Question about Sony KP-53N77 TV
Sony kp-46wt-500 tv help
The tv has double writing like when on espn the score and things at the bottom of the screen has a red background wrting just like the foreground writing. also there is some green on the left side of the screen.
  • mike699 Dec 25, 2008
    The convergence is out of adjustment. Try going into the setup menu and see if the TV has auto convergence or manual with crosshairs which you can adjust until they match and overlap to a white color.
I have a kp-53n77 sony rear projection and under the menu under setup (the toolbox icon) ther is an option for flash focus, select this and go to yes and it fixes itself!
Posted on Sep 28, 2008
    Sergeant:
    Champion:
  • 375 Answers
If your set has auto focus try activating it if not you require a convergence alignment.
Posted on Apr 13, 2008
I have a sony kp-53n77 rear projection tv i cleaned the lenses but i still have alittle to much red how can i clean up the color
Older projection set:
Not knowing exactly what it looks like I suggest two things: first in the menu look for convergence to see if it is off adjustment wise--it can be adjusted in customer mode to see if that helps.
Also either turn color all the way off (Black and white) to see what color the screen is with no color--if somewhat red you will need to turn the red screen control down--I can tell you where and how.
If screen is too red, red will be the prominent background color with color off or on.
Another easy way to LOOK is go to an unused video input---should only see "Input 1" for example in green and rest of screen should be black and not red to any degree.
Let me know with a comment here what you find.
May 02, 2012 | Sony KP-53N77 TV
Hi. On my sony 57in. tv i am getting red arched lines over the entire screen, and double images. 5 years ago i had a similar ocurrence and the tech changed a module. What is the cause ? and why again so...
2 Things can cause this Red Tube needs to be adjust down on screen drive control or you need to replace Both of your STK ICS. Sony has alot of problems with Defective Tubes.Red and Blue Shorted out the most.
Mar 24, 2010 | Sony KP-57WS510 57" Rear Projection HDTV
How can I turn Zoom off on picture? Cannot see Games Scores on ESPN.
use the perspective button on the remote. or aspect, or aspect ratio, whatever it is... it is definitely on the remote.
Sep 30, 2009 | Sony KP-53S65 53" Rear Projection...
KP-46WT510 Red lines and double vision
yes the convergence problem leaves a shadow of red or blue like an outline around the picture, sometimes part of the screen some times the entire screen.
Jun 26, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
KP-51HW40 Sony 51" Fades to blue screen
The service manual on page 8 shows how to adjust the Red/Blue/Green screen voltages. To get to the adjustment board, take the front speaker grill off (two screws at the bottom left and right) and set it aside. No need to disconnect any wires. Then remove the plywood board with 4 screws that exposes the screen/focus adjustments. The top 3 adjustments are for focus, and you need not mess with these. The bottom 3 adjustments are for Red/Blue/Green screen voltage rough adjustments. My screen showed red lines, so I had to turn the bottom right adjustment with a philips head screwdriver just slightly until the red gun retrace lines where no longer visible.
Aug 26, 2008 | Sony KP-51HW40 51" Rear Projection...
Sony projection tv double vision
2 STK- they are big and black theses are your convergence ics.
Mar 20, 2008 | Sony KP-51HW40 51" Rear Projection...
Sony 46" Rear Projection HDTV Bad Picture
Hello, I also have the kp53xbr45 and I am looking for a red bulb, where can I find one at a good price? Thanks
Feb 09, 2008 | Sony KP-53XBR45 53" Rear Projection...
Cant read espn scores
same problem...screen seems to be to long. i cannot see all objects on bottom...no solution in the menu...help plz
Dec 07, 2007 | RCA 27F530T 27" TV
My toshiba tn61x81 projection tv
have you tried the convergence option in the menu? i believe it is under "picture". this allows for nine different sections of the screen to be adjusted when projection images get out of whack.
Oct 20, 2007 | Toshiba TN61X81 61" Rear Projection...
Televison & Video Logo
111 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
