Question about Samsung ML 2010 Laser Printer
Printer makes a loud clicking noise
Printer starts grinding (clicking) really loudly when I try to print something.
  • 1 more comment
  • bevusr10 Jun 14, 2008
    Hi
    I have the same problem when i try to print I get a loud clicking noise. I know its not the crtridge because i have changed that. Unfortunately I can go no further because I cannot see what's going on when the printer is closed up.
  • envance Apr 18, 2009
    My ML2010 makes a noise like a machine gun when it's switched on.
    Did you resolve this problem?
  • Anonymous Apr 30, 2009
    Got the same problem. it then starts pulling a paper in and then stops.
    I heard that i must install new drivers, but that doesn't help either.
With power cable removed, I had to unscrew the plastic covers, then metal plate on left side of printer to get to white plastic gears. When I pulled the metal plate away slightly, I heard something fall inside the printer. After shaking the printer a little bit, one of my son's tiny lego pieces fell out. When I reassembled, the printer works like new.
Posted on Sep 12, 2010
I decided to try and sort this out and I removed the toner and started digging around (with the power lead out...). I discovered a small plastic cap from one of my kids toys jamming the mechanism up. I removed it and fired it up and it's been fine ever since.
Thanks for the above posts.
Posted on Feb 25, 2010
I had exactly the same - loud clicking noise from the gears on L/H side, and discovered a small bit of wood had somehow ended up in the same place as the above illustration. Removed and instantly cured. Well done to pabben!
Posted on Jan 30, 2010
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 3 Answers
Same problem after a paper trapped. I don´t know if the paper trap was because something broke, but after I took the paper the noise started. Please someone give us a solution.
Posted on Sep 10, 2009
  • Pablo Benitez
    Pablo Benitez Sep 11, 2009
    Solved, It has a coin that moved out one part of the printer. Now I have to resolve the printer not taking the papper problem.
  • Pablo Benitez
    Pablo Benitez Sep 13, 2009
    An image of the problem.
Hp 1018 printer making really load grinding noise and not printing
ok first try restarting your printer, then try uninstalling the driver for your printer off your computer, restart your computer and printer and then reinstall your drive for the printer, see if you get a replacement for your printer or a refund
Dec 01, 2014 | HP LaserJet 1018 Printer
HP Color Laserjet 8550 - Loud grinding noise near fuser
Hi Harden,
Thats an issue with the fuser assembly,try to check the teflon condition/ teeth gear might have worn out.
Jan 30, 2014 | HP Color LaserJet 8550dn Printer
Printer HL-3070CW - LOUD Grinding noise when it seems to be running large print offs. It is almost like it gets too hot
My 3070CW makes the same noise. It is caused by the transfer belt. One roller is driven by a cog and this goes fine. The other roller has a tensioner and this roller is making all the noise. While the noise is really loud and annoying - it is completely harmless. Hope this helps.
Aug 09, 2011 | Brother HL 5250DN Laser Printer
My Dell 2135cn printer all the sudden started making crazy loud grinding noises. Then I got a paper jam. I fixed the paper jam and tried to print again, but got the loud grinding noises and paper jam...
Refer to the service manual in disassembling the device.. Clean it thoroughly then try it again.. If, you have no experience in doing so, hire a qualified tech to do so.
Jun 17, 2011 | Dell 2135cn All-In-One Laser Printer
Why Samsung CLP-300 Printer making annoying/loud clicking noises?
So try to get the black toner cartridge out of the Machine. On zhe backside of the Cardridge is a gear. Try to turn the gear, maybe the Toner inside is clump together. When you can turn it very easy in both directions it's fine.
Oct 19, 2009 | Samsung CLP 300 Laser Printer
Lexmark C510 is making grinding noises while printing large jobs
I found another posting stating that the culprit was the black toner cartridge. Sure enough I changed our black cartridge and the grinding noise has stopped. No wonder the grinding noise was not happening all the time only when the black cartridge got low. Thanks for the help!
Oct 15, 2009 | Lexmark C510 Laser Printer
My external hd makes a constant, loud noise
Back up your files and buy a replacement drive the grinding noise is the hard drive experiencing mechanical failure and may stop working soon.
Oct 08, 2009 | LaCie Computers & Internet
Makes noise
Click HERE for HP troubleshooting for your printer.
Jun 06, 2008 | HP Officejet 5610 All-In-One InkJet...
Loud grinding noice before starting to print
Mine makes a grinding noise when scanning or making copies. As long as everything is working, I just tolerate the noise in which the rest of the staff find amusing at first and then ignore it as I do.
Jan 25, 2008 | HP PSC 1210 All-In-One InkJet Printer
Printer makes noise while cleaning heads
Grinding noise is most likely caused by the carriage lock getting stuck and holding the print head at the home position. The noise is caused by the toothed belt that pulls the head back and forth, skipping over the splines on the motor drive wheel. If you have been able to print since the problem occurred, chances are that it has freed itself up and will be fine. Regarding the loss of cyan & magenta output, follow the solution given in my previous posts to complete a manual under-head cleaning cycle. This should get you going. Check this previous post for cleaning info: http://www.fixya.com/support/t137335-problem_print_outs_from_printer
Jul 05, 2007 | Epson 1000 ICS All-In-One InkJet Printer
Samsung ML 2010 Laser Printer Logo
1,110 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
