Question about Lexmark X8350 All-In-One InkJet Printer
Not printing correctly - Lexmark X8350 All-In-One InkJet Printer
  • andrewsrajku Mar 02, 2009
    The printer is printing half left side alone of a page
Prints in some areas but not the whole paper
Posted on Apr 22, 2008
Why is the text printing on Zebra LP 2844-Z label incorrectly spaced?
Zebra printers are not really made to print PDF files, if the only option is PDF I'd recommend switching to print on a laser. Also open the PDF and see if they are correct in the original doc
Oct 06, 2015 | Zebra Office Equipment & Supplies
Will not print a test page also unable to find or adjust spool settings and cannot change Priority settings. Some things will print but many items will not, even then it seems very slow.
Printing Problems
? The machine beeps while printing.
The machine may have a paper jam.
• Clear the paper jam (1 p. 13-3).
? Nothing prints.
The power cord may not be plugged in securely.
• Check that the power cord is plugged securely into the machine and into the wall outlet (1 p. 2-9). If the machine is plugged into a power strip, make sure the power strip is plugged in and turned on.
You may not have removed the plastic seal from the cartridge.
• Make sure you install the cartridge properly (1 p. 2-13).
The cartridge may need to be replaced.
• Replace the cartridge (1 p. 12-7).
? Printout does not match the print media size.
The print media may not be loaded correctly.
• Make sure the print media is loaded correctly in the multi-purpose tray (1 p. 5-4).
? Printout is skewed.
• Make sure the paper delivery slots are clear.
? Print media jams occur.
You may not be using the correct paper delivery slot.
• Select the correct paper delivery slot (1 p. 5-7).
? Printout is not clear.
You may not be using the correct print media type.
• Make sure you load print media that meets the requirements for the machine
(1 p. 5-2).
You may be printing on the wrong side of the paper.
• Some papers have a "right" side for printing. If the print quality is not as clear as you would like it to be, try turning the paper over and printing on the other side.
? Printout has vertical white streaks.
Toner may be low or unevenly distributed.
• Redistribute the toner inside the cartridge (1 p. 12-7). If the problem persists, replace the cartridge (1 p. 12-7).
Jan 03, 2011 | Canon FAXPHONE L80 Laser
Page isnt prining out Have new ink in printer
Before you can troubleshoot the problem, determine its cause. Do the following steps in order:
1. Print another PDF, such as the first page of Acrobat Help.
  • If a separate PDF file prints correctly, the PDF that doesn't print correctly could be damaged. See "Can't print a specific PDF file" later in this document.
  • If the separate file doesn't print correctly, go to step 2.
2. Print another type of file (for example, a plain text file) from another application (such as Microsoft Word or WordPad).
  • If that other type of file prints correctly, the problem isn't system-wide--it's specific to the Adobe Reader or Acrobat product. However, the problem could come from Reader or Acrobat interacts with the system. Go to step 3 to eliminate some system-related causes of the problem.
  • If that other type of file doesn't print correctly, the problem is system-wide--it isn't specific to Acrobat or PDFs. The problem could be low system resources, insufficient memory on your printer, or a poor connection between your computer and the printer. Go to step 3 to eliminate some likely causes of the problem.
3. Restart your computer, and then print a PDF.
  • If the file prints correctly, your system may have been out of memory or resources.
  • If the file doesn't print correctly, go to step 4.
4. Turn off your printer for at least 15 seconds to flush its memory. Then turn it back on and print a PDF.
  • If the file prints correctly, the printer's memory was too full or had become corrupt.
  • If the file still doesn't print correctly, go to step 5.
5. Print from another computer.
  • If the file prints correctly from another computer, the computer you first used may be unable to connect to the printer or the network correctly. Consult your network documentation or contact your network administrator.
  • If the file still doesn't print correctly, go to step 6.
6. Print a PDF to another printer.
  • If the file prints correctly to a different printer, the computer you first used may be unable to connect to the original printer. Communication, hardware, or memory problems can cause this kind of connection problem. Make sure that the printer is turned on and connected properly. Then run a self-test on the printer to make sure that it's working correctly. Consult your printer documentation for self-test instructions or contact your network administrator.
  • If the file doesn't print correctly, see "Can't print any file from any application" later in this document.
Please post your feedback and Vote if the problem resolved as per your satisfaction.
Sep 01, 2010 | Lexmark Z611 InkJet Photo Printer
When we print with out IPF710 with the print quality set on "high", it does just fine. But when we set the print quality to "standard" it prints parallel pink lines that are about an inch apart across the...
try to print a nozzle check from the test print menu and check if the 6 grids are correct.
From this print out you will find out if some of the colors are nto correct
Nov 12, 2009 | Canon imagePROGRAF IPF710 Printer
Printer LCD says Cartridge Problem - Tri-Color. Refer to device documentation to troubleshoot.
Before you can troubleshoot the problem, you need to determine its cause.
To determine the cause of the printing problem:
1. Print another PDF file, such as the first page of Acrobat Help:
-- If that file prints correctly, the PDF file that doesn't print correctly may be damaged. See "Resolve problems printing a specific PDF file from an Acrobat product" in this document.
-- If the file doesn't print correctly, go to step 2.
2. Print another type of file (for example, a .txt file) from another application (such as Microsoft Word or WordPad):
-- If that file prints correctly, the problem isn't system-wide--it's specific to the Acrobat product. However, the way Acrobat interacts with the system may affect printing performance. Go to step 3 to eliminate some system-related causes of the problem.
-- If the file doesn't print correctly, the problem is system-wide--it isn't specific to Acrobat or PDF files. The problem could be low system resources, insufficient memory on your printer, or a poor connection between your computer and the printer. Go to step 3 to eliminate some likely causes of the problem.
3. Restart your computer, and then print a PDF file:
-- If the file prints correctly, your system may have been out of memory or resources.
-- If the file doesn't print correctly, go to step 4.
4. Turn off your printer for at least 15 seconds to flush its memory, and then turn it back on and print a PDF file:
-- If the file prints correctly, the printer's memory was too full.
-- If the file doesn't print correctly, go to step 5.
5. Print from another computer:
-- If the file prints correctly, the computer you first tried to print from may be unable to connect to the printer or the network correctly. Contact your network administrator or consult your network documentation.
-- If the file doesn't print correctly, go to step 6.
6. Print a PDF file to another printer:
-- If the file prints correctly, the computer you first tried to print from may be unable to connect to the original printer because of a communication, hardware, or memory problem. Make sure that the printer is turned on and connected properly, and then run a self-test on it to make sure that it's working correctly. For instructions, see the documentation that came with the printer. You may want to contact your network administrator for assistance.
-- If the file doesn't print correctly, see "Resolve problems printing any file from any application" in this document.
you can try these option and then try to resolve them and you can find the solution on follwing link==http://kb2.adobe.com/cps/316/316508.html
For more free tehnjical support you can visit-----http://tinyurl.com/lkrpwy
Jul 06, 2009 | HP Officejet J4680 InkJet Printer
Right half of A4 has not print correctly
How old is the printer? try to go to the print options and do a realignment of the print heads. if its an old printer possible might need to clean the print head if that didnt work maybe bad print head.... take it to the pro. good luck!
Mar 21, 2008 | Canon BJC S300 InkJet Printer
Workcentre c2424 Color Problem
For Microsoft Windows 2000 / XP OS:
  1. Within an application, click on [File] on the toolbar, and then select [Print] from the menu. The Print window will be displayed.
  2. Click on the [Properties] button. The Properties window will be displayed.
  3. Click on the [TekColor] tab.
  4. Select a TekColor correction.
    NOTE: It may be necessary to try all the color corrections to obtain the required results.
  5. Click [OK] twice to send the print job to the printer.
For Microsoft Windows 98 / ME OS:
  5. Click on [Apply].
  6. Click [OK] twice to send the print job to the printer.
From the Apple Macintosh OS 9:
  2. From the General pull-down menu, select [TekColor].
  3. Select a TekColor correction.
  4. Click on [Print] to send the print job to the printer.
From the Apple Macintosh OS X (10.2.x and 10.3.x):
  2. From the Copies and Pagespull-down menu, select [Image Quality].
    NOTE: If the Image Quality option is not displayed on Copies and Pages pull-down menu for OS X, configure the printer with the correct PPD. See the procedure below, if needed.
To configure the Printer with the correct PPD:
The PPD file contains features a particular printer supports such as TekColor Corrections. In order for the TekColor Corrections and other printer specific features to be available, the correct PPD file must be specified when the printer is installed, or modify the setting following the procedure below.
  1. Open the appropriate utility: Print Center (for OS 10.2.2.x) or the Printer Setup Utility (for OS 10.3.x):
    1. Double-click on the [Hard Drive].
    2. Double-click on the [Applications] folder.
    3. Double-click on the [Utilities] folder.
    4. Double-click on [Print Center] or [Printer Setup Utility].
  2. Select the appropriate printer from the Printer list.
  3. Click on [Printers] on the toolbar, and then select [Show Info] from the menu.
  4. From the Name and Location pull-down menu, select [Printer Model]. The current PPD being used will be displayed.
  5. If the PPD displayed is incorrect (for example; the PPD is set to 'Generic PostScript Printer'), click on the pull-down menu, and select [Xerox].
  6. Select the corresponding PPD for the printer and then click on [Apply Changes].
    NOTE: Make sure the correct feature set is selected. For example; if the printer is a Phaser 8400DP, make sure the DP feature set is selected.
  7. Close any open windows.
  8. Make sure the Image Quality option is available on the Copies and Pages pull-down menu following the OS X procedure above.
Jan 10, 2008 | Xerox C2424 Copier
Color on monitor different from print
Windows 2000 / XP
  1. From the application's File menu, select Print to display the application's Print dialog box.
  2. Click the Properties button located at the top, right of the Print dialog box to display the printer Properties window.
  3. Click the TekColor tab.
  4. Select a TekColor correction. It may be necessary to try all the color corrections to obtain the desired results.
  5. Click OK to return to the Print dialog box, then click OK to send the print job to the printer.
Windows 98 / Me
  5. Click the Apply button at the bottom, right of the Printer Properties window.
  6. Click OK to return to the Print dialog box, then click OK to send the print job to the printer.
Macintosh OS 9
  1. From the application's File menu, select Print.
  2. Click on the General drop-down list and select TekColor.
  3. Select a TekColor correction. It may be necessary to try all the color corrections to obtain the desired results.
  4. Click the Print button to send the print job to the printer.
Macintosh OS 10 (10.2.x and 10.3.x)
  2. Click the Copies and Pages drop-down list and select Image Quality.
note_image33x30.gif Note: If the image quality option is not displayed, refer to configure the printer with the correct PostScript Printer Description (PPD) File Below. Configure the Printer with the Correct PostScript Printer Description (PPD)
note_image33x30.gif Note: The steps below are only necessary if the Image Quality option is not available in Macintosh OS X. The PPD file contains features a particular printer supports such as TekColor Corrections. In order for the TekColor Corrections and other printer specific features to be available, the correct PPD file must be specified when the printer is installed. To ensure the printer is configured with the correct PPD file:
  1. Open the Print Center (for OS 10.2.2.x) or the Printer Setup Utility (for OS 10.3.x):
    1. Open the Hard Drive.
    2. Open the Applications folder.
    3. Open the Utilities folder.
    4. Open the Print Center or Printer Setup Utility.
  2. With the Print Center or the Printer Setup Utility open, select the appropriate printer from the printer list, then click Show Info from the Printers menu.
  3. Click the Name and Location drop-down lsit and select Printer Model.
  4. The current PPD being used will be displayed. If the PPD shown is incorrect (for example; is set to Generic PostScript Printer), click the drop-down list and select Xerox.
  5. Select the corresponding PPD for the printer and click Apply Changes. note_image33x30.gif Note: Make sure the correct feature set is selected. For example; if the printer is a Phaser 8400DP, ensure the DP feature set is selected.
  6. Close the Printer Info window, close the Printer List window, then check that the Image Quality option is available.
Nov 05, 2007 | Xerox Phaser 8400 Laser Printer
My printer(hp laser jet 1320) dosen't print correctly in more then 30 pages.
sounds like a memory issues or a windows swap file problem. when printing large docs u need to have some free memory in the computer. Also some printers 2 day used windows memory to print so if your pc only has small amount of free memory it can effect printing out large docs. also with a laptop it shares it memory with the video GPU. so you may need to upgrade your memory in your laptop .
Sep 25, 2007 | HP LaserJet 1320 Printer
Lexmark X8350 All-In-One InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
