Question about Delstar DS 31024 MP3 Player
My mp3 player keeps saying starting and it won't stop
My player's batteries ran out and when i replaced them it just keeps saying starting. I have tried replacing the batteries and it still says starting. I have left it for 24hrs and it still says the same thing. What do i have to do to get it to work?
  • mrmarvelous Apr 13, 2008
    thats just maddeningly unhelpful
  • brina112007 May 12, 2009
    i have the same problem
Posted on Apr 13, 2008
My 1997 Suzuki Bandit600 won't start, the battery
during the battery replacement did you manage to either forget or damage a wire that powers up say your ignition module... ?
Sep 15, 2014 | 1997 Suzuki GSF 600 S Bandit
Why won't my mp3 coby player won't charge
Your coby is not charging anymore..The battery probably needs to be replaced with a new one..Please check your connection when you charge it..There should be an icon that shows your battery is charging. If it does so that means your coby is charging but your battery cant store the energy anymore.
Feb 19, 2012 | Coby MP-610 MP3 Player
I have an RCA mp3 player M4304 and the battery says full, but it shuts down and reads "low battery" after 10 minutes. Can the battery be changed? If so, how?
If the MP3 player battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced.
Jul 11, 2011 | RCA M4304 Digital Media Player
Firmware error
A) If the firmware failed to load, then the mp3 player has a hardware problem that cannot be resolved using reset, repair, or any of the other suggested methods - call Philips and see if you are still in-warranty.
B) The battery on this player wasn't meant to be replaced. Trying to do so will void your warranty. If you are out-of-warranty, take a tiny screwdriver, pop the case open, and replace it with the same type of battery listed in the product spec sheet - this spec sheet is available for free from Philips website. Before you try changing the battery, understand this:
C) 90% of the time, changing the battery doesn't resolve the issue
D) Compare the cost of buying the new battery versus buying a new mp3 player before plunking down on a new battery.
-Tha Mp3 Doctor
Mar 17, 2009 | Philips SA6025 Digital Media Player
The songs on my mp3 will not play. They appear on the screen but no sound. THere seems to be trouble with the battery.
Make sure the hold switch if off. Reset the player. Try a different USB port on same computer. Try a different computer with the same OS (to prevent formatting-related errors)  Here's some general info about the problem:  “My Mp3 player won’t turn on” or “My Mp3 player won’t hold a charge.” (POWER SUPPLY ISSUE) The tricky part about these issues is that there are several possible causes – it could be software or it could be hardware.  Before you try anything else, make sure the mp3 player’s “hold” or “lock” switch is not engaged.  See your user’s manual for location of switch/ instructions (available from manufacturer’s website).  If the hold is engaged, the mp3 player will not charge, and it will not turn on.  Then, make sure the player is plugged into a compatible computer with a USB 2.0 port.  Manylaptops and older desktops lack sufficient power resources to properly power/charge/utilize an mp3 player.  Next, try resetting your mp3 player.  If that still fails, try your device’s “recovery” button. There is a specific button that triggers the recovery mode – volume + for most players, REC button for others, play for others, and skip forward for still others.  The general formula goes something like this, although you may have to substitute another button for “volume +”: disconnect the player from the computer, turn it off even if you have to reset the player to turn it off (if it is dead, this won’t be a problem), hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player (even if it is completely dead) - it will pop up a window that says Found New Hardware Wizard. Make sure that your mp3 player is not designed for a country other than your own – this information can be obtained from the manufacturer in most cases.  European and some Asian current systems are different than in the U.S., Canada, and Mexico.  If you plug a United States mp3 player into a European wall outlet, you will fry the player.  If you plug a German mp3 player into a US outlet, it will have insufficient power to power the player.  There are transformers available that can correct for this issue. If you have lost the original charger for your mp3 player, try to obtain the original charger.  If the original is no longer available, check your product specs to get EXACTLY the correct voltage.  It may seem harmless to use a 5V charger on a 4.5V mp3 player, but in many cases you will damage the mp3 player by doing this. Also, never unplug an mp3 player while it is transferring music/files/performing a firmware upgrade (and also, never perform these activities when your player is not at least 75% charged).  This is a sure way to kill most mp3 players.  As a safety rule, always check and use the “safely remove hardware” option if it is available on your computer – lower right hand corner (green arrow pointing to chip) in most Windows taskbars.  If it is not available, wait one full minute after your last file transfer to unplug the mp3 player – even if your mp3 player says “OK to disconnect.” If your mp3 player uses AA, AAA, or any type of user-removable battery, you must take extra steps to prevent equipment damage when replacing batteries (most product manufacturers do not know this tip).  Before removing the batteries, power the player off and let it sit for one minute or longer.  Run your hand along the side of your computer tower to dissipate static electricity (or use any other method available to dissipate static electricity).  Use only and exactly the replacement battery recommended by the manufacturer.  Carefully remove the old battery.  Hold and gently squeeze the new battery for a few seconds to dissipate static.  Hold the mp3 player case in one hand, and carefully insert the new battery.  One single static spark, and your mp3 player could be history.  Also, check your product documentation beforehand to see if removing the battery will result in your song’s being erased/data being lost.  Many, if not most, mp3 players do not have replaceable batteries – the manufacturers do not have them, and popping open your mp3 player more often than not causes damage to additional components. If the solutions above do not work, and you have gone through troubleshooting with the manufacturer, you may have hardware damage and the player will need to be replaced. -Tha Mp3 Doctor
Jun 03, 2008 | Sony NWZ-S615F Walkman Video MP3 Player
System initializing
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
May 19, 2008 | iRiver H10 MP3 Player
My phillips mp3 says {Memory corruption} wat does it mean
Format your mp3 Player then re-upload your music onto it
Jan 10, 2008 | Philips SA5125/37 MP3 Player
Transfer pending, but won't start transferring
press reset button or re-flash the firmware
Jul 10, 2007 | Rio Sport S35S MP3 Player
Delstar DS 31024 MP3 Player Logo
168 people viewed this question
Top Delstar Audio Players & Recorders Experts
steve cannon
Level 1 Expert
Mister Danger
Are you a Delstar Audio Player and Recorder Expert? Answer questions, earn points and help others
