Question about Hotpoint NVL333EY Electric Dryer
HOTPOINT NVL333EYOWW sudden no start
I checked the wall current. its ok. I checked the start switch w/ dvom- it works. I checked the door switch- it works too. Since several people have had problems with the thermal switch, I wonder if that is my problem also. Please advise where the thermal switch is located, how to test it, and if bad how to replace it. Any info on part price and sourcing would also be appreciated. Email: I_M_BT@hotmail.com or phone 714 six -o-six- 9358
  • pwchambers Apr 25, 2008
    Dryer was working fine. Stopped it and added clothes ad it wouldn't start again. Just makes a humming sound when you hold knob to start
  • 4040 Jun 02, 2008
    same problem
Thermal switch is on the top in the back on the right side as you are facing the dryer. Pop the top off and voila, easy fix.
Posted on Apr 28, 2008
1996 cavalier 4 door. can't unlock door from either inside or outside
I assume you mean the power locks.
This will require you to do some electrical testing, if you have a DVOM, you can figure this out. It is more than likely a bad switch and you will just have to replace it. However, it may be a blown fuse or an open somewhere in the circuit, try checking the fuses prior to anything else. They will be located in the interior fuse block. If the fuse is ok, remove the door lock switch and test for 12v at the connector with the dvom, if you find 12volts, replace the switch, if not, start tracing the wiring through the vehicle.
Sep 15, 2015 | 1996 Chevrolet Cavalier
Hotpoint aqualtis aqxxf149hpi is showing a error h20
Check tube to water pressure switch. The wall of the rubber tube on my machine had worn through due to friction. Taped it up to make sure this was the problem. No H2O code and machine working!
May 27, 2014 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint dryer (nvl333eyoww) not heating
The thermostat and element are mounted on the back wall of the dryer. To gain access you must remove the drum. Here is my home movie:
My home movie and repair photos for GE hotpoint dryers
Dec 02, 2012 | Hotpoint Dryers
Hotpoint aquarius wt540 no power in machine no light at switch
Hi, check the following trouble spots below. you will find the issue in one or, all the areas stated.
1. No power to the washer
Make sure there's power getting to the washer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the washer, if this is the case, the wiring must be repaired or replaced.
2. Lid switch/door switch
The washing machine may not function if the lid switch or door switch is defective. The switch is usually located near the door. Replace if found defective.
**If you are getting power to the washer and, step 1 and 2 check out ok, replace the timer control and start switch as well.(You can test the continuity or, resistance level of the Lid switch with a multimeter(ohm).
Jul 16, 2009 | Washing Machines
Hotpoint dryer nvl333eyoww, Motor runs, heating
Did you ohm out the thermal overload?
May 18, 2009 | Hotpoint Dryers
Hotpoint Dryer Heater stays on when door is opened
Strange. Heaters usually shut down with the spinning drum when door is open. If you check the schematic for unit you can check to see if in fact this is correct operation. Attached site usually has schematics for appliances. You might want to check. Search Over 2 1 Million Appliance Parts
Sep 01, 2017 | Hotpoint NVL333EY Electric Dryer
You need to check the heater element and or thermostats for continuity. You will need a meter to do this
Replace if found to open circuit.
Plz rate this solution.
Thanks.
Dec 17, 2008 | Hotpoint NVL333EY Electric Dryer
I have a Hotpoint Electric Dryer Model Number NBXR453EVOWW, It quit all of a sudden and will not turn on.
raise top ck thermal fuse on element housing on rear wall top right side..also possible door switch ..if you have already verified breakers ok and unit has 220 volts
Jul 15, 2008 | Dryers
Hotpoint NVL333EYOWW mfg 9/99
I encountered the same problem. Turned out to be a blown thermostat, caused by too much moisture from the washer not spinning the delicate cycle enough and / or oversized dryer loads. Cut your load sizes in half and avoid using delicate cycles for cotton items. Very easy fix, Prices in the Midwest range from 30 to 40 USD. Godspeed.
Apr 13, 2008 | Hotpoint NVL333EY Electric Dryer
Hotpoint NVL333EYOWW electric dryer
If it doesnt run at all its nothing to do w the thermal aspects at all. The motor would run regardless just no heat. Check all paths electrically to the motor and be sure to check the motor itself.
Apr 13, 2008 | Kenmore 62882 Electric Dryer
Hotpoint NVL333EY Electric Dryer Logo
228 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
