I just got a GE washer from conns storeand the model number is EWA5600GWW and i need to know can you used powder detergent it a washer
    Genius:
  • 1,073 Answers
Yes you can use powder
Posted on Apr 13, 2008
Gltf1670as1can you use powder detergent in ?
Good Morning Friend,
I understand that you want to know if you can use powder detergent in your Frigidaire washer, model# GLTF1670AS1. Below are the advised steps for the detergent dispenser of your washer.
• Add measured detergent to the detergent compartment of the dispenser drawer.
• Detergent is flushed from the dispenser at the beginning of the cycle. Either powdered or liquid detergent can be used. Note: Liquid detergent will drain into the washer drum as it is added.
• Low sudsing detergent is recommended for this washer. Use the manufacturer's recommended amount.
• If low sudsing detergent is not available, a reduced amount of regular detergent may be used. Because
reducing the amount of detergent may reduce cleaning, it is important to pretreat stains, sort carefully by color and soil level, and avoid overloading.
• Detergent usage may need to be adjusted for water temperature, water hardness, size and soil level of the load.
• For best results, avoid oversudsing.
Hope this is helpful.
-Best Regards-
WP
Jun 05, 2014 | Frigidaire Washing Machines
Should I put powder detergent in the tray or in the drum in my Asko front load washer?
But the powder in the tray. I have a asko washer myself
You should to able to go on line and download your manual
Go to Asko.com Good Luck
Feb 12, 2013 | Asko W6461 Front Load Washer
I do most of my shopping online and liquid bleach sometimes doesn't ship without breaking. Is it OK to use dry or powder bleach? I have the whirlpool cabrio top load large capacity model.
It should be okay to use dry bleach, if you follow the instructions on the bleach. Some bleaches require dissolving in water first, others can be used dry.
May 13, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
What is the partion insert for the washing powder container for?
Welcome to FixYa.
That is the Liquid detergent partition...P/N 8061633. ( part number )
**This from ASKO...
Because ASKO washers use less water than conventional top-loading washers, you need less detergent and fabric softener. We recommend that you use a low-sudsing powder detergent only, preferably a high-efficiency (HE) detergent designed specifically for front-loading washers.
**(Liquid detergents tend to suds more, which make them more difficult to rinse out.)**
Detergent - The amount of detergent needed varies, depending on the detergent you use. For high-efficiency detergent specifically for front-loading washers, you should use the amounts recommended by the manufacturer.
Also, the amount of detergent needed can vary due to differences in water hardness. (Refer to the Use and Care Guide for more details.) If you choose to use a liquid detergent, start out with a very small amount, such as one or two tablespoons.
Hope that answers your question, let me know please.Thanks for choosing FixYa for your repair solutions today. Let me know if you need further assistance.
Please take a moment and rate the solution provided for you as well as a testimony if you feel it warranted.
Good luck.
Regards,
Macmarkus :)
Oct 22, 2010 | Asko W6021 Front Load Washer
Where to put the powder detergent in the washer? how come did not dissolved?
Chances are that the washer is a front load. If it is it requires liquid detergent. If you want to use powder put it in with the clothes and not in the top detergent well.
Hope that clears things up.
ash
Vote please.
Sep 22, 2010 | GE WSXH208A Front Load Washer
I don't have a manuel
See the following Sears site for PDF versions of their manuals.
You'll have to select the right one for you washer since it appears that there are three different Model Numbers that use the same stock number.
http://www.managemylife.com/mmh/owner_manuals/search?query=45986
Jul 03, 2010 | Kenmore Elite 45986 Front Load Washer
When in wash it dosent remove all soap powder from clothes
I don't know how you are administering the soap powder to the machine..but for one, its recommended that you use detergent thats made exclusively for the front loader washer, usually says "he" on the front of the LIQUID detergent, they recommend that you use liquid detergent on top of that, BUT if you have to use regular powder detergent it must be put inside the tub and NOT the pull out detergent drawer. The reason why they want you to use liquid is because the powder detergent is not concentrated and when you use it, it lathers up alot and its harder for the front loader machine to clean out the clothes and I was told that they (sales agents) have heard of soap suds and bubble floods coming from the machine due to either using the powder detergent or using too much. Hope that this helps!!
May 15, 2010 | Zanussi ZJ1217 Front Load Washer
Detergent will not dispense
generaly the detergent tray has a "gate" that needs to be moved to the top position for powder. (up for powder, down for liquid). This is the generic answer. if you verify the model number or list the model of your unit I will attempt to locate a users guide for you.
Please take the time to give this solution a fix ya rating
clarkco
Mar 07, 2009 | GE WSXH208A Front Load Washer
Washer leaves a white film on dark cloths.
is she using powdered soap? if so shes been using too much. shell need to clean out the washer. a bottle of white vinager in a hot water wash with no clothes will clean it out. tell her to cut back on the soap. the box will say use a whole scoop. but thats just to get you to buy more soap. you only need half of that
Nov 28, 2007 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
