults and test your xbox live connection
Apr 03, 2009 | Microsoft Xbox 360 Console
My adapter is Wired but my IP address Fails :(
I am not sure how to fix it through multi-wired interned but the best way to get connected to the Xbox Live is to give it a direct access to the internet.
Try to look into your manual you got with your Xbox and find how to connect it through other means than direct access.
In the meantime, before you find a way - your best bet is to just take your internet cable that is connected directly to the modem and connect it to the Xbox.
Dec 31, 2008 | Microsoft Xbox 360 Console
Xbox live is not working
How are you connecting Your Xbox console upto your Internet ? if your Connecting Via WiFi, Make sure you have the Xbox compatible WiFi adaptor, if you are connecting Via a Local Area network, Ensure that your Console is hooked up Directly to Your Router, and if your connecting Via a Shared internet connection thru a PC, Ensure it is Hooked up correctly and also that your computer is set up to allow sharing the internet connection, That sometimes makes Xbox live faulty.
Also another problem for IP addresses not working is Due to your Internet service provider, Some broadband companies constantly renew IP addresses changing them every so often which the Xbox doesnt like. I would suggest contacting your Service provider and seeing if they have any Technical Support !
Oct 27, 2008 | Microsoft Xbox 360 Console
Ip address failed
I think you need to ring your internet provider and they will enable xbox live from their side. Its fairly simple and they will know what your talking about.
Oct 20, 2008 | Microsoft Xbox 360 Console
Linksys wrt54gs router and Xbox live
make sure that internet connection working fine first..if it is connect you xbox via wired or wireless(if wireless, make sure that you connect to your own wireless network and enter the wireless security if there is)...check if you can get an ip address, better set to obtain the ip address and dns of your xbox, if all set and still unable to access internet, access the linksys router setup page by typing 192.168.1.1 on the address bar of your internet explorer, when pop-up for username and password type admin under password, leave it empty for the username. Click administration tab and disabled UPnP. Check if your X-BOX working fine. Hope this help you.
Sep 29, 2008 | Linksys Wireless-G WRT54GS Router...
Xbox live cant connect mtu failed
Hi can you please help me i was on xbox live tryed to connect with a router and now my 360 is askin for an ip address,but we do not no it can you please help thanks Paul
Aug 02, 2008 | Microsoft Xbox 360 Console
Ip address failed
If you are behind a router.. try hooking it up directly to your cable modem or DSL modem. If that fixes the problem then you need to open ports on the router to allow the connect to get routed to your xbox.
http://support.microsoft.com/kb/908874
Jan 18, 2008 | Microsoft Xbox 360 Console
Get go to xbox live
For some reason everyone has the same problem buy the Xbox 360 wireless kit and should work but for now you might as well just wait untill get its fixed
Dec 30, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
90 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
